    [Plugin] Draw Boundingbox
    50 Posts 20 Posters 40.2k Views 20 Watching
      So, are the faces not what you will be using? But instead just construction points for the boundingbox edges?
      Could easily make it draw the boundingbox with constructions lines and constructions points.
        dedmin
        Both! But option like this is welcome!! ☀ ☀
          Update to 1.1.0
          # CHANGELOG
          # 1.1.0 - 04.07.2010
          #    * Support for 2D instances.
          #    * Option between Faces or Construction geometry.
          #    * Processes all groups / components in selection.
          #    * Changed menu text.
          #    * Fixed namespace name.
          • Didier BurD
            Didier Bur
            Hi Thomthom,
            I was wondering if it is really useful to store options in the registry (read/write_defaults).
            Adding more and more reg keys will slow down the computer or not ? What do you think ?
            DB
              I don't think the overhead of extra registry items is that significant. I'd rather use the registry and the built-in API than to start littering small preference files about and adding extra complexity. Processing many small files also has its overhead.
                Are there alternatives?
                  dedmin
                  • bagateloB
                    bagatelo
                    Why the boundingbox is not attached with object? Why we cannot make boundingbox with only edges?
                      No one asked... 😉
                        dedmin
                        @thomthom said:
                        No one asked... 😉
                        Oh yes, please! 🎉 🎉
                        • kenK
                          ken
                          Thomthom
                          Designing and fabricating large but still truck-able steel equipment, I find your plugin an easy to use method to determine the width, height and length of each section for the trucking company. You have made it easier to determine how to arrange a load on the truck bed to minimize the requirements for oversize load permits.
                          Ken
                            huh - again the simplest of plugins turns out to be of wider usage than I thought. I figured it was a rather obscure request. 😄
                            alexpacio2013A 1 Reply Last reply 🙏
                              agamemnus
                              Very useful for my game -- to center models or stretch them appropriately utilizing the length/width/height ratios. Thank you.
                                That can be used for packaging too 😉
                                Next step will be optimisation of placement of some objects for minimize the Bounding box 😉
                                • kenK
                                  ken
                                  Now, that would be very useful.
                                  Ken
                                  • B
                                    Ben Ritter
                                    Thanks for sharing ☀
                                    • mitcorbM
                                      mitcorb
                                      @ThomThom:
                                      Just out of curiosity, is the bounding box you create even distantly related to the method of producing a convex hull--or is this even relevant?
                                        Nope - it just uses the corner of the boundingbox SketchUp provides.
                                        • GaieusG
                                          Hi Thom,
                                          Great plugin (again) but blah-blah... you know that.
                                          I have noticed however that it can be launched when only primitive geometry (i.e. no group/component) is selected then I can even tell the plugin to create a bounding box but of course nothing happens.
                                          Of course, I know why this is happening ("not" happening) so not too big problem but maybe some warning dialog would be best so that users do not get confused.
                                            Couldn't you simply make a temporary group of all selected and then get the bounds of that?
                                            ents=model.active_entities
                                            ss=model.selection
                                            enta=ss.to_a
                                            gp=ents.add_group(enta)
                                            bb=gp.bounds
                                            ### store that data
                                            gp.explode
                                            ### make the bbox
                                            ss.add(enta)
                                            ### OR whatever...
                                            • 1 / 3
