    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 477.3k Views 92 Watching
    • shuraS Offline
      shura
      Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
      btw, nice to hear your voice again ๐Ÿ˜‰
      best
      alex
      • X Offline
        xrok1
        Thom, what address do you send your email from? maybe the domain name is in my blocked sender list for some reason. i still havn't recieved. ๐Ÿ˜ž
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • honoluludesktopH Offline
          honoluludesktop
          Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
          • X Offline
            xrok1
            are you talking about a cage or proxy mesh? or opposite of subdivision?
              honoluludesktop
              What is a cage or a proxy mesh?
              • X Offline
                xrok1
                like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
                here is an example: you manipulate the outer mesh to effect the inner one.
                • X Offline
                  xrok1
                  ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
                  SDS WITH SOFT SELECTION!
                  http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
                  • ArcA Offline
                    Arc
                    I made a little video tut, but I don'n know how to instert ping video in post?
                    http://www.screencast.com/t/OTlkZWRjMT
                    [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
                      honoluludesktop
                      Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                        best
                        alex
                        Hi Alex! Thank you very much!
                        Hope you are doing well. Give me a shout if you should find yourself in Trondheim again! ๐Ÿ˜„
                          It would be difficult, yes. I have only implemented a polyline simplifier in one of my plugins - but that was just porting an algorithm I found. I have no idea on how to simplify a whole mesh.
                          But didn't Fredo or Whaat do something like this in one of their plugins?
                            Thanks Arc! Really fun to see it used by others! ๐Ÿ‘
                            (I embedded the video for you. Had to dig into the HTML source of that link you gave to find the .swf reference. Jing is awkward like that.)
                              Plugin Polyreducer by Whaat ๐Ÿ˜‰
                                honoluludesktop
                                Can someone point me to a link? The ones I tried hung or didn't do mesh, don't recall the names.
                                  The plug Polyreducer by Whaat above your post don't make the trick? ๐Ÿ˜ฎ
                                    honoluludesktop
                                    Maybe I am doing something wrong, here is the model.
                                    Shoes01 high heels.skp
                                    • PixeroP Offline
                                      Pixero
                                      Looks great Thomas. Will get it ASAP.
                                      By the way, now that your done with the vertex tool could you start thinking about a UV tool with planar and cubic mapping? ๐Ÿ˜‰
                                        ๐Ÿ˜„ ๐Ÿค“
                                        Yes - UV experimenting is on the schedule. I had some success with a quick mockup for planar mapping - basically projecting. Need to experiment with how cubic will be done and what kind of UI is needed.
                                        Also looking into a way to lock UV mapping co-ordinates - something that would be useful as a standalone plugin and as a feature of others, such as Vertex Tools.
                                          Yup, and Fredo scale (bending), Shape bender and all. I want to be able to create arches without any hassle. ๐Ÿ˜’
                                            @Honolulu
                                            Whith your shoe that curious, after Polyreduce, number of entities is increasing! ๐Ÿ˜ฎ
                                            I works with only one shoes, save at the end of a process of poly reduce 50%
                                            Relaunch, poly reduce 50% etc... 6 times!
                                            At the end I have more entities than the beginning! ๐Ÿ˜’
                                            Shoes01medium6.zip
                                            • 33
                                            • 34
                                            • 2 / 34
