    If Toolbar is true make it false
    54 Posts 4 Posters 7.2k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      @simonstaton said:
      to test it out could I simply just add a new .rb file inside of the plugins folder and inside there put:
      status = if UI.toolbar_visible?('GettingStarted')
      > Sketchup.send_action(21992)
      > end
      Yes I put things like this in a rb called "!Defaults.rb"
      The exclamation makes it load before alpha characters because of the position of ! in the ASCII set.
      Also you don't need "status =" if you will not use the status reference.
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        @simonstaton said:
        could there be errors?
        of course there could be!
        πŸ˜†
          simonstaton
          I see so how would I load up a new .rb file to have this in, is it as simple as making a file called hidetool.rb then inside there putting
          !Defaults.rb
          • Dan RathbunD
            Dan Rathbun
            @simonstaton said:
            ..., is it as simple as making a file called hidetool.rb then inside there putting
            No.. name the FILE --> !Defaults.rb
            # defaults for Sketchup Startup
            begin
              # hide the GettingStarted toolbar
              Sketchup.send_action(21992) if UI.toolbar_visible?('GettingStarted')
            P.S. the send action line is all 1 line in the above example.
              simonstaton
              > begin
              > end
              legend that seems to be working however each time I load sketchup it seems to toggle it on and off, so the first time I load it it turns it off then I close and reopen then its turned on.
              • Dan RathbunD
                Dan Rathbun
                Close sketchup.
                Rename Plugins folder -> xPlugins
                make a new Plugins folder
                copy the !Defaults.rb file into the new folder
                Restart Sketchup
                if it works, some other file is causing problems
                if it doesn't work, then it's a ver 6 bug
                (when done restore your folders to before.)
                Your only alternate then would be a Windows System call using Win32API.so
                That requires a knowledge of C language and the MS Windows API.
                  simonstaton
                  Ok, neither of the methods worked I also tried it using v7 and its still not working.
                  it is defiantly doing something as when all the plugins are disabled it will disable the toolbar then on the next reopen the toolbar will open so it just seems to be toggling it :s
                    Why are you trying to turn on/off the user's toolbar in the first place?
                      simonstaton
                      it is so that the user can see only my toolbar which is explained when they download, what is so bloody confusing is that when I put the event:
                      UI.set_toolbar_visible("GettingStarted", false)
                      inside of a toolbars tool event it works fine and hides it however when I put it lose inside the .rb file nothing happens!
                      this is driving me crazy I might just leave it as they have to click a button on my toolbar to hide it.
                      Simon
                        Maybe the toolbars aren't accessible when the .rb loads... ?
                        Timed delay?
                          simonstaton
                          I think you are right! if its working from the ruby console and its working on the toolbar and its not working on load it must be because the toolbar is false until it has loaded.
                          anyway to add a delay onto the .rb file and have it only run once sketchup is fully loaded?
                            UI.start_timer
                            http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#start_timer
                            Note that you can only use whole seconds with the timer.
                              simonstaton
                              excellent, works like a dream thanks dude. I can now finally say SOLVED
                              now I know this isnt related to my initial question however you guys know your stuff and I dont want to go making yet another topic. is there anyway to set a variable in ruby like you can in javascript.
                              in my toolbar I have two tools that rely on each other, a compress tool and a checkout tool before you checkout you need to compress.
                              is there anyway that only my tools even I can have it so that when you click compress it sets a variable like:
                              compress = true
                              and my default have compress = false then on my checkout tool have:
                              if (compress = true){
                              event
                              else {
                              alert
                                Use
                                if compress {...
                                or
                                if compress == true {...
                                to test if compress IS true
                                BUT NOT
                                if compress = true {...
                                Which will set compress to true and therefore always return true ?
                                = sets a variable to a value
                                == compares two values
                                  Assuming you have wrapped your code in a module, use an instance variable: @compressed.
                                  http://www.techotopia.com/index.php/Understanding_Ruby_Variables
                                  http://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Variables_and_Constants
                                    simonstaton
                                    I seem to be getting errors am I doing this right:
                                    @compress = "no"
                                    # EXPLODE TOOL
                                         model=Sketchup.active_model
                                         cmd = UI;;Command.new("Explode"){
                                     result = UI.messagebox "This will Compress your Climbing Frame meaning you cannot edit past this point!\n\n Would you like to continue?\n\nNote; Only Do This Once Per Model", MB_YESNO
                                     if result == 6 # Yes
                                       model.entities.to_a.each{|e|e.explode if e.class==Sketchup;;Group or e.class==Sketchup;;ComponentInstance}
                                       Morisdov.att_get
                                       @compress = "yes"
                                         cmd.small_icon = "finished.png"
                                         cmd.large_icon = "finished.png"
                                         cmd.tooltip = "Compress | Compress your Climbing Frame"
                                         cmd.status_bar_text = "Compressing your Climbing Frame"
                                         cmd.menu_text = "Compress"
                                         toolbar = toolbar.add_item cmd
                                         toolbar.show
                                    # VIEW CART
                                    	 if compress == "yes" {Morisdov.att_get}
                                    	 if compress == "no" {UI.messagebox("Before Viewing Your Cart Make Sure You Have Compressed Your Climbing Frame\n\nNote; You Only Need to Compress Once")}
                                         cmd.small_icon = "check.png"
                                         cmd.large_icon = "check.png"
                                         cmd.tooltip = "View Cart | View a List of Items Used"
                                         cmd.status_bar_text = "Loading Cart"
                                         cmd.menu_text = "View Cart"
                                         toolbar.show
                                    Thanks for the help by the way guys, much appreciated
                                      At some point you refer to compress when it should always be @compress πŸ˜’
                                        And you are better of using true and false instead of strings "yes", "no" - strings are very slow. and "yes" and "no" both evaluates to true.
                                        If you get errors then please post them. They help pinpoint specifically what is going on. "some error" is to vague to make any good guess.
                                          simonstaton
                                          I still seem to be getting this error:
                                          C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;309; syntax error
                                          	 if @compress == "yes" {Morisdov.att_get}
                                          C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;310; syntax error
                                          	 if @compress == "no" {UI.messagebox("Before Viewing Your Cart Make Sure You Have Compressed Your Climbing Frame\n\nNote; You Only Need to Compress Once")}
                                          C;/Users/Simon/Documents/Action Design Your Own v2/Action 3D 3/Plugins/Utilities/Toolbar.rb;310; syntax errorError Loading File LoadToolbar.rb
                                            You're thinking Jsvascript. Your If Else syntax is wrong.
                                            http://en.wikibooks.org/wiki/Ruby_Programming/Syntax/Control_Structures
                                            • 2 / 3
