    Sculptris
    69 Posts 23 Posters 20.8k Views 23 Watching
    • EscapeArtistE Offline
      EscapeArtist
      @hieru said:
      @jo-ke said:
      how can I convert the model to 3ds?
      sculptris allows only obj and sc1
      I'm struggling with this as well. Does anyone have any suggestions?
      I tried importing a Sculptris .obj into Wings3D, but it crashes every time.
      You can try converting using FBXConverterUI from Autodesk, last I checked it was still available and free.
      You'll have to convert from format "A", your starting format i.e. .OBJ; to .FBX and then to "B", your desired format, i.e .3DS. It works OK, but the output isn't exactly always what I wanted.
      You an also try using Blender to import/export your desired format.
      As far as the model not being visible, try "zoom extents" to see if it appears. Also try increasing the view distance (view > view properties > clip end (set to max, 10,000). Also, consider your model may have been put inside the box.
      • HieruH Offline
        Hieru
        Thanks, I'll give your suggestions a go.
        www.davidhier.co.uk
          Sculptris goes to California 😎
          The mini Zbrush creator DrPetter (Sculptris) goes to Zbrush land! 😉
          And integrates the Z Team 😎
            Khai
            and no news if it'll stay free or go fee...
              see Dr Petter words 😉
              You have yet a cool free version, no ? 😉
                Khai
                actually..not as such, I don't. it crashes constantly with any OBJ brought into it, from any program I use to create them.. and they are OBJ's that other programs have no issues with at all..... I was hoping there would be a fix to the OBJ support..
                  Maybe you don't import the good obj format 😒
                  Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                    Khai
                    lets see. OBJ's from Blender, UVMapper Pro, Poser, trueSpace, Wings3D, Hexagon.... I've had it crash with cubes tri'd or not tri'd.
                    sorry I did do my homework trying to get it to work, but so far I've had no luck with it.
                      KiraNL
                      I played arround with this one too, very nice altho very buggy too.
                      Some of my creations:
                      http://img829.imageshack.us/img829/7388/workinprogressct.png
                      http://img534.imageshack.us/img534/3164/frontsidep.png
                      And a little video, dont know how to include youtube, but heres the link:
                      http://www.youtube.com/watch?v=-Tv329_Oexo
                      • artysmediaA Offline
                        artysmedia
                        hello:
                        One month ago i started using sculptris. Now i will show you my third model.
                        http://farm7.static.flickr.com/6209/6025777804_0031189871.jpg
                        Devil Chiu 01 por artysmedia, en Flickr
                        More, laterrrrr 💚
                        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                        Blog: Artysmedia
                        • StilTegS Offline
                          StilTeg
                          Damn, I definitely need to improve my skills in Sculptris ...
                          doing technical engineering on SketchUp ... without plugins
                          • BoxB Offline
                            I saw this thread this morning so downloaded Sculptris, watched a couple of Vids and after mucking about for a while I produced this.
                            Very nice program.
                            I guess now I should learn about rendering.
                            • soloS Offline
                              Got a link to the vids?
                              • BoxB Offline
                                I just went to the forum for sculptris and found the first sticky with what seemed relevant to getting started.
                                The links are in the thread.
                                ZBrushCentral
                                (www.zbrushcentral.com)
                                • soloS Offline
                                  Very helpful tutorial, I have been using it without watching any tutorial (as I never found one)
                                  Expect brilliant models...I'm energized.
                                    artysmedia
                                    Simplified version to use with Google SketchUp in my project "Ripper Rapper".
                                    Designed with Sculptris and Google SketchUp
                                    Edges: 74640
                                    Faces: 48435
                                    http://farm7.static.flickr.com/6210/6028911972_9fc358f67a.jpg
                                    Devil Chiu 03 por artysmedia, en Flickr
                                    And the retouched one:
                                    http://farm7.static.flickr.com/6082/6025223459_73c30b7cc1.jpg
                                    Devil Chiu 02 por artysmedia, en Flickr
                                    Blog: Artysmedia
                                      artysmedia
                                      http://farm7.static.flickr.com/6181/6053166725_26da0d09f2_m.jpg
                                      Tree-rror 01 por artysmedia, en Flickr
                                      This is the fourth model I have done with the program Sculptris. The first two (fairly complex) are still cooking in the oven.
                                      [Este es el cuarto modelo que he realizado con el programa Sculptris. Los dos primeros (bastante más complejos) están todavía cociéndose en el horno.]
                                      Designed with 3D Studio Max and Sculptris
                                      Rendered with VRay
                                      Retouched with Adobe Photoshop
                                      [Diseñado con Sculptris y 3D Studio Max
                                      Renderizado con VRay
                                      Retocado con Adobe Photoshop]
                                      Blog: Artysmedia
                                        artysmedia
                                        Another model...
                                        http://farm7.static.flickr.com/6207/6055212519_488c75629c_m.jpg
                                        Demonic por artysmedia, en Flickr
                                        Blog: Artysmedia
                                          artysmedia
                                          Another model...
                                          http://farm7.static.flickr.com/6191/6056251675_e6ffb51ba1_m.jpg
                                          Duendemon por artysmedia, en Flickr
                                          Blog: Artysmedia
                                            artysmedia
                                            Drakomonik
                                            http://farm7.static.flickr.com/6087/6059120699_83aca6fb35_m.jpg
                                            Drakomonik por artysmedia, en Flickr
                                            Blog: Artysmedia
                                            • 3 / 4
