    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Yes, this is working, thank tak2hata!
      I can make fur again
      (now just exploring all the settings...)
      • JClementsJ Offline
        JClements
        Gaieus: That's Shaga-delic.
          saturne45
          Hello, very great job... make fur is very nice. thank you.
            tald311
            Thank you. This is great.
              Click Draw
              Been playin'....this is very cool! I hope PETA doesn't get wind of this 🤣
              Thanks very much for this!!!
              Jeff
              Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                realist
                Hi, I'm new to Sketchup and about to climb the learning curve.
                I saw the Fur plugin and thought it would be a cool additon to Sketchup. I clicked on the link to download it but all that does is refresh the page. It doesn't download anything. Am I missing something here? Thanks.Gary
                  JollyFather
                  Thanks a lot!!!
                  Best regards,
                  JF
                    paulower
                    Hello Tak2hata.
                    I have spoken these days about the plugin, which is one of the best I've seen so far for our dear SketchUp.
                    Is there a way the dialog can remember it's position on the screen? I always expect it to reopen where I put it the previous time. 😄
                    Any chance this feature soon?
                    Hi,all.
                    I updated this plugin to version1.3i.
                      Webdialog sees easier.(Thanks Diego.)
                      Parameter name translates by langage text file.
                    Thanks.
                    If you wish, I can provide the translation from Portuguese languaje from Make Fur
                    http://i910.photobucket.com/albums/ac301/bausketchup/MakeFUR1.jpg
                    http://i910.photobucket.com/albums/ac301/bausketchup/makefur2.jpg
                    _______________________________
                    My Blog
                    Baú SketchUp
                    Baú SketchUp
                    Visite nosso blog.. Visit our blog Baú SketchUp
                      thiloo
                      thank you so much, I already love this Plugin!
                      some question:
                      • what´s the "Valid Distance" for?
                        if I choose "make by Component: no"
                        and enter something different than 0,000m it´s not working.
                        if I choose "make by Component: yes"
                        it´s working, but seems to have no effect.
                      • Also, if I select "make by Component: yes" the results are looking quite different from when I select no". for example: the force values seem to have stronger impact on component:yes.
                        tak2hata
                        Hi, thiloo.
                        @thiloo said:
                        some question:
                        The Valid Distance is validate fur about distance from camera.
                        So This value is large.like 20m.
                        But 0 make all valid.it do not omits fur.
                        Example.Use valid distance = 8000mm.
                        About Fur_Valid Distance1
                        About Fur_Valid Distance2
                        About Fur_Valid Distance3
                        Hi,paulower.
                        Sorry ,Now I examines the method to remember dialog position.
                        That demands the javascript knowledge from me.
                        I will update few day later.
                        Thanks.
                        by TAK2HATA
                          autarchos
                          Dear Mr. Paulo Wer:
                          That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                          Besten Grüßen,
                          Drazen Petrovic
                            thiloo
                            thanks tak2hata for the quick explanation,
                            wow, that´s also an powerful feature.
                            sadly it´s not working if I choose "make by component - yes"!
                            also, with component activated, the reaction to the force settings are quite unexpected?
                            I need the components for instancing -> rendering.
                            again, Thank You for your time and effort
                              I see the same issue that thiloo describes.
                                Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html
                                http://3.bp.blogspot.com/_mDRU50FpD-E/TAALyG_ckXI/AAAAAAAAAMI/geNk8IzxF7Y/s400/WithFur.png
                                  bryan_gibson79
                                  As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
                                  BG
                                    autarchos
                                    Didier's Hide Faces/Edges plug-in is one method:
                                    http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/hide_faces_edges.rb
                                    BG
                                    • marleusM Offline
                                      marleus
                                      Really cool plugin
                                      thanks a lot 👍 👍
                                      Markus Sillander
                                      Vantaa, Finland
                                      I'm on FormFonts now
                                      http://www.formfonts.com
                                      • N Offline
                                        notareal
                                        It still amaze me what this plugin can do
                                        Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
                                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                          paulower
                                          @autarchos said:
                                          Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                                          Besten Grüßen,
                                          Drazen Petrovic
                                          Yes, sure I can explain:
                                          1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
                                          2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
                                          • Do not forget to apply the texture on both sides, ie, in the back and front face.
                                          **3 -**Create a component for each texture (one for the grass normal and other to grass bush);
                                          **4 -**In the Settings Window FUR, I made the adjustments and settings required, such as:
                                          • TopJitter (%): 1
                                          • Direction (X): 0mm
                                          • Direction (Y): 0mm
                                          • Direction (Z): 500m or 5000m (not mm. That in my example)
                                          • In the menu drop down "Make by Component", choose the component that you created;
                                          5 - Click on Make Fur;
                                          **6 -**I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
                                          I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
                                          File - Map Alpha Mask
                                          File - Map Grass
                                          My Blog
                                          Baú SketchUp
                                          Baú SketchUp
                                            paulower: that's a nice setup. Thanks for sharing.
                                            • 32
                                            • 33
                                            • 5 / 33
