    [Plugin] Draw Boundingbox
    50 Posts 20 Posters 40.2k Views 20 Watching
      I don't think the overhead of extra registry items is that significant. I'd rather use the registry and the built-in API than to start littering small preference files about and adding extra complexity. Processing many small files also has its overhead.
        Are there alternatives?
          dedmin
          πŸ‘ πŸ‘ πŸ‘ πŸ‘
          • bagateloB
            bagatelo
            Why the boundingbox is not attached with object? Why we cannot make boundingbox with only edges?
              No one asked... πŸ˜‰
                dedmin
                Oh yes, please! πŸŽ‰ πŸŽ‰
                • kenK
                  ken
                  Thomthom
                  Designing and fabricating large but still truck-able steel equipment, I find your plugin an easy to use method to determine the width, height and length of each section for the trucking company. You have made it easier to determine how to arrange a load on the truck bed to minimize the requirements for oversize load permits.
                  Ken
                    huh - again the simplest of plugins turns out to be of wider usage than I thought. I figured it was a rather obscure request. πŸ˜„
                    alexpacio2013A 1 Reply Last reply πŸ™
                      agamemnus
                      Very useful for my game -- to center models or stretch them appropriately utilizing the length/width/height ratios. Thank you.
                        That can be used for packaging too πŸ˜‰
                        Next step will be optimisation of placement of some objects for minimize the Bounding box πŸ˜‰
                        • kenK
                          ken
                          Now, that would be very useful.
                          Ken
                          • B
                            Ben Ritter
                            Thanks for sharing β˜€
                            • mitcorbM
                              mitcorb
                              @ThomThom:
                              Just out of curiosity, is the bounding box you create even distantly related to the method of producing a convex hull--or is this even relevant?
                                Nope - it just uses the corner of the boundingbox SketchUp provides.
                                • GaieusG
                                  Hi Thom,
                                  Great plugin (again) but blah-blah... you know that.
                                  I have noticed however that it can be launched when only primitive geometry (i.e. no group/component) is selected then I can even tell the plugin to create a bounding box but of course nothing happens.
                                  Of course, I know why this is happening ("not" happening) so not too big problem but maybe some warning dialog would be best so that users do not get confused.
                                    Couldn't you simply make a temporary group of all selected and then get the bounds of that?
                                    ents=model.active_entities
                                    ss=model.selection
                                    enta=ss.to_a
                                    gp=ents.add_group(enta)
                                    bb=gp.bounds
                                    ### store that data
                                    gp.explode
                                    ### make the bbox
                                    ss.add(enta)
                                    ### OR whatever...
                                      hm... I thought I had some message system that warned about no valid selection. Must have accidentally removed it as I rewrote it
                                      • GaieusG
                                        I do not mean to create a bounding box for loose geometry - what for? - it's just for other users to avoid confusion.
                                        Also, how about an option that the bounding box is inside/outside of the group/component? (Would be easier to move them together with just one click selection). Of course, in this case there would be the risk of loose geometry merging inside...
                                          > ss=model.selection
                                          > enta=ss.to_a
                                          > bb=gp.bounds
                                          > ### store that data
                                          > gp.explode
                                          > ### make the bbox
                                          > ss.add(enta)
                                          > ### OR whatever...
                                          I could just add up the bounds from all the "loose" geometry.
                                            I was thinking adding to the input box:
                                            Option to group the generated geometry
                                            Option to generate the geometry inside the components they represent.
                                            • 1 / 3
