    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.5m Views 343 Watching
      Perhaps look at Grow.rb or ComponentStringer.rb ?
      • F Offline
        fishdiva
        Sheer Genius, Fredo! Love the Radial Bending feature - Google should definitely make this INDISPENSABLE feature official.
        For some reasons FredoScale toolbar does not appear but since right click does the same job this is a minor issue...
        Thank you again for a great piece of work!!
          fishdiva
          The FredoScale plugin is registered as an 'extension' so you need to activate it from Window > Preferences > Extensions + tick FredoScale & OK; and then [probably] open it from View > Toolbars > FredoScale ...
            Well, if
            the plugin must be already activated (or it activates automatically?)
            However you may need to activate the Toolbar itself under View > Toolbars.
              arjunmax09
              hello everyone... i'm currently having only 9 toolbar buttons in fredoscale whereas there are supposed to be 12 in one video on youtube... and i'm sure there's a setting to get more buttons how can i do that?? 😒
              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                There are usually only 9 buttons on my FredoScale toolbar and only 9 tools in the context-menu.
                BUT you can have up to 14 !
                You can add extra tools from Menu > Tools > Fredo6 Collection > FredoScale > Default Parameters ...
                What do you want the others to be ?? Choose from the list. You need to restart SUp to see the changes...
                  shoeb_cars
                  NO MATTER HOW MANY PRAISES WE KEEP HEAPING ON YOU....U DESERVE MORE N MORE
                  1000 REP... 👍 💚
                    thom_stone
                    agreed, this is a fantastic plug in.
                    however... i am making some 3d models for some longboards i want to make, so i downloaded this to put the curve and camber into the boards. did the longitudinal downward curve no problem, however when it came to the latitudinal upward camber (the slight tip up at each edge of the board, so you can lock your feet in for cornering and speed) i first had to add a flat ended oblong to the end as the end of my board was pointy and the radial beding tool could not lock on to the front, this worked fine, so i went from the center did the first one.
                    It took about 5 minutes to load the action (just a side affect of a slow computer, i thought) then when i got back it had worked but i still had the tool selected so i pressed esc and the action undid. tried again, stil had the tool selected so i typed in 6 degrees and pressed enter. took 5 minutes or so to load then the screen was entirely blank, so i saved it in a hope it would come back if i reloaded, but its aLLLLL gone. im well gutted.
                    sorry about the essay figured more help could be given if people knew the details.
                    thanks for your help in advance
                    • W Offline
                      wyatt
                      I get the following error when starting SU 7. I've probably had this error a long time; I just now had time to try to fix it. I have reloaded the FredoScale2.0i.zip and LibFredo63.4c.zip so I should have the latest files. I have the following in my Plugins folder: libfredo6.rb, LibTraductor.rb, LibTraductor.def, ZLoader_FredoScale.rb, FredoScale_ZH.lang, LIBFREDO6_Dir_34, and FREDOSCALE_Dir_20. I have the Fredo Scale toolbar, and the tools work fine. What's gone wrong?
                      Thanks,
                      Wyatt
                      • fredo6F Offline
                        Wyatt,
                        You seems to have an incorrect footprint in the Plugins folder.
                        You should only have 2 folders FREDOSCALE_Dir_20 and LIBFREDO6_Dir_34, and 2 files LibFredo6.rb and ZLoader__FredoScale.rb
                        What I don't understand is that you say you have the FredoScale toolbar because the message you get means that you did not load the FredoScale script.
                        • W Offline
                          wyatt
                          Fredo,
                          Thanks for the quick reply. I have those 2 folders and 2 files, and indeed, the toolbar loads. See the pic.
                          Is LibTraductor.rb and LibTraductor.def from an old version, or an entirely different script? I actually tried deleting them, but then other (older?) plugins don't work - those errors say that LibTraductor.rb doesn't exist - so I reloaded them. I'm not sure where the .lang file came from. I only need the En version, so maybe that file isn't necessary.
                          Wyatt
                            chouaibcl65
                            thank you , i dont know how to download
                            • Jean-FrancoJ Offline
                              Jean-Franco
                              Hi Chouaib,
                              go to the end of the first post of this thread and you will find the file to download.
                              Jean-Franco
                                chouaibcl65
                                thank yououuu
                                  Mocom
                                  i love your plug-ins you are the master thank you. 😄
                                    KarinaGM
                                    I have a problem with the plugin. It suddendly stoped working.
                                    A couple of hours ago I used it normaly. Now I can't bend or twist... 😕
                                    I haven't installed nothing new, just worked with huge files that sometimes crash.
                                    Here I put some screenshots of what is happening now when I try to use radial bend
                                    I downoladed and reinstaled the plugin and Libredo (just in case) in the correct path, just where it was this morning. I checked the list file by file (everything was there), anyway I deleted and place the new ones instead. No luck. Restarted pc (sometimes it works) no luck again.
                                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                    -Benjamín Franklin.**
                                      There is a toggle that makes it subdivide the object. Looks like you have turned it off. I can't remember what key toggled it though.
                                        Read the manual... http://forums.sketchucation.com/download/file.php?id=35246
                                          KarinaGM
                                          well I read it... but until now it never ocured to me that the defaults didn't include slicing. 😳
                                          THANKS!
                                          • fredo6F Offline
                                            THANKS!
                                            Slicer is activated by key F4.
                                            Note that all options can also be activated via the contextual menu (right click).
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 57
                                            • 58
                                            • 22 / 58
