    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 433.5k Views 92 Watching
      @honoluludesktop said:
      Wow, it that a mesh, or linked surfaces?
      What is?
      • honoluludesktopH Offline
        honoluludesktop
        The plane, or cylinder, etc. Hmm..... maybe I don't know how to ask my question. If still unclear, attached is a sample. Can I change its shape? What happens to the textures? Btw, thats a very slick menu.
        Temp00.skp
          Yes - here's your model after I selected a part of it, with soft selection and moved it. Looks like the wind pushes the curtains.
          As for the UV mapping, that will unfortunately be messed up - as normally happens in SketchUp when you modify UV mapped geometry.
          However, this is another feature I am looking into. If I can get it working I will probably also make a standalone "preserve UV mapping" plugin.
          I hope that answered your question? ๐Ÿ˜•
            Btw, here is your sample file after I modified it. The UV mapping didn't seem to bad.
            Temp00_TT.skp
              honoluludesktop
              Thanks, where were you when I needed it ๐Ÿ™‚ the texture was a SU floor covering that I scaled and changed the color of.
                Coding into the night ๐Ÿ˜‰
                • shuraS Offline
                  shura
                  Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
                  btw, nice to hear your voice again ๐Ÿ˜‰
                  best
                  alex
                  • X Offline
                    xrok1
                    Thom, what address do you send your email from? maybe the domain name is in my blocked sender list for some reason. i still havn't recieved. ๐Ÿ˜ž
                    โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                      honoluludesktop
                      Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
                      • X Offline
                        xrok1
                        are you talking about a cage or proxy mesh? or opposite of subdivision?
                          honoluludesktop
                          What is a cage or a proxy mesh?
                          • X Offline
                            xrok1
                            like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
                            here is an example: you manipulate the outer mesh to effect the inner one.
                            • X Offline
                              xrok1
                              ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
                              SDS WITH SOFT SELECTION!
                              http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
                              • ArcA Offline
                                Arc
                                I made a little video tut, but I don'n know how to instert ping video in post?
                                http://www.screencast.com/t/OTlkZWRjMT
                                [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
                                  honoluludesktop
                                  Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                                    best
                                    alex
                                    Hi Alex! Thank you very much!
                                    Hope you are doing well. Give me a shout if you should find yourself in Trondheim again! ๐Ÿ˜„
                                      It would be difficult, yes. I have only implemented a polyline simplifier in one of my plugins - but that was just porting an algorithm I found. I have no idea on how to simplify a whole mesh.
                                      But didn't Fredo or Whaat do something like this in one of their plugins?
                                        Thanks Arc! Really fun to see it used by others! ๐Ÿ‘
                                        (I embedded the video for you. Had to dig into the HTML source of that link you gave to find the .swf reference. Jing is awkward like that.)
                                          Plugin Polyreducer by Whaat ๐Ÿ˜‰
                                            honoluludesktop
                                            Can someone point me to a link? The ones I tried hung or didn't do mesh, don't recall the names.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
