    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 968.2k Views 175 Watching
      Daniel S
      @tig said:
      It's here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      The clue is in the 'note' πŸ˜‰[attachment=2:2pbi3eqh]<!-- ia2 -->Capture.PNG<!-- ia2 -->[/attachment:2pbi3eqh] or there are links in any of my posts announcing an update...[attachment=1:2pbi3eqh]<!-- ia1 -->Capture1.PNG<!-- ia1 -->[/attachment:2pbi3eqh]
      Hi TIG
      Great Idea!!! What about if you click in the image and that makes a direct download of the plugin?
      Something like:
      CLICK on the image for download!!
      [attachment=0:2pbi3eqh]<!-- ia0 -->Screenshot_1.jpg<!-- ia0 -->[/attachment:2pbi3eqh]
      The code I Use:
      [url=http://forums.sketchucation.com/download/file.php?id=48174][attachment=0]Screenshot_1.jpg[/attachment][/url]
      Daniel S
        I'd prefer the users read the post... then download... although I know a lot will scroll past everything anyway but if the image were to link to the download they'd even have no need to do that - you'd be amazed how many PMs we scripters get about problems with installing the files, simply because most new users never read the notes and open a zip file and then drag'n'drop everything into their Plugins folder; when these days a lot of stuff goes into sub-folders to try and keep things a little 'ordered'...
          liangljz
          i am looking for it. thank you
            toldo39
            thnx
              stefx
              Hi TIG,
              the plugin set is amazing!
              I would like to know if there is a chance to create the extrude-edge-by-rails but for faces, something like "extrude faces by rails".
                I didn't make a separate EEby.. tool since you can do it relatively easily with EEbyRails as in this exampleCapture.PNG
                  stefx
                  Thank you TIG.
                  I have tried but:
                  1: i create my face with all the edges welded
                  2. i select the profile as curve
                  3. i select the 2 rails
                  4. i select the melding-prfile curve
                  1. Sketchup crashes!
                  I am thinking to split the face-curve in two parts.
                  Stef.
                    Can you post an example skp ?
                      stefx
                      Here it is!
                      basically it is roof design, you could find the profile of the roof and 2 rails.
                      The two rails don't touch the profile.
                      So I welded the whole profile, I welded the 2 rails but when I try to use the plugin everything crashes!
                      I have tried to split the profile in more parts, and it looks like working.
                      Stef.
                      roof test.skp
                        It can only be done after the model is 'fixed'.
                        The roof profile is not quite coplanar [try to add a face to it - you can't !] so it adds all sorts of additional problems... with geometry flying off into space etc etc...
                        Complex 3D curves will work as Profiles but especially looped ones with slight discrepancies can be problematical !
                        To fix it select the roof profile curve and use EEbyVector on it to make a small temporary roof-bit [ extruded away from the 'rails' but in line with the first edge].
                        Now draw a large vertical rectangle that intersects the whole of this new roof-bit.
                        Select that rectangle and right-click > intersect > with model.
                        Erase the unwanted bits of the rectangle and keep just the faced roof profile.
                        Erase the temporary roof-bit too.
                        You know have a coplanar roof profile.
                        Select the edges of it and weld them into one curve.
                        Move it near to the rails but not touching them, so it doesn't 'split'.
                        Check that the rails have the same number of edges - if not group them draw over them with lines and erase the originals then when they have the same number of edges [select and use entity info] weld each set in turn into a curve.
                        Now you can use EEbyRails...
                        Select the Profile, then the Rails in turn and the Profile again as the melding-profile [in is 'assumed' at the other end of the rails as required].
                        The mesh is made as expected...
                        You need to add 'end-faces' by drawing over an edge at the ends... πŸ€“Capture.PNG
                          stefx
                          Hi TIG, thank you for your tutorial.
                          I guess it is a problem of my Sketchup.
                          This a licensed version that I used at work.
                          I am saying that because i have tried to use a simple rectangle with 2 rails (I draw one and copied as 2 rail just to have the same number of segments and same features).
                          (see attached)
                          After I welded the edge of the rectangle if I try to use the Extrude By Rails sketchup quit the work.
                          I think I have to do the same splitting the edge of the rectangle or roof in different pieces.
                          roof test.skp
                            How do the want the profile to end at the rail-ends ? If it's wanted as 'flat' then you need to copy the profile to the end and rotate it etc. I'd let the rails split the profiles and make two extrusions, then group their groups, edit that group and explode the two into one st of geometry inside this parent-group.
                            If you want to extrude the profile along the rail in the same plane all if the time then try EEbyEdges [group] the two sets of profile and path first...Capture.PNG
                              stefx
                              Hi Tig,
                              thank you for your tutorial......again.....
                              I have followed your indications. I got the results I wondered.
                              We don't need Extrude face by rails as soon we could get the same results in other ways.
                              Thanks again.
                              Stef.
                                rizal21
                                my toolbar for this not show up, please help 😐 , found #extrusionToolbar.rb, but i think it's for menu
                                  The file you found IS needed to make the menu AND toolbar.
                                  You need to activate the toolbar from View > Toolbars > Extrusion Tools πŸ˜•
                                    tiagomedeirosdsg
                                    Obrigado pelo plugin
                                      Thanks for [the] plugin
                                      πŸ‘
                                      • olisheaO Offline
                                        olishea
                                        For some reason, when I install this plugin....my sketchup starts up very quickly. I used to wait 15 seconds or so for all my plugins to load, now it's instant!!
                                        confused!!
                                        having a play with these amazing tools, thank you so much TIG.
                                        are there any videos in the pipeline? I feel they would help a lot.
                                        Also, how do you define a "melding profile"....I mean I know what it does.....is it just the finishing profile? if that makes sense
                                        oli
                                          Oli
                                          There are quite a few [illustrated] pages for each tool in the set - see the many links from the main zipped set download page...
                                          A lot of the tools need two profiles and two rails.
                                          The pick order is:-
                                          A 'profile' - the starting curve form that will 'extrude' down the rails.
                                          B 'rail-1' - the first rail to follow with this extrusion.
                                          C 'rail-2' - the second rail to follow with this extrusion - Note: you can also pick 'rail-1' again as 'rail-2' and it then assumes a copy of 'rail-1' is placed at the other end of the 'profile'.
                                          D 'melding-profile' [it's a fancy name for 'profile-2'!] is what the 'profile' will 'morph' into [meld] as it is repeated down the rails - Note: you can pick 'profile' again as the 'melding-profile' and then the only 'morphing' the profile will undergo is the fitting between the rails etc.The curves need not touch but it can be helpful to visualize the result if they do... the 'mesh' is made 'over' the 'rails'.
                                          Pairs of profiles/rails need NOT have equal curve segment counts... but if they do not and the numbers are not simple multiples then extra vertices are added to adjust the mesh and it might not be what you expected...
                                          πŸ€“
                                            maxel99
                                            excellent ruby tig, truly amazing.
                                            I just had two questions:
                                            *The extrude edges by faces does not appear to work with lines - can you make this work?
                                            A work around for this is to create a line and then break it apart and use the 'weld' ruby to put it back together. BUT is there a simpler way? It'd be great if this just worked for straight lines - or do you know of a similar ruby plugin that does this function?
                                            *second: are there tutorials for these tools? I am struggling to use them and it looks like there are bits and pieces of info on them but they are not in one central location - would it be possible to unify the tutorials for these into a few critical images for each tool like you unified the toolbar?
                                            Would be great, and as I said earlier, great tools as they are (just wish I could use them better with more tutorials!)
                                            • 31
                                            • 32
                                            • 8 / 32
