    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      AcesHigh
      @xrok1 said:
      i knew i should have popped that before it got out of hand! 😲
      who would have ever imagined fur for SU?????????????????????????????
      a very hairy nipple?? πŸ˜„ πŸ˜„
      • E Offline
        ENG. YASEEN
        I Made This By Fur Plugin 😍
        http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
        😎 πŸ‘
        Thx tak2hata
        My Website:
        http://xyz4studio.blogspot.com/
          adityas
          What am I suppose to do after making fun with this tools?
          Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
          Damn good... simple but... (I cant't explain with words).
          • mariochaM Offline
            mariocha
            Hey many, many thanks man ! impressive plugin.
            After all, some still think art is easier on grass πŸ˜†
            %(#008000)[Mario C.
            • RichardR Offline
              Richard
              @pixero said:
              @richard said:
              Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
              Thats not what I was after.
              Sorry mate I understand now! Yes certainly an option to force specs easier than it certainly could be without work! Though that said this is the first we have seen of this plug so who knows, good idea though!!!! πŸ˜„
              [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                tak2hata
                Hi, All.
                I updated make fur plugin version to 1.3a(test version).
                Because I changed the format of the preset, it is not compatible with the one before.
                Please warn you.
                Thanks.
                by TAK2HATA
                • EscapeArtistE Offline
                  EscapeArtist
                  Just keeps getting better!
                    Daniel S
                    Thank you for the update tak2hata!
                    Perhaps in next versions you can put all the options in a submenu? Something like the attachment.
                    Daniel S
                      Why metric and imperial? Why not just deal with the units in the way that the model is?
                        tak2hata
                        Hi,Daniel.
                        I Changed menu items into sub menu named "Fur_v1_3".
                        Hi,Thomas.
                        Because I think it easy to test both imperial and metric.
                        I am not accustomed to the imperial.
                        I will corrects it in future version.
                        Thanks for your advice.
                        by TAK2HATA
                          The Numeric, Float and String class has some nice methods that let you deal with units in the user's locale and in the current model's units.
                            tak2hata
                            Hi, Thomas.
                            Thanks ! I'm searching for that method.
                            by TAK2HATA
                              Basically:
                              Ensure the units you use are Length objects. Length.to_s will output a unit in the user's locale and model settings. This is useful when presenting units in the UI, like for inputboxes etc.
                              Then you have String.to_l, which is useful to convert user input into Length. If a user types "100mm" it then .to_l will convert that into the appropriate Length. (Length is always in SU's internal units: inches)
                              "100m".to_l
                              becomes:
                              3937.00787401575
                              If the user has mm set as the model units, then "100" (without any unit indication) is assumed to be in mm and the result is:
                              "100".to_l 3.93700787401575
                              same thing as if the user had typed "100mm"
                              "100mm".to_l 3.93700787401575
                                portenart.emile
                                Hello every body,
                                I found this plugin today. It look amazing. Ihave made the grass but i don't know why it isn't render in Vray ? I'm sure it's a specific option i have to check but i don't found it.
                                I use Skectchup pro 7.1.6, Vray for sketchup 01.05.30, and Fur Plugin 1.3.
                                I can send you a screenshot or a file if you need.
                                Thanks you for your help πŸ˜„
                                Emile
                                • mariochaM Offline
                                  mariocha
                                  Hum .... Although the title says V1.3b
                                  the download still says v1.3a πŸ˜•
                                  %(#008000)[Mario C.
                                    This is due to a Sketchup bug and groups. The groups will render when you reopen the model.
                                    The latest VfSU does not suffer from this SU bug.
                                      jbrown
                                      Very handy.
                                      Am I missing something in the settings, though? It appears to be growing from the opposite side of the selected face and I can't figure out how to change that. Not too big a deal to select the opposite side from where it needs to go, but maybe there's an easier way?
                                        Hi Justin,
                                        Don't you have back faces where you want to grow the fur? Try to right click > Reverse faces and grow it again.
                                          tak2hata
                                          Hi,all.
                                          I upadte fur plugin v1_3c(test version).
                                          Mario..
                                          Sorry,I made a mistake in writing title. 😲
                                          So Current version up to 1_3c.
                                          Thanks.
                                          by TAK2HATA
                                            portenart.emile
                                            Thanks you so much thomthom, it works.
                                            I'll post you my render once done.
                                            Emile
                                            • 32
                                            • 33
                                            • 5 / 33
