    1.3k Posts 299 Posters 2.5m Views 297 Watching
      Karl Hauser
      You are a "genius"*** - quite wonderful work - you MUST make a tutorial immediately !!!
      ***Compared to Fredo that's better than good!
      • EscapeArtistE Offline
        EscapeArtist
        • 1 for the tutorial request.
        Wow. That is some delicate looking work. I never would've thought to use this curviloft for something like that.
          • mitcorbM Offline
            mitcorb
            To Fredo6 and testers:
            Excellent!
            • charly2008C Offline
              charly2008
              thanks for your nice comments. I'm going next week to prepare a small tutorial. The workflow is very simple.
              Charly
                Pherim
                Absolutely great plugin! But it only worked for me after I deleted this plugin: http://www.cerebralmeltdown.com/projects/sunplugin/
                This is not very bad as I never used it but I was still surprised about this. Maybe you can find out why this happened. At first, whenever I wanted to use your plugin, Sketchup immediately crashed without any error message whatsoever. Now it works fine, thoug.
                • fredo6F Offline
                  This plugin is an example of what should never be done. It replaces methods or add methods to basic Ruby classes String, Float (replaces the Round method) and Numeric. Whatever is the intention, it may end up with conflicts with other plugins, because every script shares the same Ruby environment.
                  This said, I have no clue why it does make Curviloft crash, because apart from the above, the script is well encapsulated in its own module.
                    hm... that is a concern. we should contact the developers.
                      charly2008
                      here some variations of rings
                        d12dozr
                        Master programmer + master artisan = 😮 😍
                        Wow, fantastic work Fredo and Charly...tutorial please, Charly?
                        http://goo.gl/f7ooYh
                          d12dozr
                          Excellent Charly, these works really deserve a thread all of their own in the Gallery.
                            grim
                            fredo and charly
                            this tool is fantastic, however after reviewing the examples posted by charly i was eager to try them out for myself but when it came time to try step 3 if found that the curviloft menue did not display the same information nor did the black backround profile menu appear i have sinced removed all rubies and reloaded only the latest from you posting to see if i had installed it incorrectly however i get the same responce
                            can you enlighten me as to the problem or is there somthing i am over looking
                            thanks
                              Jim
                              I have moved the Curviloft tutorial to the Tutorials Forum - it will hopefully keep both topics more readable.
                              http://forums.sketchucation.com/viewtopic.php?f=18&t=29374
                              • halroachH Offline
                                halroach
                                As all of your wonderful plugins!
                                Very nice fredo!
                                FlexTools - Super Quick Windows, Doors, Slats...
                                  dolphus
                                  Fredo I am a big fan of your work, i hang my head in shame and confess that i cannot get the Curvilot to work when i start uo SU i get the following message " Module Curviloft requires LibFredo6 version greater than 35. Current version is 34" but i do have Version 35 in the plugin dir as well as 34 if i remove the 34 many of my other Fredo plugins work is it possible for anyone to diagnose my problem?
                                  Thanks in anticipation
                                  • fredo6F Offline
                                    @grim said:
                                    fredo and charly
                                    thanks
                                    Maybe you just need to click on a junction to get the floating palette appear, if it is your problem.
                                    • fredo6F Offline
                                      Check out if you have a subfolder named LIBFREDO6_Dir_35 in the Plugins directory. Normally, the script automatically select the latest version of LibFredo6
                                        grim
                                        fredo
                                        thanks for the pointers, they work... there seems to be a lot more to using this tool than i realise, i am getting the hang of it slowly
                                          dolphus
                                          Thank you for the quick reply, I thought i had put the folder in i have now and it works
                                          Thank you very much
                                          • fredo6F Offline
                                            @daniel s said:
                                            Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
                                            Daniel S
                                            I missed this one.
                                            Here is the result, with Loft by Spline
                                            Pencil for loft.skp
                                            • 65
                                            • 66
                                            • 7 / 66
