    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
      danbig
      here's one:
      what's the difference between the "soften" and "hide" commands for lines?
        Left is Hidden, right is softened...
        and SHIFT+ = Hide
        and CTRL+ = Soften
          danbig
          Other than appearance, is there a difference in how the two behave?
          (I'm slow to Doh! on this one ๐Ÿ˜•)
            In this example the cylinder with the HIDDEN lines, it's faces are still individually manipulated. Where as SOFTENED results one continuous face. SU playing games with the mind
            To create the cylinder without softened edges, just draw a circle, then right click it and Explode Curve followed by . Now you can hide edges and see for yourself!
              danbig
              Hmm. Strange. I'm able to create hidden and soft lines (I use hidden lines regularly).
              But if I create two cylinders, just as you have, the hidden line version behaves exactly the same as the soft lines version (sketchup displays the sides as one big face, unless I display "hidden lines" then I can select each face individually).
              Also, my hidden line cylinder looks identical to the soft line cylinder.
              Can anyone comment on the intent behind creating these two different line styles? What is the "suggested" or intended use for each?
                Hi DanBIG,
                Draw two circles and the right click as mentioned above to 'Explode Curve'
                Now both circles, because we have returned the circle to individual segments, instead of one polyline, SU creates a cylinder with individual faces...
                Hiding these faces do not merge the faces into one another again, it just hides the Edges(Vertices). Thus still enabling you to manipulate each face...
                SU, when it creates CURVES(POLYLINES), allows you to simulate smoothness. As SU natively uses only straight lines to create any curve, having the ability to simulate smoothness/roundness is necessary. When you select View>Hidden Geometry you are effectively asking SU to show both HIDDEN and SOFTENED lines.
                To answer your question, which looks nicer?
                • mitcorbM
                  mitcorb
                  following up
                  doesn't it also affect how textures or materials are applied?
                  • GaieusG
                    Regarding textures; it does not really control how they are applied but how you can apply them. I.e. you cannot manipulate texture mapping (positioning, projection etc) on curved surfaces only on singular face(t)s. In order to access these on curved surfaces and be able to do anything, you need to show hidden geometry first.
                    • GaieusG
                      I have never noticed this...
                      ๐Ÿ˜ฒ
                      And we have a "search this topic" box as well!
                      ๐Ÿ˜ฎ
                      And I am an admin here for about three years now?
                      ๐Ÿ˜’ ๐Ÿ˜ณ ๐Ÿ˜•
                      • mitcorbM
                        mitcorb
                        @Gaieus:
                        No one is immune. ๐Ÿ˜‰
                        I will probably be next.
                          ๐Ÿ˜†
                            Administrator is at first level
                            Moderators second level
                            Surfers users are in the hold ๐Ÿ˜„
                            Mine Doh of the day ๐Ÿ˜’
                            One research realised then the second one ... ๐Ÿ˜ณ
                            • genma saotomeG
                              genma saotome
                              @danbig said:
                              @xrok1 said:
                              i think the biggest duh moment of all that everbody (hopfully) goes through is realizing that it matters which way the faces are oriented.
                              90% of the 3dwarehouse posters still havn't had that duh moment. ๐Ÿ˜†
                              ...ok, I'd better ask, because my mind is blank after reading this.
                              What do you mean, "it matters which way the faces are oriented"?
                              This is either something I know, in different terms, or something I don't know at all.
                              If you export SU models to other software that undestands cad models the "light colored" face is regarded as the surface normal -- an odd phase in itself -- but what that means is that face will change it's appearance per the intensity of the light plus angle of the surface normal relative to the light source whereas the reverse face -- the "dark one" -- does nothing. IOW, any kind of add'l rendering depends upon setting face orientation correctly.
                                arklandesign
                                I hardly ever mess with the axes settings, but have finally had a need to start using this and often found I would inadvertently set the blue axes downwards rather than up.
                                Was watching a tutorial this morning, and found that if one triple clicks (after setting the red axis) it is automatically done correctly for you..... It was a Duhh !!! moment for me.
                                  When you use the Rectangle tool and make the first click on an edge that is connected to a face, the rectangle tool will align to the edge. ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜ณ
                                    When you have a very long list of Plugins under Menu Plugins ๐Ÿ˜’
                                    Just press a letter on the keyboard and you can see every plugs begining by this letter ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜ณ ๐Ÿ’š
                                    Damned how many time I have losted with this ๐Ÿ˜ณ
                                    Of course you must know the name of the plugin that you want use ๐Ÿ’š
                                    @Thomthom
                                    Yes but...Inference don't works or maybe you have a trick? ๐Ÿ˜„
                                    Of course I can move the segment atfer drawn the rectangle
                                    (maybe the best) but with only the rectangle tool? ๐Ÿ˜„
                                    • P
                                      penumbradesign
                                      my duh! moment, toggling control while erasing to hide edges rather than erasing them!
                                        Eraser+Ctrl 'softens' edges.
                                        Eraser+Shift 'hides' edges.
                                        Eraser+Ctrl+Shift unsoftens edges.
                                        To 'unhide' edges you have to use Entity Info or right-click context-menu 'unhide'... ๐Ÿค“
                                        • ToboboT
                                          Tobobo
                                          Eraser+Ctrl+Shift also unhides edges (I think)
                                          Toby
                                          Philippians 4:13
                                            It un-smooths - but doesn't unhide.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
