    1.3k Posts 300 Posters 3.2m Views 298 Watching
    • P
      Panga
      Ok Fredo,
      thanks for trying out ! The sandbox is already a goog tool for terrain, but the post cleaning and the triangulation not already good needs enhencements.
      Regards.
        Fredo,
        Looks really good.
        See attached file - a question for both you Fredo and TIG
        The Demo video shows clicking of 3 or 4 seperate lines.
        Will it be able to skin the attached file - a closed (welded) single polyline ???
        or would it have to be broken up into 3 or 4 seperate polylines first ???
        Maybe one of TIGs Extrude Tools can handle closed polylines like the attached file ???
        This would be really useful and a feature I'd request if this Script doesn't do it already
        (or if TIGs Extrude Tool doesn't already do it).
        Regards
        Howard L'
        The problem with one closed polyline is where do you make the 'corners' - certainly with my EEbyRails tool anyway - perhaps Fredo has a cunning plan... It's easy to make the shape you show with EEbyRails - [and almost certainly with Fredo's newer and chic tool] but you need the 2 profiles and 2 rails. I Exploded the whole polyline [Curve], Selected the pieces of the two Curves and Welded them into a profile and a rail, then Divided the two remaining lines into 12/18 Segments in turn, then Welded those into straight 'Curves' - that way the tool doesn't have to be guessing about how best to divide up uneven pairs of sides: then EEbyRails simply made the form you see, using the four pieces as two profiles and two rails...Capture.PNG
        I'm sure Fredo's tool will be as capable [or better 😒 ]
        • B
          bimbachi
          @diego-rodriguez said:
          Here is the results, in video (quickly done),
          Hello Fredo6,
          fantastic plugin !!!
          and by occasion - what tool are you using to crate those beautiful small gifs videos?
          regards
          • fredo6F
            regards
            I use Camtasia Studio 7 (which has a free one-month trial period).
            • fredo6F
              Regards
              Howard L'
              Howard,
              TIG's EEbyRail can handle it well, if you split the contour into 4 pieces.
              Curviloft will try to manage automatically the split (in particular when you have multiple contours), but this is more tricky and I still have some issues.
              So, for the time being, Curviloft would use the same method as recommended by TIG.
              Note however that Curviloft will accept contours made of curves and / or individual edges
              BoatHull_Half - HL.skp
              • C
                Click Draw
                Wow Fredo6....amazing! Any idea when you will have this plugin ready to post? Thanks in advance, I can't wait!
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                  mathrisk
                  Perfect work , great plugin. I was looking for this for a long time.
                  • H
                    Howard leslie
                    Fredo / TIG,
                    Thanks very much for the replies from both of you.
                    As suspected (for now) closed polylines must be broken up before processing (whichever tool is used) - but its not too painful.
                    Keep up the good work with your EXCELLENT scripts.
                    Hugely appreciated by all.
                    Regards
                    Howard L'
                    • W
                      Woz2007
                      This looks like a very powerful plugin & Im amazed at how fast things are developping. It certainly looks like it will improve the possibilities of more organic modelling.
                      Will this plugin be FREE or a commercial item upon release?
                      Do you have an ETA?
                      Does the created surface act as a normal SU surface allowing you to push pull edit vertices etc?
                      Ive got one eye keenly focused on this development 😄
                      • T
                        tomislavm
                        Perfect work, thanks!
                        • fredo6F
                          Answer is FREE
                          The surface generated are pure SU, as a combination of edges and faces, encpasulated within a group. You can do whatever you like with it with all SU tools.
                          • K
                            kostas_designer
                            Answer is FREE
                            Amazing professional work AND great generosity.
                            You deserve the "SU Knight" gold medal, man!
                            I am speechless.. 😮 😮
                            • W
                              watkins
                              Dear Fredo6,
                              I should like to add my applause and thanks too. Your generosity is greatly welcomed by the community with is Sketchup.
                              With all best wishes,
                              Bob
                                markitekt
                                You Ruby guys never fail to amaze me.
                                Keep up the great work and thanks for your generosity Fredo!
                                Mark P.
                                • arquitectomaracuchoA
                                  arquitectomaracucho
                                  thanks fredo! tools cool! woow, friend you should receive a good salary by Google Sketchup!
                                  • L
                                    lapx
                                    Fredo fantastico 😍
                                    Now we need you in the Gulf!
                                      rickgraham
                                      I will add my kudos to the long list too. It seems to me that 2010 is really shaping up to be the year of awesome plugins.
                                      Wonder, if we should do a top 10 plugins at the end of each year based on comments and downloads? 😄
                                      Rick
                                      • troyhomeT
                                        troyhome
                                        This should be a standard tool for SU!!! way to rock our world!
                                        IOviz.com
                                        SU Pro 2024 PC
                                        • H
                                          haynesc
                                          wasnt SubDivideSmooth getting a makeover ?
                                          • F
                                            ferrosoa
                                            Nice job ... it isnt possible download yet?
                                            • 65
                                            • 66
                                            • 4 / 66
