    1.5k Posts 471 Posters 3.4m Views 470 Watching
      Cris999
      Hello
      Is there another place to download this plugin?
      I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
      Thank You, Cris999
        The 2.1c zip is fine I just re-downloaded it to test... Try again.
          Cris999
          I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
          Thank You
          • fredo6F Offline
            Thank You
            Which unzip program do you use?
              Cris999
              First: I tried to selfextract the file.
              Second: it was 7-Zip
              Third: WinAce
              Forth: I used a online unzipper service
              Fifth: I sent the file to somebody, asking him to unzip
              Sixth: I downloaded from another PC and tried unsuccessfully to unzip
              Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
              Thank You, Cris999
              • fredo6F Offline
                Third: WinAce
                Thank You, Cris999
                Maybe you should try to download WinZip (this is what I use to zip the files).
                In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                • X Offline
                  xrok1
                  i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. ๐Ÿ˜„
                  โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                    blair
                    Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                      blair
                      There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                      • X Offline
                        xrok1
                        you could always make a copy of your original stuff and put it on a hidden layer before you do major edits like round corner.
                          Or even better; use Didier's Ghost Component plugin to keep the original (unrounded) as ghost and round the "real" to anything. Then you can always get back to the original.
                            blair
                            Thank you both for excellant ideas. If not for you guys I would have never guessed or know. Rebuilding 28 interior and exterior corners is not the most fun I have ever had. But, I am now ready for next time.
                              blair
                              Sorry to bother you for this seemingly simple specific but where can I find "Didier's Ghost Component plugin"? I have searched here, Smustard, Ruby Library Depot and Googled but I must not be typing the best words/word combinations.
                              • olisheaO Offline
                                olishea
                                http://forums.sketchucation.com/viewtopic.php?f=180&t=21469
                                oli
                                  Luix0
                                  Gracias
                                    blair
                                    Thanks Oli
                                      Thanks Oli! ๐Ÿ˜‰
                                        lionheart198151
                                        Thanks for sharing,It's so cool!!!
                                        • fredo6F Offline
                                          I know what to do for this type of configuration, but this is not at all a trivial change. So it is on my (big) list of things to do.
                                          In the mean time, I would follow the 'manual' way, as you describe.
                                            push
                                            thank you
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 73
                                            • 74
                                            • 16 / 74
