    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      I thought it was just me? Been playing around in Libfredo Default Parameters trying to see if it's linked to that?
      Have you failed to upload the .rb/rbs?
      There's a _Loader .rb in the CurviLoft folder...i'm afraid to play though πŸ˜•
      oops. I forgot the loader ZLoader__Curviloft.rb (although it is one line code, it is useful). It is now included in the download section of the main post.
      see http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&p=248195#p248195
      • Rich O BrienR Online
        Thanks Fredo, working like a dream...
        πŸ˜‰
          c.plassais
          Thanks Fredo
          a great plugin and a very nice presentation πŸ‘
          Christophe
            SketchMan
            First of all i would like to say Hi to all of you.
            Then i must say to you Fredo. THANKS for this great plugin. You are the man. 😎 Keep up the good work... πŸ‘
            (PS. will send you some money when i can afford it)
            Now i must go and play with this greate new cool stuff.. πŸ˜„
              tue.tue
              Thank you very much Fredo πŸ‘
                Panga
                Thanks Fredo, I'll give you feedback for sure !!
                Regards
                  Ben Ritter
                  Fredo, a most gracious and appreciative "thank you".
                  • cmeedC Offline
                    cmeed
                    this is amazing, thank you very much!
                    when i saw the preview i wondered if this would be able to handle this dilemma.
                    A seat i recently designed needed an end that curved round and formed the back rest. I've just played for 20mins on the beta and i'm struggling. can curviloft help?
                    cheers
                    chris
                    plugin help.skp
                      Daniel S
                      Thank you Fredo!!! 😍 😍 😍
                      The loft tool works very well. All seems very user friendly... and that is very difficult in tools like this ones. The use of your hoverselect tool in the manual selection makes it very simple too.
                      In the release note you say that there are some limitations and unfinished work.
                      Modify vertex matching by selecting a vertex and dragging it to a new position inside the floating palette is a limitation or a unfinished feature?. That would be awesome.
                      And is possible to allow SketchUp remember the last position of the floating palette? In the default position I have to move it always because there I have all the SU tools there.
                      Daniel S
                      PS. CanΒ΄t wait for the other tools πŸŽ‰ πŸŽ‰ Hope that you can realease more beta versions before the "official release".
                      • fredo6F Offline
                        cheers
                        chris
                        I think you need to draw first the rails that give the shape of the junction, making sure that each surface would be closed by 4 or 3 curves. Then you can apply the Skinning function.
                        • fredo6F Offline
                          This is rather an unfinished feature. Actually, this is why you have a preview zone in the floating palette, because editing on the model, with faces hiding vertices may be less convenient.
                          Daniel S
                          Also an unfinished feature
                          The other tools work but may have more issues and unfinished features.
                          • V Offline
                            vidy
                            Hai Fredo, thanks for this pre release ver, im really excited with this capability, thanks againn 😍
                            regards,
                            still so much to learn..
                            • cmeedC Offline
                              cmeed
                              Fredo[/quote]
                              Thanks but i couldn't get the rails working with this. I don't understand it completely yet. i need to wait till the documentation comes out as i seem to find myself with alot of colourful lines with 7,8,9 written on them.
                              But on the up side i worked the path method see pics YES!
                              look at me using colour edge plugin!
                              result!!!!
                              • charly2008C Offline
                                charly2008
                                This is a new milestone. I find this tool opens up new design possibilities. The loft tool works very well and easy to understand. Especially because the geometry of the forms can be calculated in advance. Thanks for this wonderful tool.
                                The last image below is an almost perfect Moebius band. Unfortunately, the last segment is not closed.
                                Moebius.skp
                                  This is already too impressive πŸ‘Š
                                  πŸ˜‰
                                  • fredo6F Offline
                                    Here is the Moebius ribbon with closure
                                    Moebius - curviloft.skp
                                    • H Offline
                                      hgdn
                                      Fredo,
                                      Great impact for SU users in creating 3d models. With yours I am not afraid of creating 3d models from now on..still new!!! Easy and powerful plugins eventhough you give bug warnings but I have not seen any thing so far!!
                                      Genius and generous Fredo πŸ˜„
                                        Ruturaj
                                        Thank you Fredo Sir,
                                        you are great
                                        Many Many Many THANK you.
                                        I'm shocked man 😲
                                        This plugin is very helpful thank you.
                                        😍 πŸ‘ πŸ˜„ πŸ˜‰
                                        Thanks,
                                        RuturaJ
                                          @lapx said:
                                          I've tried it as well. Thanks Fredo for such a wonderful. Can you get it to maintain a sharp edge? I noticed it round the corners. Would be nice to have this as an option if available.
                                          These tools do work very well.... πŸ’š
                                          The form is auto-smoothed ? You can always select the resultant group and right-click > soften, and set sliders to 0 and all edges will un-smooth/un-soften etc...
                                          or view > hidden_geometry toggle to 'on' and use erase+ctrl+shift to un-soften wiped edges [also remember that erase+ctrl softens wiped edges and erase+shift hides wiped edges - but you must select hidden lines to unhide them using entity info, as there is not erase >> unhide equivalent key-combo...]
                                          • massimoM Offline
                                            massimo Moderator
                                            Already a must-have plugin. Thank you Fredo. πŸ‘
                                            • 65
                                            • 66
                                            • 7 / 66
