    [Plugin] Draw Boundingbox
    50 Posts 20 Posters 40.2k Views 20 Watching
      dedmin
      Both! But option like this is welcome!! ☀ ☀
        Update to 1.1.0
        # CHANGELOG
        # 1.1.0 - 04.07.2010
        #    * Support for 2D instances.
        #    * Option between Faces or Construction geometry.
        #    * Processes all groups / components in selection.
        #    * Changed menu text.
        #    * Fixed namespace name.
        • Didier BurD
          Didier Bur
          Hi Thomthom,
          I was wondering if it is really useful to store options in the registry (read/write_defaults).
          Adding more and more reg keys will slow down the computer or not ? What do you think ?
          DB
            I don't think the overhead of extra registry items is that significant. I'd rather use the registry and the built-in API than to start littering small preference files about and adding extra complexity. Processing many small files also has its overhead.
              Are there alternatives?
                dedmin
                • bagateloB
                  bagatelo
                  Why the boundingbox is not attached with object? Why we cannot make boundingbox with only edges?
                    No one asked... 😉
                      dedmin
                      @thomthom said:
                      No one asked... 😉
                      Oh yes, please! 🎉 🎉
                      • kenK
                        ken
                        Thomthom
                        Designing and fabricating large but still truck-able steel equipment, I find your plugin an easy to use method to determine the width, height and length of each section for the trucking company. You have made it easier to determine how to arrange a load on the truck bed to minimize the requirements for oversize load permits.
                        Ken
                          huh - again the simplest of plugins turns out to be of wider usage than I thought. I figured it was a rather obscure request. 😄
                          alexpacio2013A 1 Reply Last reply 🙏
                            agamemnus
                            Very useful for my game -- to center models or stretch them appropriately utilizing the length/width/height ratios. Thank you.
                              That can be used for packaging too 😉
                              Next step will be optimisation of placement of some objects for minimize the Bounding box 😉
                              • kenK
                                ken
                                Now, that would be very useful.
                                Ken
                                • B
                                  Ben Ritter
                                  Thanks for sharing ☀
                                  • mitcorbM
                                    mitcorb
                                    @ThomThom:
                                    Just out of curiosity, is the bounding box you create even distantly related to the method of producing a convex hull--or is this even relevant?
                                      Nope - it just uses the corner of the boundingbox SketchUp provides.
                                      • GaieusG
                                        Hi Thom,
                                        Great plugin (again) but blah-blah... you know that.
                                        I have noticed however that it can be launched when only primitive geometry (i.e. no group/component) is selected then I can even tell the plugin to create a bounding box but of course nothing happens.
                                        Of course, I know why this is happening ("not" happening) so not too big problem but maybe some warning dialog would be best so that users do not get confused.
                                          Couldn't you simply make a temporary group of all selected and then get the bounds of that?
                                          ents=model.active_entities
                                          ss=model.selection
                                          enta=ss.to_a
                                          gp=ents.add_group(enta)
                                          bb=gp.bounds
                                          ### store that data
                                          gp.explode
                                          ### make the bbox
                                          ss.add(enta)
                                          ### OR whatever...
                                            hm... I thought I had some message system that warned about no valid selection. Must have accidentally removed it as I rewrote it
                                            • 1 / 3
