    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • honoluludesktopH
      honoluludesktop
      The plane, or cylinder, etc. Hmm..... maybe I don't know how to ask my question. If still unclear, attached is a sample. Can I change its shape? What happens to the textures? Btw, thats a very slick menu.
      Temp00.skp
        Yes - here's your model after I selected a part of it, with soft selection and moved it. Looks like the wind pushes the curtains.
        As for the UV mapping, that will unfortunately be messed up - as normally happens in SketchUp when you modify UV mapped geometry.
        However, this is another feature I am looking into. If I can get it working I will probably also make a standalone "preserve UV mapping" plugin.
        I hope that answered your question? ๐Ÿ˜•
          Btw, here is your sample file after I modified it. The UV mapping didn't seem to bad.
          Temp00_TT.skp
          • honoluludesktopH
            honoluludesktop
            Thanks, where were you when I needed it ๐Ÿ™‚ the texture was a SU floor covering that I scaled and changed the color of.
              Coding into the night ๐Ÿ˜‰
              • shuraS
                shura
                Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
                btw, nice to hear your voice again ๐Ÿ˜‰
                best
                alex
                • X
                  xrok1
                  Thom, what address do you send your email from? maybe the domain name is in my blocked sender list for some reason. i still havn't recieved. ๐Ÿ˜ž
                  โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                  • honoluludesktopH
                    honoluludesktop
                    Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
                    • X
                      xrok1
                      are you talking about a cage or proxy mesh? or opposite of subdivision?
                      • honoluludesktopH
                        honoluludesktop
                        What is a cage or a proxy mesh?
                        • X
                          xrok1
                          like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
                          here is an example: you manipulate the outer mesh to effect the inner one.
                          • X
                            xrok1
                            ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
                            SDS WITH SOFT SELECTION!
                            http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
                            • ArcA
                              Arc
                              I made a little video tut, but I don'n know how to instert ping video in post?
                              http://www.screencast.com/t/OTlkZWRjMT
                              [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
                              • honoluludesktopH
                                honoluludesktop
                                Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                                  best
                                  alex
                                  Hi Alex! Thank you very much!
                                  Hope you are doing well. Give me a shout if you should find yourself in Trondheim again! ๐Ÿ˜„
                                    It would be difficult, yes. I have only implemented a polyline simplifier in one of my plugins - but that was just porting an algorithm I found. I have no idea on how to simplify a whole mesh.
                                    But didn't Fredo or Whaat do something like this in one of their plugins?
                                      Thanks Arc! Really fun to see it used by others! ๐Ÿ‘
                                      (I embedded the video for you. Had to dig into the HTML source of that link you gave to find the .swf reference. Jing is awkward like that.)
                                        Plugin Polyreducer by Whaat ๐Ÿ˜‰
                                        • honoluludesktopH
                                          honoluludesktop
                                          Can someone point me to a link? The ones I tried hung or didn't do mesh, don't recall the names.
                                            The plug Polyreducer by Whaat above your post don't make the trick? ๐Ÿ˜ฎ
                                            • 33
                                            • 34
                                            • 2 / 34
