    1.3k Posts 299 Posters 2.9m Views 297 Watching
      rachmatrf
      Could you open the Ruby console and check if there are some errors reported there.
      The situation is rather strange however.
      I would suggest you try with the other tools to see if you have something similar. All tools share a large part of the selection processing code, and this would help me to better figure out where this could come from.
      Hi Fredo,
      At the first, I was thinking that there's something wrong with the copy I got, so I downloaded a fresh new copy and replaced the old one in the plugins directory. But the problem still remains.
      As you suggest, I just checked the ruby console and found no error there. I already tried other tools as well, and the selection's just fine. Here I attach the selection using RoundCorner tool (which is another awesome work of yours). I found no problem using this tool. Is it because I am using SU7?
      Thank you so much.
      Best Regards...
      blank ruby console
      • charly2008C Offline
        charly2008
        A SCF crown for all the excellent Ruby programmers. Curviloft opens up new design possibilities.
        • fredo6F Offline
          Charly,
          You are rather a magician. I had no idea that the plugin could generate all this marvelous shapes. So I guess that on top of the technical capability of curviloft you have added a lot of artistic sense. 👍
            charly2008
            Hi Fredo,
            Your words make me a little bit proud. That motivates me very much to continue. I am only the craftsmen who tries to find some practical applications for this tool. But i'm Sure also other members will present their ideas in the forum. Below another Example.
              Karl Hauser
              You are a "genius"*** - quite wonderful work - you MUST make a tutorial immediately !!!
              ***Compared to Fredo that's better than good!
              • EscapeArtistE Offline
                EscapeArtist
                • 1 for the tutorial request.
                Wow. That is some delicate looking work. I never would've thought to use this curviloft for something like that.
                  • mitcorbM Offline
                    mitcorb
                    To Fredo6 and testers:
                    Excellent!
                      charly2008
                      thanks for your nice comments. I'm going next week to prepare a small tutorial. The workflow is very simple.
                      Charly
                        Pherim
                        Absolutely great plugin! But it only worked for me after I deleted this plugin: http://www.cerebralmeltdown.com/projects/sunplugin/
                        This is not very bad as I never used it but I was still surprised about this. Maybe you can find out why this happened. At first, whenever I wanted to use your plugin, Sketchup immediately crashed without any error message whatsoever. Now it works fine, thoug.
                        • fredo6F Offline
                          This plugin is an example of what should never be done. It replaces methods or add methods to basic Ruby classes String, Float (replaces the Round method) and Numeric. Whatever is the intention, it may end up with conflicts with other plugins, because every script shares the same Ruby environment.
                          This said, I have no clue why it does make Curviloft crash, because apart from the above, the script is well encapsulated in its own module.
                            hm... that is a concern. we should contact the developers.
                              charly2008
                              here some variations of rings
                                d12dozr
                                Master programmer + master artisan = 😮 😍
                                Wow, fantastic work Fredo and Charly...tutorial please, Charly?
                                http://goo.gl/f7ooYh
                                  d12dozr
                                  Excellent Charly, these works really deserve a thread all of their own in the Gallery.
                                    grim
                                    fredo and charly
                                    this tool is fantastic, however after reviewing the examples posted by charly i was eager to try them out for myself but when it came time to try step 3 if found that the curviloft menue did not display the same information nor did the black backround profile menu appear i have sinced removed all rubies and reloaded only the latest from you posting to see if i had installed it incorrectly however i get the same responce
                                    can you enlighten me as to the problem or is there somthing i am over looking
                                    thanks
                                      Jim
                                      I have moved the Curviloft tutorial to the Tutorials Forum - it will hopefully keep both topics more readable.
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      • halroachH Offline
                                        halroach
                                        As all of your wonderful plugins!
                                        Very nice fredo!
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                          dolphus
                                          Fredo I am a big fan of your work, i hang my head in shame and confess that i cannot get the Curvilot to work when i start uo SU i get the following message " Module Curviloft requires LibFredo6 version greater than 35. Current version is 34" but i do have Version 35 in the plugin dir as well as 34 if i remove the 34 many of my other Fredo plugins work is it possible for anyone to diagnose my problem?
                                          Thanks in anticipation
                                          • fredo6F Offline
                                            @grim said:
                                            fredo and charly
                                            thanks
                                            Maybe you just need to click on a junction to get the floating palette appear, if it is your problem.
                                            • 11
                                            • 65
                                            • 66
                                            • 9 / 66
