    [Plugin] Draw Boundingbox
    50 Posts 20 Posters 40.3k Views 20 Watching
      agamemnus
      Very useful for my game -- to center models or stretch them appropriately utilizing the length/width/height ratios. Thank you.
        That can be used for packaging too πŸ˜‰
        Next step will be optimisation of placement of some objects for minimize the Bounding box πŸ˜‰
        • kenK
          ken
          Now, that would be very useful.
          Ken
          • B
            Ben Ritter
            Thanks for sharing β˜€
            • mitcorbM
              mitcorb
              @ThomThom:
              Just out of curiosity, is the bounding box you create even distantly related to the method of producing a convex hull--or is this even relevant?
                Nope - it just uses the corner of the boundingbox SketchUp provides.
                • GaieusG
                  Hi Thom,
                  Great plugin (again) but blah-blah... you know that.
                  I have noticed however that it can be launched when only primitive geometry (i.e. no group/component) is selected then I can even tell the plugin to create a bounding box but of course nothing happens.
                  Of course, I know why this is happening ("not" happening) so not too big problem but maybe some warning dialog would be best so that users do not get confused.
                    Couldn't you simply make a temporary group of all selected and then get the bounds of that?
                    ents=model.active_entities
                    ss=model.selection
                    enta=ss.to_a
                    gp=ents.add_group(enta)
                    bb=gp.bounds
                    ### store that data
                    gp.explode
                    ### make the bbox
                    ss.add(enta)
                    ### OR whatever...
                      hm... I thought I had some message system that warned about no valid selection. Must have accidentally removed it as I rewrote it
                      • GaieusG
                        I do not mean to create a bounding box for loose geometry - what for? - it's just for other users to avoid confusion.
                        Also, how about an option that the bounding box is inside/outside of the group/component? (Would be easier to move them together with just one click selection). Of course, in this case there would be the risk of loose geometry merging inside...
                          > ss=model.selection
                          > enta=ss.to_a
                          > bb=gp.bounds
                          > ### store that data
                          > gp.explode
                          > ### make the bbox
                          > ss.add(enta)
                          > ### OR whatever...
                          I could just add up the bounds from all the "loose" geometry.
                            I was thinking adding to the input box:
                            Option to group the generated geometry
                            Option to generate the geometry inside the components they represent.
                            • GaieusG
                              OK, I'll stop nagging you now...
                              πŸ˜‰
                              • cmeedC
                                cmeed
                                I just downloaded this plugin and its a very useful addition, I'm using it, thanks to 'dedmin's recommendation for use with Layout. Its difficult sometimes to use the dimensioning tool in LO on rounded or odd shaped geometry. this tool certainly helps! Thank you
                                grouping the resulting boundary box would make a great simple plugin more streamlined. if at all possible.... please ... maybe
                                  agamemnus
                                  I noticed that if I rotate some objects and use this plugin, the bounding box will use the rotated boxes of these other objects... any way to perhaps get the real limits of the object set instead of using their (inaccurate) bounding box without having to explode everything?
                                    There probably is, but I'm not sure how. This plugin is very simple designed specifically to use the boundingbox.
                                    • EarthMoverE
                                      EarthMover
                                      I missed this useful plugin the first time around. Thanks to Rich for pointing me here and of course thanks to ThomThom for another brilliant tool! πŸ‘
                                      Content Creator at Skapeup
                                        John_C
                                        Thanks for this great little plugin Thomthom, it's allowed me to reset the axis on an irregular component that inherited from someone else's model.
                                        I'm not sure how often I'll use it, but it's great to know about all of your cookie ware plugins, thanks ... πŸ‘
                                          AISmebel
                                          Hello dear thomthom. Can I ask you to make a small edit to your plugin for me so that it puts construction points not only at the outer corners, but also in the center of the construction lines. For your understanding, I will attach a picture. (Additional points I built using AAV) Additional points help to move or position rounded objects. Thank you.
                                          • Didier BurD
                                            Didier Bur
                                            Hi AISMebel,
                                            Below is what you can do:
                                            Browse your disk to your Plugins folder to find a sub-folder named 'tt_draw_bb'
                                            • open the file 'core.rb' in that folder (using a'pure' text editor)
                                            • find line #118
                                            • add the following line:
                                            ents.add_cpoint( Geom;;Point3d.linear_combination(0.5, face[0], 0.5, face[1]))
                                            • save the core.rb file and restart SketchUp.
                                            click to see if it works ;-)
                                            DB
                                            F A 2 Replies Last reply
                                            • 2 / 3
