    Sculptris
    69 Posts 23 Posters 20.8k Views 23 Watching
    • charly2008C Offline
      charly2008
      I find this program very intuitive compared to Zbrush. I think this could be my standard program for organic shapes.
      I have tried to bring some of these models with the OBJ importer into Sketchup but it doesn't work for me.
      Than I have converted it to 3ds files and they were imported correctly.
      Vice versa i had the same problem with the import of sketchup OBJ files into Sculptris. I don't know how to solve it.
      Attached the file i want to import into Sculptris. But all in all, this is a promising program.
      Wikinger.skp
        Khai
        Remus kindly made this for me http://forums.sketchucation.com/viewtopic.php?f=323&t=26620 which will check for N-Gons..
        I think we should ask him if he can get it to highlight them. then we can simply fix them ready for export to Sculptris...
          charly2008
          Hi khai,
          I would be very happy if Remus would do this.
          Karl
            remus
            Probably easier to just use this: http://forums.sketchucation.com/viewtopic.php?p=175613#p175613
            My ruby skills are a little rusty as well 😛
              Khai
              uuugh noooooo
              I'll just manually check for the Ngons....
                In case of interest I have translated the Sculptris'Doc in French 😉
                sculptris_help.zip
                  Very interesting find, Pilou, thanks!
                  I have not tried yet but it seems there could be a smooth workflow with SU itself. What do you guys think, should we move the topic to the extensions forum? After all, it seems to be SU related as far as I can tell.
                    It's a mini "Zbrush", so some organic and result has many triangles 😉
                    • EscapeArtistE Offline
                      EscapeArtist
                      Yep, functions quite a bit like zbrush, obviously without the complexity or toolset. I found it easier to use though. Good fun, and it works quite well for what it is.
                        charly2008
                        Hi Remus,
                        I used the triangulate Faces by selection. But the N-Gon Check says there are still N-Gons in the model. What can i do else?
                        Karl
                        Wikinger.zip
                          Khai
                          I think your going to be doing some cleanup there...!
                            charly2008
                            i used the new N-Gone Check. In my Wikinger.skp it counted 12567 N-Gons. I tried to triangulate the model but without success.
                            Karl
                              remus
                              You could always try saving it as a .3ds then importing it back in to SU.
                                charly2008
                                If i try to export the model as 3ds, Sketchup crashes. I don't know why.
                                • pyrolunaP Offline
                                  pyroluna
                                  whohooo supercool!!
                                  I had to try this out at once!
                                  So I did:
                                    As Sculptris can export colors and depth buffer you can make any after effect in your favorite 3D package 😎
                                    By Taron (administrator of Dr Petter'site 😉
                                    http://img99.imageshack.us/img99/3461/sheeple.jpg
                                    http://img189.imageshack.us/img189/2074/muscleape2.jpg
                                    Auto Portrait
                                    http://img69.imageshack.us/img69/9866/taron.jpg
                                    http://img337.imageshack.us/img337/459/butterflies.jpg
                                    http://img441.imageshack.us/img441/3096/foldeye.jpg
                                    • tridemT Offline
                                      tridem
                                      I used Blender as translator... 😳
                                      • jo-keJ Offline
                                        jo-ke
                                        how can I convert the model to 3ds?
                                        sculptris allows only obj and sc1
                                        I tried to import the obj-file with the obj-importer plugin, then su was calculating but nothing appears.
                                        what can I do?
                                        http://www.zz7.de
                                        • jo-keJ Offline
                                          jo-ke
                                          I tried to do that, but the modell doesn't appear in blender.
                                          what importpresets did you use?
                                          "ceate scene"?
                                          http://www.zz7.de
                                          • tridemT Offline
                                            tridem
                                            Be sure there's nothing in Blender...I remember that was totally out of scale and far from axis center and for this reason (?..I believe...) hidden in Blender viewport.
                                            • 1 / 4
