    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      tak2hata
      Thanks Mario and Oxer. 😆
      I change "#" in line(638 and 1309).
      now, version is 1.4d.
      I wish this work on mac very well.
      @oxer said:
      There is a problem yet, all performances of Crowd work but when you select a component for crowd the plugin create a noname group on surface but isn't a group with your component selected, it's a group of triangles, i don't know why.
      I hope that tak2hata help us for resolve this problem.
      Bye!
      I will examine the part again.
      Please wait.(few days)
      Thanks a lot.
      by TAK2HATA
        tak2hata
        @jeabdc said:
        I don't understand about "assign_material"&"get_from_material".
        Thank Jeab from Thailand 😄
        Hi jeabdc.
        Now, "assign_material"&"get_from_material" do not work.
        It assign the parameters of fur to current material.
        If exporter plugin include the function of make fur,It will perform.
        Thanks.
        by TAK2HATA
        • pyrolunaP Offline
          pyroluna
          is there any difference between 1.4b and 1.4d(c?) if I'm on a windows machine?
          • mariochaM Offline
            mariocha
            Feedback on 1.4d.
            Yes! the web dialogs show properly now.
            But ...
            Make crowd stops short at "Calc __ polygons".Screen shot 2010-06-25 at 08.57.26.png
            And for Fur, units have only one choice, Imperial, Input box and web dialog. normal ?
            %(#008000)[Mario C.
              tak2hata
              I update version1.4e.
              Change is only one thing.
              remove from context menu.
              Hi ,Pyroluna.
              Recently changes do not effect windows machine.
              When I will change big thing ,I will increase version number to 1.5 higher.
              @mariocha said:
              Feedback on 1.4d.
              But ...
              Hi ,Mario.
              I will examin that problem.
              Please wait.
              "Units" is only seeing units working with sketchup.
              so it can not change.
              Thanks.
              by TAK2HATA
              • romboutR Offline
                rombout
                finally had a project to test.
                this is my first and only test yet, i did need to manually adjust everything to my desire though.
                But im gonna 'play' with it a lot more!!!!!
                • BurkhardB Offline
                  Burkhard
                  Here is the German file
                  fur_lang_de.txt
                  http://www.ia-plus.de
                    MDM
                    man this plugin is awesome 😍 🎉 🎉 🎉 🎉 🎉 🎉
                    for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🤣 will be available
                    great stuff I love it, and it's so much fun 😄
                    Nothing is impossible :smile:
                    • F Offline
                      frv
                      On a Mac crowd maker still does not work.
                      The dialog now works fine but it does not create any crowd on the selected surface.
                      Hope you can update when you have any time. But don't worry, I am already fine with the current version making crowds with the fur dialog.
                      Francois
                      An idea for crowd maker, it would be nice if we can project a line that guides the crowd into certain directions. For instance at stations crowds tend to walk back and forth following routes. Maybe its possible to click a line, or a curved line and crowdmaker puts the crowd with a specified with along this line.
                      Francois
                        cnsdkliang
                        Very nice plugin. 😎 😆
                        • DareDevilD Offline
                          DareDevil
                          @tak2hata said:
                          Hi,all.
                          I updated this plugin to version1.3i.
                          Webdialog sees easier.(Thanks Diego.)
                          Parameter name translates by langage text file.
                          Thanks.
                          A french translation.
                          Thanks to you all !
                          Edit :
                          The file is now in UTF8 format
                          fur_lang_fr.txt
                            AcesHigh
                            people, you are talking about making grass, but if I try to make a simple rug, with fur, the file will jump in size to some 20-30mb! It will take minutes to import it into another file (like, inside of a house). And render times (to start the render) will soar in VRAY.
                            • jo-keJ Offline
                              jo-ke
                              sorry, but where do I copy the language file and how can I activate it?
                              http://www.zz7.de
                              • BurkhardB Offline
                                Burkhard
                                Just to the Plugins folder. After restart you'll find fur_en in the Menu>Plugins. But opening the browser it is in German.
                                (Wurde allerdings noch nicht überprüft; Gegenvorschläge sind willkommen )
                                • jo-keJ Offline
                                  jo-ke
                                  OK, very easy, it worked.
                                  Danke
                                  http://www.zz7.de
                                    Technohippy
                                    AWESOME... many thanks
                                    http://www.realitybuildingdesign.co.uk
                                      MartinK
                                      Just downloaded this and look forward to trying it out. My respect and admiration for all those who create and make these Rubies available is beyond words...so THANKS TO ALL.
                                        djrique
                                        Paulower
                                        I downloaded this translation Portuguese-BR, but it didn't work. I put it on the sketchup plugin folder like the instructions, how I do? Thx.
                                        • plot-parisP Offline
                                          plot-paris
                                          thats really a great plugin. so much fun to work with... 😄
                                            robert111
                                            plot-paris , very nice modeling , can you make your fur setting thanks
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 32
                                            • 33
                                            • 14 / 33
