    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • honoluludesktopH
      honoluludesktop
      What is a cage or a proxy mesh?
      • X
        xrok1
        like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
        here is an example: you manipulate the outer mesh to effect the inner one.
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • X
          xrok1
          ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
          SDS WITH SOFT SELECTION!
          http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
          • ArcA
            Arc
            I made a little video tut, but I don'n know how to instert ping video in post?
            http://www.screencast.com/t/OTlkZWRjMT
            [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
            • honoluludesktopH
              honoluludesktop
              Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                @shura said:
                Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
                btw, nice to hear your voice again ๐Ÿ˜‰
                best
                alex
                Hi Alex! Thank you very much!
                Hope you are doing well. Give me a shout if you should find yourself in Trondheim again! ๐Ÿ˜„
                  @honoluludesktop said:
                  Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
                  It would be difficult, yes. I have only implemented a polyline simplifier in one of my plugins - but that was just porting an algorithm I found. I have no idea on how to simplify a whole mesh.
                  But didn't Fredo or Whaat do something like this in one of their plugins?
                    Thanks Arc! Really fun to see it used by others! ๐Ÿ‘
                    (I embedded the video for you. Had to dig into the HTML source of that link you gave to find the .swf reference. Jing is awkward like that.)
                      Plugin Polyreducer by Whaat ๐Ÿ˜‰
                      • honoluludesktopH
                        honoluludesktop
                        Can someone point me to a link? The ones I tried hung or didn't do mesh, don't recall the names.
                          The plug Polyreducer by Whaat above your post don't make the trick? ๐Ÿ˜ฎ
                          • honoluludesktopH
                            honoluludesktop
                            Maybe I am doing something wrong, here is the model.
                            Shoes01 high heels.skp
                            • PixeroP
                              Pixero
                              Looks great Thomas. Will get it ASAP.
                              By the way, now that your done with the vertex tool could you start thinking about a UV tool with planar and cubic mapping? ๐Ÿ˜‰
                                ๐Ÿ˜„ ๐Ÿค“
                                Yes - UV experimenting is on the schedule. I had some success with a quick mockup for planar mapping - basically projecting. Need to experiment with how cubic will be done and what kind of UI is needed.
                                Also looking into a way to lock UV mapping co-ordinates - something that would be useful as a standalone plugin and as a feature of others, such as Vertex Tools.
                                • GaieusG
                                  Yup, and Fredo scale (bending), Shape bender and all. I want to be able to create arches without any hassle. ๐Ÿ˜’
                                    @Honolulu
                                    Whith your shoe that curious, after Polyreduce, number of entities is increasing! ๐Ÿ˜ฎ
                                    I works with only one shoes, save at the end of a process of poly reduce 50%
                                    Relaunch, poly reduce 50% etc... 6 times!
                                    At the end I have more entities than the beginning! ๐Ÿ˜’
                                    Shoes01medium6.zip
                                    • X
                                      xrok1
                                      i'm very surprised this isn't getting waaaaay more attention (its like the holy grail of SU IMHO). ๐Ÿ˜• give people fur they'll play forever (this does work with fur you know), but give people a real tool and its too much like work i guess ๐Ÿคฃ ??????
                                      • CadFatherC
                                        CadFather
                                        ..wonderful ruby. well thought out in detail - amazing i had just the right need for it yesterday - put it through the paces and no glitch..
                                        ๐Ÿ‘ ๐Ÿ‘
                                        • honoluludesktopH
                                          honoluludesktop
                                          On my system, with this model, Polyreduce just hangs:-(
                                            I'd love to see in action screenshots of what kind of modelling people use the plugin for. nudge nudge wink wink
                                            • 33
                                            • 34
                                            • 3 / 34
