    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 790.8k Views 175 Watching
    • simon le bonS Offline
      simon le bon
      Dear TIG,
      I would like make a request to you for a new extrude tool (or at least for an available option).
      A tool to sort the edges skeleton in their own family.
      in a kind of way this option already exists with ExtrudeEdgesByRailsByFaces which makes the separation between "Rails" and "Profiles" families...
      Here handmade isolation of "rails" and "profiles" with eraser tool on an initial skin done with Extrude edges by rails
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_042_th.jpg
      It would be a "generous tool" which would offer a great base to work with various tools (besides yours 😉 ).
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_043_th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_045_th.jpg
      with my hope you will find this request important as me, hope also it is not a too great duty I'm asking for.
      ++simonlebon
        simon le bon
        Dear TIG,
        No reply from you. I feel a bit confused/disappointed . 😳 Am I wrong with something?
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_046_th.jpg
        I'm just trying to get all the benefits of your tools and communicate the results here in SCF!
        Ok, please forget my demand. There is already a pretty fast solution to pick up the families curves.
        1. using EEbRbF one time for the profiles, one time for the rails.
        2. explode the resulting groups and explode all the single curves groups.
        3. select by hand all the welded curves (CTRL)and copy them
        4. one time for Profiles family, and the same for Rails family.
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_047_th.jpg
          Then we can mix the power of plenty of tools...
        with my sympathy,
        *simon
          Sorry Simon 😳 , but I've been a bit preoccupied lately... it is quite easy to do this and I am thinking of including an option with EEbyRails to allow you to keep only the Rail-paths, Profile-paths or Rail+Profile-paths... OR I might just make the 'pipe-dream' ExtrudeEdgesToLattice tool... That would do what you want... but also perhaps let you apply a lattice to the untriangulated mesh's faces - using an desired offset from each face's edges and also PushPulled up/down by desired amount[s] too...
          I am very 'bogged down' at the moment but I AM thinking about it...
            simon le bon
            Thank you TIG for your word, I feel better now.
            What you are planning is very exciting .
            It is now going to be hard to wait for.
            you are the
            http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/gnie.gif
            of this place.
            😉 simon
              Landie
              Thankyou for sharing. 😍
              http://www.smithdimes.co.uk
                New updated set available here... http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                Brand new tool ExtrudeEdgesByRailsToLattice added.
                [It has basic EN-US/FR/ES lingvo files...] http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
                Replacement ES lingvo files for all tools included [from Defisto]; and some new FA lingvo files for some tools added [through Majid] - Thanks to them! 😄
                Minor adjustments:
                EEbyEdges tool now exits gracefully.
                A few scripts have had the missing "require 'deBableizer.rb'" added.
                RickW's ' offset.rb' method-only script is now included in the set - because it's needed by EEbyRailsToLattice...
                • mitcorbM Offline
                  mitcorb
                  Again, TIG:
                  Thank you for your talents and contributions.
                  • W Offline
                    watkins
                    Dear TIG,
                    You appear to be using version 1.0 of offset.rb. There is a later version, V2.1 (see the attached). Is it okay to use the later version with your scripts?
                    Regards,
                    Bob
                    offset.rb
                      @watkins said:
                      Dear TIG,
                      Regards,
                      Bob
                      Don't know how I'm still using that old one !
                      Finger on the pulse, and all that.... 😒
                      Anyway... it doesn't matter, v1 or v2.1 both work fine when I've tested...
                      I'll package the new version with any future updates...
                      Meanwhile, if users already have the newer version then I recommend that they don't overwrite it with the older zipped one until the zipped update catches up...
                      Sorry for any confusion...
                        Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
                          I have reissued a new version again today http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
                          After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb 😒 .
                          None of this affects my tools - they only need the Face::offset() method !
                          In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
                            Here's another version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                            An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
                            [note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
                            Thanks...
                              doy
                              thumbs up....this is hot...thanks a lot for sharing
                                Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
                                  Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
                                    Works fine now 👍
                                      gavvy
                                      😲 TO Tig ,I can't say anymore 👍
                                        Here is an updated set.
                                        EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
                                        Reverse the order of picking the rails to swap the diagonals' direction.
                                        Make two diagonal groups overlaid to get a 'diamond mesh' etc...
                                        The lingvo files have be updated to match.
                                          Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                          EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                                          • W Offline
                                            watkins
                                            Dear TIG,
                                            Does one still need offset.rb? I notice that it is missing from the zipped folder.
                                            Regards,
                                            Bob
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 32 / 32
