    If Toolbar is true make it false
    54 Posts 4 Posters 6.1k Views 4 Watching
      UI.start_timer
      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#start_timer
      Note that you can only use whole seconds with the timer.
        simonstaton
        excellent, works like a dream thanks dude. I can now finally say SOLVED
        now I know this isnt related to my initial question however you guys know your stuff and I dont want to go making yet another topic. is there anyway to set a variable in ruby like you can in javascript.
        in my toolbar I have two tools that rely on each other, a compress tool and a checkout tool before you checkout you need to compress.
        is there anyway that only my tools even I can have it so that when you click compress it sets a variable like:
        compress = true
        and my default have compress = false then on my checkout tool have:
        if (compress = true){
        event
        else {
        alert
          Use
          if compress {...
          or
          if compress == true {...
          to test if compress IS true
          BUT NOT
          if compress = true {...
          Which will set compress to true and therefore always return true ?
          = sets a variable to a value
          == compares two values
            Assuming you have wrapped your code in a module, use an instance variable: @compressed.
            http://www.techotopia.com/index.php/Understanding_Ruby_Variables
            http://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Variables_and_Constants
              simonstaton
              I seem to be getting errors am I doing this right:
              @compress = "no"
              # EXPLODE TOOL
                   model=Sketchup.active_model
                   cmd = UI;;Command.new("Explode"){
               result = UI.messagebox "This will Compress your Climbing Frame meaning you cannot edit past this point!\n\n Would you like to continue?\n\nNote; Only Do This Once Per Model", MB_YESNO
               if result == 6 # Yes
                 model.entities.to_a.each{|e|e.explode if e.class==Sketchup;;Group or e.class==Sketchup;;ComponentInstance}
                 Morisdov.att_get
                 @compress = "yes"
                   cmd.small_icon = "finished.png"
                   cmd.large_icon = "finished.png"
                   cmd.tooltip = "Compress | Compress your Climbing Frame"
                   cmd.status_bar_text = "Compressing your Climbing Frame"
                   cmd.menu_text = "Compress"
                   toolbar = toolbar.add_item cmd
                   toolbar.show
              # VIEW CART
              	 if compress == "yes" {Morisdov.att_get}
              	 if compress == "no" {UI.messagebox("Before Viewing Your Cart Make Sure You Have Compressed Your Climbing Frame\n\nNote; You Only Need to Compress Once")}
                   cmd.small_icon = "check.png"
                   cmd.large_icon = "check.png"
                   cmd.tooltip = "View Cart | View a List of Items Used"
                   cmd.status_bar_text = "Loading Cart"
                   cmd.menu_text = "View Cart"
                   toolbar.show
              Thanks for the help by the way guys, much appreciated
                At some point you refer to compress when it should always be @compress πŸ˜’
                  And you are better of using true and false instead of strings "yes", "no" - strings are very slow. and "yes" and "no" both evaluates to true.
                  If you get errors then please post them. They help pinpoint specifically what is going on. "some error" is to vague to make any good guess.
                    simonstaton
                    I still seem to be getting this error:
                    C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;309; syntax error
                    	 if @compress == "yes" {Morisdov.att_get}
                    C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;310; syntax error
                    	 if @compress == "no" {UI.messagebox("Before Viewing Your Cart Make Sure You Have Compressed Your Climbing Frame\n\nNote; You Only Need to Compress Once")}
                    C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;310; syntax errorError Loading File LoadToolbar.rb
                      You're thinking Jsvascript. Your If Else syntax is wrong.
                      http://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Control_Structures
                        Try
                        if test; action; end
                        OR
                        action if test
                        or
                        if test
                           action
                        elsif another_test
                           another_action
                        else ### anything else !
                           yet_another_action
                          simonstaton
                          haha excellent guys, it works thanks the all the help!
                            simonstaton
                            @thomthom said:
                            UI.toolbar_names
                            http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
                            The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
                            > UI.toolbar_names ["Standard", "Principle", "Camera", "Drawing", "Edit", "Construction", "Walk", "DisplayMode", "StandardViews", "Section", "Google", "GettingStarted", "VCB"]
                            I dont suppose you know what the toolbar name would be for the large toolset do you?
                            Thanks,
                            Simon
                              simonstaton
                              I see, no worries hope they fix it soon. Thanks
                              • Dan RathbunD
                                Dan Rathbun
                                Updated my previous post, to give send_action integers, and info on the DC ruby toolbar.
                                I'm not here much anymore.
                                • Dan RathbunD
                                  Dan Rathbun
                                  It does NOT have a string identifer that works with UI.toolbar_names or UI.set_toolbar_visible, etc.
                                  This is a bug in the API; we have asked that it be fixed.
                                  Misspelled argument: 'Principle' for the Principal toolbar.
                                  The missing arguments: %(#000000)[**identifier]%(#F0F0F0)[____]%(#000000)[tb_ID]%(#F0F0F0)[_]%(#000000)[send_action int "LargeToolSet"]%(#F0F0F0)[_]%(#000000)[(211)]%(#F0F0F0)[__]%(#000000)[23056 "Layers"]%(#F0F0F0)[_______]%(#000000)[(220)]%(#F0F0F0)[__]%(#000000)[21132 "Shadows"]%(#F0F0F0)[______]%(#000000)[(103)]%(#F0F0F0)[__]%(#000000)[10546**]
                                  NOTE: %(#000000)[**"Dynamic Components"]%(#F0F0F0)[_]%(#000000)[(59648)]** is a ruby toolbar (not a native toolbar.)
                                  You must use UI.toolbar('Dynamic Components') with the .visible?, .restore, .hide and .show methods.
                                  • 3 / 3
