    If Toolbar is true make it false
    54 Posts 4 Posters 6.1k Views 4 Watching
      simonstaton
      it is so that the user can see only my toolbar which is explained when they download, what is so bloody confusing is that when I put the event:
      UI.set_toolbar_visible("GettingStarted", false)
      inside of a toolbars tool event it works fine and hides it however when I put it lose inside the .rb file nothing happens!
      this is driving me crazy I might just leave it as they have to click a button on my toolbar to hide it.
      Simon
        Maybe the toolbars aren't accessible when the .rb loads... ?
        Timed delay?
          simonstaton
          I think you are right! if its working from the ruby console and its working on the toolbar and its not working on load it must be because the toolbar is false until it has loaded.
          anyway to add a delay onto the .rb file and have it only run once sketchup is fully loaded?
            UI.start_timer
            http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#start_timer
            Note that you can only use whole seconds with the timer.
              simonstaton
              excellent, works like a dream thanks dude. I can now finally say SOLVED
              now I know this isnt related to my initial question however you guys know your stuff and I dont want to go making yet another topic. is there anyway to set a variable in ruby like you can in javascript.
              in my toolbar I have two tools that rely on each other, a compress tool and a checkout tool before you checkout you need to compress.
              is there anyway that only my tools even I can have it so that when you click compress it sets a variable like:
              compress = true
              and my default have compress = false then on my checkout tool have:
              if (compress = true){
              event
              else {
              alert
                Use
                if compress {...
                or
                if compress == true {...
                to test if compress IS true
                BUT NOT
                if compress = true {...
                Which will set compress to true and therefore always return true ?
                = sets a variable to a value
                == compares two values
                  Assuming you have wrapped your code in a module, use an instance variable: @compressed.
                  http://www.techotopia.com/index.php/Understanding_Ruby_Variables
                  http://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Variables_and_Constants
                    simonstaton
                    I seem to be getting errors am I doing this right:
                    @compress = "no"
                    # EXPLODE TOOL
                         model=Sketchup.active_model
                         cmd = UI;;Command.new("Explode"){
                     result = UI.messagebox "This will Compress your Climbing Frame meaning you cannot edit past this point!\n\n Would you like to continue?\n\nNote; Only Do This Once Per Model", MB_YESNO
                     if result == 6 # Yes
                       model.entities.to_a.each{|e|e.explode if e.class==Sketchup;;Group or e.class==Sketchup;;ComponentInstance}
                       Morisdov.att_get
                       @compress = "yes"
                         cmd.small_icon = "finished.png"
                         cmd.large_icon = "finished.png"
                         cmd.tooltip = "Compress | Compress your Climbing Frame"
                         cmd.status_bar_text = "Compressing your Climbing Frame"
                         cmd.menu_text = "Compress"
                         toolbar = toolbar.add_item cmd
                         toolbar.show
                    # VIEW CART
                    	 if compress == "yes" {Morisdov.att_get}
                    	 if compress == "no" {UI.messagebox("Before Viewing Your Cart Make Sure You Have Compressed Your Climbing Frame\n\nNote; You Only Need to Compress Once")}
                         cmd.small_icon = "check.png"
                         cmd.large_icon = "check.png"
                         cmd.tooltip = "View Cart | View a List of Items Used"
                         cmd.status_bar_text = "Loading Cart"
                         cmd.menu_text = "View Cart"
                         toolbar.show
                    Thanks for the help by the way guys, much appreciated
                      At some point you refer to compress when it should always be @compress 😒
                        And you are better of using true and false instead of strings "yes", "no" - strings are very slow. and "yes" and "no" both evaluates to true.
                        If you get errors then please post them. They help pinpoint specifically what is going on. "some error" is to vague to make any good guess.
                          simonstaton
                          I still seem to be getting this error:
                          C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;309; syntax error
                          	 if @compress == "yes" {Morisdov.att_get}
                          C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;310; syntax error
                          	 if @compress == "no" {UI.messagebox("Before Viewing Your Cart Make Sure You Have Compressed Your Climbing Frame\n\nNote; You Only Need to Compress Once")}
                          C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;310; syntax errorError Loading File LoadToolbar.rb
                            You're thinking Jsvascript. Your If Else syntax is wrong.
                            http://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Control_Structures
                              Try
                              if test; action; end
                              OR
                              action if test
                              or
                              if test
                                 action
                              elsif another_test
                                 another_action
                              else ### anything else !
                                 yet_another_action
                                simonstaton
                                haha excellent guys, it works thanks the all the help!
                                  simonstaton
                                  @thomthom said:
                                  UI.toolbar_names
                                  http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
                                  The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
                                  > UI.toolbar_names ["Standard", "Principle", "Camera", "Drawing", "Edit", "Construction", "Walk", "DisplayMode", "StandardViews", "Section", "Google", "GettingStarted", "VCB"]
                                  I dont suppose you know what the toolbar name would be for the large toolset do you?
                                  Thanks,
                                  Simon
                                    simonstaton
                                    I see, no worries hope they fix it soon. Thanks
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Updated my previous post, to give send_action integers, and info on the DC ruby toolbar.
                                      I'm not here much anymore.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        It does NOT have a string identifer that works with UI.toolbar_names or UI.set_toolbar_visible, etc.
                                        This is a bug in the API; we have asked that it be fixed.
                                        Misspelled argument: 'Principle' for the Principal toolbar.
                                        The missing arguments: %(#000000)[**identifier]%(#F0F0F0)[____]%(#000000)[tb_ID]%(#F0F0F0)[_]%(#000000)[send_action int "LargeToolSet"]%(#F0F0F0)[_]%(#000000)[(211)]%(#F0F0F0)[__]%(#000000)[23056 "Layers"]%(#F0F0F0)[_______]%(#000000)[(220)]%(#F0F0F0)[__]%(#000000)[21132 "Shadows"]%(#F0F0F0)[______]%(#000000)[(103)]%(#F0F0F0)[__]%(#000000)[10546**]
                                        NOTE: %(#000000)[**"Dynamic Components"]%(#F0F0F0)[_]%(#000000)[(59648)]** is a ruby toolbar (not a native toolbar.)
                                        You must use UI.toolbar('Dynamic Components') with the .visible?, .restore, .hide and .show methods.
                                        • 3 / 3
