    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • X
      xrok1
      love the jitter idea. i already use the jitter ruby (modified a little ๐Ÿ˜‰ ) to add a little age or just mellow out the CG look sometimes.
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
      • honoluludesktopH
        honoluludesktop
        Wow, it that a mesh, or linked surfaces?
          What is?
          • honoluludesktopH
            honoluludesktop
            The plane, or cylinder, etc. Hmm..... maybe I don't know how to ask my question. If still unclear, attached is a sample. Can I change its shape? What happens to the textures? Btw, thats a very slick menu.
            Temp00.skp
              Yes - here's your model after I selected a part of it, with soft selection and moved it. Looks like the wind pushes the curtains.
              As for the UV mapping, that will unfortunately be messed up - as normally happens in SketchUp when you modify UV mapped geometry.
              However, this is another feature I am looking into. If I can get it working I will probably also make a standalone "preserve UV mapping" plugin.
              I hope that answered your question? ๐Ÿ˜•
                Btw, here is your sample file after I modified it. The UV mapping didn't seem to bad.
                Temp00_TT.skp
                • honoluludesktopH
                  honoluludesktop
                  Thanks, where were you when I needed it ๐Ÿ™‚ the texture was a SU floor covering that I scaled and changed the color of.
                    Coding into the night ๐Ÿ˜‰
                    • shuraS
                      shura
                      Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
                      btw, nice to hear your voice again ๐Ÿ˜‰
                      best
                      alex
                      • X
                        xrok1
                        Thom, what address do you send your email from? maybe the domain name is in my blocked sender list for some reason. i still havn't recieved. ๐Ÿ˜ž
                        • honoluludesktopH
                          honoluludesktop
                          Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
                          • X
                            xrok1
                            are you talking about a cage or proxy mesh? or opposite of subdivision?
                            • honoluludesktopH
                              honoluludesktop
                              What is a cage or a proxy mesh?
                              • X
                                xrok1
                                like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
                                here is an example: you manipulate the outer mesh to effect the inner one.
                                • X
                                  xrok1
                                  ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
                                  SDS WITH SOFT SELECTION!
                                  http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
                                  • ArcA
                                    Arc
                                    I made a little video tut, but I don'n know how to instert ping video in post?
                                    http://www.screencast.com/t/OTlkZWRjMT
                                    [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
                                    • honoluludesktopH
                                      honoluludesktop
                                      Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                                        best
                                        alex
                                        Hi Alex! Thank you very much!
                                        Hope you are doing well. Give me a shout if you should find yourself in Trondheim again! ๐Ÿ˜„
                                          It would be difficult, yes. I have only implemented a polyline simplifier in one of my plugins - but that was just porting an algorithm I found. I have no idea on how to simplify a whole mesh.
                                          But didn't Fredo or Whaat do something like this in one of their plugins?
                                            Thanks Arc! Really fun to see it used by others! ๐Ÿ‘
                                            (I embedded the video for you. Had to dig into the HTML source of that link you gave to find the .swf reference. Jing is awkward like that.)
                                            • 33
                                            • 34
                                            • 2 / 34
