    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      aiwkha
      So nice plugins.
        blajnov
        @angor2005 said:
        Please Russian translation.
        Many Thanks to you all !
        fur_lang_ru.txt
          ๐Ÿ‘
          • McGyverM Offline
            McGyver
            Hi. I've been playing around with this and have found some good uses for this plugin. The one thing I'm not getting is, which setting (if any) controls the number of (leafs, blades of grass, etc.) that are generated... I've been trying to get smaller number of "blades per inch" but I'm not really noticing much of a difference. I figured it would be Density(Num/m2) and or MaxNumber(/face)... I went as low as 10 on a 4 ft x 4 ft square and I really can't tell the difference between these set at 200... ๐Ÿ˜•
            Any suggestions or help in this matter is greatly appreciated.
            EDIT- Never mind, I figured it out... I was using sandbox and the faces(grids) were too small... works fine otherwise.
            Visit My ShareCG Freebie Gallery
              tak2hata
              Hi all.
              I update makefur to version1.4c(webdialog test for mac)
              fixing webdialog problem on mac os.
              (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
              I wish this working on mac!
              4 ft x 4ft = 16 ft.sq
              16 * 10(num/m2) = 160.
              16 * 200(num/m2) = 3200.
              If you keeping MaxNumber(/face) as 200,then It makes 200 fur on each faces.
              16 x200 = 3200 changes to 200.
              So you should glow MaxNumber(/face) like 4000.
              Thanks.
              by TAK2HATA
              • mariochaM Offline
                mariocha
                I'm so sorry to have to report the web dialogs still do not work on Mac here. Empty.
                I have other plugins that use them, and they work just fine.
                Web dialog, Fur 1.4c
                %(#008000)[Mario C.
                  jeabdc
                  I don't understand about "assign_material"&"get_from_material".
                  Thank Jeab from Thailand ๐Ÿ˜„
                  • OxerO Offline
                    Oxer
                    Hello mariocha,
                    I work on Mac too, and the web dialogs don't appear but i find a solution for resolve this problem, edit "fur_en.rb" (with TextWrangler for example) and delete this sign "#" in the lines 638 and 1609, now the web dialogs will work.
                    There is a problem yet, all performances of Crowd work but when you select a component for crowd the plugin create a noname group on surface but isn't a group with your component selected, it's a group of triangles, i don't know why.
                    I hope that tak2hata help us for resolve this problem.
                    Bye!
                      tak2hata
                      Thanks Mario and Oxer. ๐Ÿ˜†
                      I change "#" in line(638 and 1309).
                      now, version is 1.4d.
                      I wish this work on mac very well.
                      Bye!
                      I will examine the part again.
                      Please wait.(few days)
                      Thanks a lot.
                      by TAK2HATA
                        tak2hata
                        Hi jeabdc.
                        Now, "assign_material"&"get_from_material" do not work.
                        It assign the parameters of fur to current material.
                        If exporter plugin include the function of make fur,It will perform.
                        Thanks.
                        by TAK2HATA
                        • pyrolunaP Offline
                          pyroluna
                          is there any difference between 1.4b and 1.4d(c?) if I'm on a windows machine?
                          • mariochaM Offline
                            mariocha
                            Feedback on 1.4d.
                            Yes! the web dialogs show properly now.
                            But ...
                            Make crowd stops short at "Calc __ polygons".Screen shot 2010-06-25 at 08.57.26.png
                            And for Fur, units have only one choice, Imperial, Input box and web dialog. normal ?
                            %(#008000)[Mario C.
                              tak2hata
                              I update version1.4e.
                              Change is only one thing.
                              remove from context menu.
                              Hi ,Pyroluna.
                              Recently changes do not effect windows machine.
                              When I will change big thing ,I will increase version number to 1.5 higher.
                              @mariocha said:
                              Feedback on 1.4d.
                              But ...
                              Hi ,Mario.
                              I will examin that problem.
                              Please wait.
                              "Units" is only seeing units working with sketchup.
                              so it can not change.
                              Thanks.
                              by TAK2HATA
                              • romboutR Offline
                                rombout
                                finally had a project to test.
                                this is my first and only test yet, i did need to manually adjust everything to my desire though.
                                But im gonna 'play' with it a lot more!!!!!
                                ๐Ÿ˜Ž
                                • BurkhardB Offline
                                  Burkhard
                                  Here is the German file
                                  fur_lang_de.txt
                                  http://www.ia-plus.de
                                    MDM
                                    man this plugin is awesome ๐Ÿ˜ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
                                    for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower ๐Ÿคฃ will be available
                                    great stuff I love it, and it's so much fun ๐Ÿ˜„
                                    Nothing is impossible :smile:
                                    • F Offline
                                      frv
                                      On a Mac crowd maker still does not work.
                                      The dialog now works fine but it does not create any crowd on the selected surface.
                                      Hope you can update when you have any time. But don't worry, I am already fine with the current version making crowds with the fur dialog.
                                      Francois
                                      An idea for crowd maker, it would be nice if we can project a line that guides the crowd into certain directions. For instance at stations crowds tend to walk back and forth following routes. Maybe its possible to click a line, or a curved line and crowdmaker puts the crowd with a specified with along this line.
                                      Francois
                                        cnsdkliang
                                        Very nice plugin. ๐Ÿ˜Ž ๐Ÿ˜†
                                        • DareDevilD Offline
                                          DareDevil
                                          @tak2hata said:
                                          Hi,all.
                                          I updated this plugin to version1.3i.
                                          Webdialog sees easier.(Thanks Diego.)
                                          Parameter name translates by langage text file.
                                          Thanks.
                                          A french translation.
                                          Thanks to you all !
                                          Edit :
                                          The file is now in UTF8 format
                                          fur_lang_fr.txt
                                            AcesHigh
                                            people, you are talking about making grass, but if I try to make a simple rug, with fur, the file will jump in size to some 20-30mb! It will take minutes to import it into another file (like, inside of a house). And render times (to start the render) will soar in VRAY.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 32
                                            • 33
                                            • 17 / 33
