    1.3k Posts 300 Posters 3.1m Views 298 Watching
      Jim
      I have moved the Curviloft tutorial to the Tutorials Forum - it will hopefully keep both topics more readable.
      404 Not Found
      (forums.sketchucation.com)
      • halroachH Offline
        halroach
        As all of your wonderful plugins!
        Very nice fredo!
        FlexTools - Super Quick Windows, Doors, Slats...
          dolphus
          Fredo I am a big fan of your work, i hang my head in shame and confess that i cannot get the Curvilot to work when i start uo SU i get the following message " Module Curviloft requires LibFredo6 version greater than 35. Current version is 34" but i do have Version 35 in the plugin dir as well as 34 if i remove the 34 many of my other Fredo plugins work is it possible for anyone to diagnose my problem?
          Thanks in anticipation
          • fredo6F Offline
            @grim said:
            fredo and charly
            this tool is fantastic, however after reviewing the examples posted by charly i was eager to try them out for myself but when it came time to try step 3 if found that the curviloft menue did not display the same information nor did the black backround profile menu appear i have sinced removed all rubies and reloaded only the latest from you posting to see if i had installed it incorrectly however i get the same responce
            can you enlighten me as to the problem or is there somthing i am over looking
            thanks
            Maybe you just need to click on a junction to get the floating palette appear, if it is your problem.
            • fredo6F Offline
              Check out if you have a subfolder named LIBFREDO6_Dir_35 in the Plugins directory. Normally, the script automatically select the latest version of LibFredo6
                grim
                fredo
                thanks for the pointers, they work... there seems to be a lot more to using this tool than i realise, i am getting the hang of it slowly
                  dolphus
                  Thank you for the quick reply, I thought i had put the folder in i have now and it works
                  Thank you very much
                  • fredo6F Offline
                    @daniel s said:
                    Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
                    Daniel S
                    I missed this one.
                    Here is the result, with Loft by Spline
                    Pencil for loft.skp
                      grim
                      danial
                      tried you shape file and came up with very different results see attached file
                      can you enlighten me as to where i am going wrong as i followed your instructions as well as trying one of my own
                      regards
                      david
                      grimshape.skp
                        Daniel S
                        You can select all the contours to make the loft:
                        You will see that there is a problem with the default method.. try to change it with the toolbar for different results:
                        Or you can make it in two parts (for this model I wanted this result):
                        Daniel S
                          Daniel S
                          The idea was a result like this for that model:
                          Is better to make the loft in parts and not all togheter in a lot of cases.
                          For example, I´m making a shape where two contours share edges.
                          it is better to make a loft between 1-2-3, then explode and after that make the loft 4-5 for better results:
                          I attach the skp to show that if you make a loft of 1-2-3-4-5 the results are not good in this case.
                          Daniel S
                          shape.skp
                          • fredo6F Offline
                            [attachment=6:fuxjwvvf]<!-- ia6 -->pencil.JPG<!-- ia6 -->[/attachment:fuxjwvvf]Daniel S
                            For the pencil, use the regular Bezier method (first method) instead of Cubic Bezier (default method).
                            [attachment=0:fuxjwvvf]<!-- ia0 -->Pencil Loft Daniel S.png<!-- ia0 -->[/attachment:fuxjwvvf]
                            PS: for the other shape, there are still some issues when curves are partially overlapping. But it is a good example I can work from.
                              I've yet to try out this plugin for myself - but is there a linear option as well? Or is it just beziers? It seems to be that the pencil would require a linear morphing to get the shape of the tip.
                              • fredo6F Offline
                                The Linear option will be available in the next release (along with other spline methods). I came to that conclusion too.
                                • Bob JamesB Offline
                                  Bob James
                                  Just came across this wonderful and amazing new tool.
                                  I'm pretty much speechless: incredible 🎉
                                  This opens up soooo many possibilities. Thank you for this great tool
                                    KarinaGM
                                    I haven't even had time to use it and I am already in love with this plugin.
                                    Thanks Fredo
                                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                    -Benjamín Franklin.**
                                      A little use of it 😉
                                      Grow by Tig
                                      Curviloft by Fredo6
                                      FredoScale by Fredo6
                                      http://forums.polyloop.net/picture.php?albumid=23&pictureid=803
                                      http://forums.polyloop.net/picture.php?albumid=23&pictureid=804
                                      • charly2008C Offline
                                        charly2008
                                        I tried with Curviloft the to make the ornaments in this historic door . But it does not look good. I have to try other shapes. In the rendered image it looks like a Crab.
                                        • N Offline
                                          notareal
                                          [attachment=0:12mbvobp]<!-- ia0 -->Pencil for Loft - Daniel S - linear.gif<!-- ia0 -->[/attachment:12mbvobp]
                                          You cannot stop amaze! This already is a true gem. Wonder to what it will grow...
                                            Daniel S
                                            I just see:
                                            404 Not Found
                                            And made me wonder... would be possible something like this?
                                            Daniel S
                                            • 11
                                            • 12
                                            • 65
                                            • 66
                                            • 10 / 66
