    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Stu
      Thanks Tak2hata, I boosted it up to 12,000!! and its fine now
      http://www.landesign.com.au
        tomot
        Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
        See my RAND code snippet below.
        if( $type == "Random + " )
            group=entities.add_group
            entities=group.entities
            1.upto($vpanes) do |i|
              x = ($vtile*i)+(i*$space)
              1.upto($hpanes) do |j|
        	    y = ($htile*j)+(j*$space)
        	o = $pt3.offset($hVec, y - $space).offset($vVec, x - $space)
            pt1 = o.offset($hVec, -$htile)
        	pt2 = o.offset($vVec, -$vtile)
        	pt3 = pt1.offset($vVec, -$vtile)
        	#entities.add_cpoint o
        	#entities.add_cpoint pt1
        	#entities.add_cpoint pt2
        	#entities.add_cpoint pt3
            face = entities.add_face o, pt1, pt3, pt2
            face.pushpull -($tthick+rand(20))
        end #if
        cheers!
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
          tak2hata
          Hi,all.
          I update this to version1.4b.
          >       end
          >     end
          > end #if
          cheers!
          Thanks tomot.
          But this plugin created preset file.
          If I add new parameter, compatible with the old one is difficult for me.
          If you want to use random size to component instance, please use crowd(webdialog).
          and change value of "size jitter" as you like.
          Thanks.
          by TAK2HATA
            Mauhaus
            Hi guys,
            I lost my dwg-import option after installing the plugin. Any ideas why this happened?
            /Thomas 😞
              Hi Thomas,
              re you sure you did not upgrade from SketchUp 7.0 to 7.1 (free) lately?
                Mauhaus
                Hi Gaieus
                Thanx for replying 😎
                Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
                /Thomas
                  SuperSized
                  In the spirit of the SA World Cup.... nice plugin
                  • FrederikF Offline
                    Frederik
                    I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
                    You need a seperate plugin...
                    Please check out the DWG/DXF import plugin for SketchUp 7.1 (Free)...
                    Cheers
                    Kim Frederik
                    • H Offline
                      hebeijianke
                      A Chinese translation.
                      Thanks to you all !
                      fur_lang_cn.txt
                        @mauhaus said:
                        Yes, I have been running 7 (7.1.6859) **PRO**for some time now. The dwg-import option disappeared after installing it...
                        That would only be the free version Kim. The pro still has the "native" import option.
                        As you are not supposed to be able to install the free version on top of the pro, there can indeed be some problem.
                        However we are going off-topic here so Thomas, after you see my post here, I will split these posts and move the new topic created this way to the SketchUp Discussions > Bug reports subforum.
                        However you could try to reinstall your SU but really make sure to download the Pro version (again) to install it. Also, for the Mac version there was also a maintenance release after the main release of 7.1. A couple of fixes were made there so best is to go for sure...
                        • F Offline
                          frv
                          TX for the great plugin, I love the idea of the crowedmaker.
                          But under OSX it does not work, the dialog panel is empty for the crowed option.
                          Francois
                          • mariochaM Offline
                            mariocha
                            @frv said:
                            ....., I love the idea of the crowedmaker.
                            Francois
                            Yep, same here. No dialog under MacOX (10.6.3) πŸ˜•
                            %(#008000)[Mario C.
                              Masoncrowell
                              can someone tell me how i do this on a mac?
                              i downloaded the file and updated my version of sketchup. the file only shows up in my downloads and i can't open it with sketchup. i also enabled my plugins menu on sketchup and the only option that shows up is a "cost" option. How do i do this? πŸ˜•
                                tak2hata
                                Francois
                                Hi,Francois and Mario.
                                It is very regrettable.
                                I will examine way for working on mac.
                                This file is compressed by zip.
                                First, You should extract this file with folder.
                                It includes
                                --fur_en.rb
                                --fur_en(folder include icon images)
                                and copy created files to plugins folder.
                                Read here.
                                http://sketchup.google.com/intl/en/download/rubyscripts.html
                                Thanks.
                                by TAK2HATA
                                  ktslambieng
                                  this is this is a new : vietnam translation for fur1.4b
                                  Thanks you for all !
                                  http://farm2.static.flickr.com/1273/4676700265_23fc0faee3_b.jpg
                                  fur_lang_vn14b.txt
                                  • F Offline
                                    frv
                                    TX Tak,
                                    hope you find the time to look into the blanc dialog for crowds.
                                    I love your idea to specialise the furmaker for crowds
                                    Francois
                                      That is due to some oddness in Geom::Transformation.scaling which I mentioned earlier.
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&p=248300#p248300
                                      But tak2hata said later he's swapped to use .scaling(a,a,a) isntead of .scaling(a) - so that should have taken care of it. Unless there is something else that also creates this scenario.
                                      Oli: are you using the latest version?
                                        ❓ what happened to Oli's post..?
                                          michaelhsu
                                          amazing, thanks.
                                          • W Offline
                                            wanchoke
                                            I use this plugin to my model, It's help to improve atmosphere a lot.
                                            Thank you very much. πŸ‘ πŸ‘
                                            http://lh6.ggpht.com/_xQzZkoFEzSQ/TBLHIaL6eII/AAAAAAAACV8/QfktBGuUv2U/s912/House on Haunted Hill 2.jpg
                                            <model link>
                                            http://sketchup.google.com/3dwarehouse/details?mid=5e3202cae2da28223fc4dc5809e00c5c&prevstart=0
                                            • 32
                                            • 33
                                            • 5 / 33
