    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 182.0k Views 79 Watching
    • jeff hammondJ Offline
      @tim danaher said:
      I'm not having much luck with this at all...
      Trying to sweep a spiral stair rail. I've got the path running smack through the midpoint of the balusters, and the profile lined up as centrally as possible, but the resulting handrail is never on the path.
      The original path & Profile are in one group in the attached .skp, the resulting sweep in another...
      Anyone point me to where I'm going wrong?
      Ta,
      i really don't know what's going on there Tim and i don't have FAK.rb installed anymore but i tried it with the 1001bit extrude and it worked out..
      that said, we're talking a $30 tool set vs. a free plugin so...
      TD_baluster.skp
        Tim Danaher
        Ta,
        [attachment=0:afd99swm]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:afd99swm]
        Thanks, Jeff -- Nice result... will have to pony up the dosh, then... 😮
        Cheers,
        Tim
        http://vizarch.blogspot.com
        • X Offline
          xrok1
          Ta,
          [attachment=0:1ls3nueo]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:1ls3nueo]
          thanks for clearing that up Jeff. i hadn't noticed that detail. i thought he was refering to the height difference on the slopes. 😳
            Tim Danaher
            [attachment=0:3ewotani]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:3ewotani]
            Hah! No I won't... the developers have made it free for academic use, and since I teach SU at a design school...
            Cheers,
            Tim
              a $30 tool
              It's free if you use it for personnal use 😎
              You will have just a starting message 😉
              • X Offline
                xrok1
                it says 30 day trial period on mine?
                  rainfrog
                  Jeff, thanks for alerting me to the continued discussion here, regarding the problem I had a few months back! And also for demonstrating the different results between the original follow me and the 1001bit tool. It is nice to see that there is indeed a plugin out there that performs the exact function I was looking for. Very helpful! 👍
                    BERNS
                    THIS IS AN EXCELENT PLUGIN FOR TOPOGRAPHY AND MANY OTHER THEMES! I SAVED UP ALMOST 95% OF TIME AND WORK.
                      lightburn
                      thanks for this wonderful plugin. this just saved me a hell lot of headaches.
                        Blomman
                        A really useful plugin. It helped me with creating a highway interchange.
                        But what if I want to paint the created shape in more than just one color? Since I'm using this plugin to create a road ramp I really want to be able to paint the sides in different colors and textures. As it is now I can't since all the sides of the thing are treated as one. If I click on the left side for example, the right, top and bottom also gets highlighted. Is there anyway to solve this?
                        By the way, I'm using this plugin together with the bezier curves plugin by Fredo 6 if that matters.
                        • mitcorbM Offline
                          mitcorb
                          @Blomman:
                          I am not sure if this is valid, but is the resulting model a group or component? If so, could you right click on this, Edit Group, or Edit Component, and then apply colors, materials, textures to the various faces?
                          Save first, then try the above. Undo(Control Z)if this does not get the desired results.
                          Keep watching this thread for other replies.
                            Blomman
                            Yes, the model is automatically turned into a group which, as far as I know, can not have multiple textures or colors applied to. I forgot to mention that I've already done what you suggested (edit group) which is were I noticed the problem I described in my previous post. I've also tried "explode" but with the same result. 😐
                              Has the model, during the FMAK process, had it's edges smoothened?
                              Have you hidden geometry on or off?
                              If it's off, just turn it on and paint the faces. Or right click the entity and choose soften/smooth and lower the slider bar until the lines appear. You can use Ctrl+E to soften any lines that you don't want to see.
                              I could be way off the mark 😕
                                Blomman
                                The hidden geometry was indeed off, now it works perfectly. Thanks! 😄
                                  Sir
                                  this plugin has just saved me hours. i love you.
                                  image attached. each side of the stairs is a different curve... pain in the ass.Spatial.jpg
                                  • marvins_dadM Offline
                                    marvins_dad
                                    Just wanted to say Thanks again!
                                    I had lost the ruby and someone helped me find this one again...it is amazing for stairs! 👍
                                    My Gallery
                                      dmonahan96
                                      So I installed the followme and keep plugin and it worked great on the first railing that I used it for but now it keeps crashing my SU every time i try it with this other section. Any suggestions?
                                        shoeb_cars
                                        google should really learn some good stuff like this...thanks man 👍
                                          So what am I missing? I've read through as much of this thread as I could. I can get FAK to work on simple arcs but not on this longer path. Even though it's not supposed to require it, I added a C-point to the start end of the path. Surely I've done something that isn't right. Can anyone tell me what it is?
                                          FAK Problem.skp
                                          • mitcorbM Offline
                                            mitcorb
                                            Weld- Don't Weld? Group- Don't Group? This is a test, right?
                                            Plugin "deprecation" due to Sketchup version?
                                            I mean, when you're stumped, we're in hell.
                                            • 11
                                            • 12
                                            • 10 / 12
