    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 271.7k Views 135 Watching
      You can also think this way; in the physical world everything has some thickness (even a sheet of paper). Now there are two kinds of 3D modellers; "solid" modellers and "surface" modellers (like SketchUp) where everything is made up of faces (and their bounding edges).
      Now a front face should always look "outward" of a (fake) "solid" while the back face should be oriented inwards thus indicating that in that direction there is just the "thickness" of the object.
      As said above, some 3rd party rendering software do not like back faces but neither do some other applications - for instance if you want to 3D print something, these back faces will drive some printers crazy.
      In SU itself it is really not too important nowadays. I still remember however that even Google Earth did not like back faces and rendered only black colours where they were exposed (this has been solved by more modern exporters ever since).
        It gets even more important when you start sending models through a render engines - many features there demand that your normals are oriented correctly.
          SketchUpNoobie
          @broomstick said:
          @thomthom said:
          A more recent Duh I had:
          Being able to select only a few edges from a face and offset them instead of the whole face.
          I had this one today!!
          Wow. I didn't know that! I thought you had to offset the whole thing then erase unwanted lines and draw wanted lines. Duh! ๐Ÿ˜ณ
          SketchUpNoobie: the complete noob in all things SketchUp.
            SketchUpNoobie
            @xrok1 said:
            the duh moment that turned out to just be a der! moment. ๐Ÿคฃ
            but seriously you can copy your construction lines with (ctrl) copy, and then say *10 or whatever so you get 10 equally spaced. if that helps?
            Duh! Wow again! I have such a hard time dividing stuff like 7 3/16" into 3 equal sections. This helps a lot! Thanks!
            • TIGT Online
              Move+ctrl to copy + typed 'dimension' + <enter> moves the copy by that 'dimension'.
              Immediately typing 10x [or 10* or x10 or *10 !] will copy 10 times, at that dimension each time.
              Alternatively immediately typing /10 will take the 'dimension' as the total distance and make 10 copies that are fitted into the distance, dividing the 'dimension' into 10 equal parts - as you say great if you want to subdivide 7 3/16" into 3 parts without worrying about the Math.
                SketchUpNoobie
                @ecuadorian said:
                Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
                Wow! Just tried it with your avatar and it works!!! ๐Ÿ˜„
                  I had and odd duh moment for that - because I just did it one time, and I surprised myself afterwards when I realised it worked. I assumed it didn't - so I have no idea why I even tried.
                    But the inverse don't work ๐Ÿ˜ž ๐Ÿ˜‰
                      KXI System
                      just figured out how to adjust a textured face.
                      Right click โžก texture
                      on textured face. Actually I knew about it but just forgot.
                      Getting the perfect sig is hard...
                      Google it!
                        SketchUpNoobie
                        @arklandesign said:
                        hehe .....This is a funny and informative thread at the same time...
                        I have one... discovered by mistake yesterday.
                        If one is in a complicated model and want to focus attention to a particular part of the model, one can double click on the scroll wheel at the point one is interested in and that will centre that point in the middle of the screen....making orbiting even easier.
                        Haha! Thanks! Funny how stupid some people are. Surely not me though! ๐Ÿ˜ณ
                          danbig
                          here's one:
                          what's the difference between the "soften" and "hide" commands for lines?
                            Left is Hidden, right is softened...
                            and SHIFT+ = Hide
                            and CTRL+ = Soften
                              danbig
                              Other than appearance, is there a difference in how the two behave?
                              (I'm slow to Doh! on this one ๐Ÿ˜•)
                                In this example the cylinder with the HIDDEN lines, it's faces are still individually manipulated. Where as SOFTENED results one continuous face. SU playing games with the mind
                                To create the cylinder without softened edges, just draw a circle, then right click it and Explode Curve followed by . Now you can hide edges and see for yourself!
                                  danbig
                                  Hmm. Strange. I'm able to create hidden and soft lines (I use hidden lines regularly).
                                  But if I create two cylinders, just as you have, the hidden line version behaves exactly the same as the soft lines version (sketchup displays the sides as one big face, unless I display "hidden lines" then I can select each face individually).
                                  Also, my hidden line cylinder looks identical to the soft line cylinder.
                                  Can anyone comment on the intent behind creating these two different line styles? What is the "suggested" or intended use for each?
                                    Hi DanBIG,
                                    Draw two circles and the right click as mentioned above to 'Explode Curve'
                                    Now both circles, because we have returned the circle to individual segments, instead of one polyline, SU creates a cylinder with individual faces...
                                    Hiding these faces do not merge the faces into one another again, it just hides the Edges(Vertices). Thus still enabling you to manipulate each face...
                                    SU, when it creates CURVES(POLYLINES), allows you to simulate smoothness. As SU natively uses only straight lines to create any curve, having the ability to simulate smoothness/roundness is necessary. When you select View>Hidden Geometry you are effectively asking SU to show both HIDDEN and SOFTENED lines.
                                    To answer your question, which looks nicer?
                                    • mitcorbM Offline
                                      mitcorb
                                      following up
                                      doesn't it also affect how textures or materials are applied?
                                        Regarding textures; it does not really control how they are applied but how you can apply them. I.e. you cannot manipulate texture mapping (positioning, projection etc) on curved surfaces only on singular face(t)s. In order to access these on curved surfaces and be able to do anything, you need to show hidden geometry first.
                                          I have never noticed this...
                                          ๐Ÿ˜ฒ
                                          And we have a "search this topic" box as well!
                                          ๐Ÿ˜ฎ
                                          And I am an admin here for about three years now?
                                          ๐Ÿ˜’ ๐Ÿ˜ณ ๐Ÿ˜•
                                          • mitcorbM Offline
                                            mitcorb
                                            @Gaieus:
                                            No one is immune. ๐Ÿ˜‰
                                            I will probably be next.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
