    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
      Landie
      Thankyou for sharing. 😍
      http://www.smithdimes.co.uk
      • TIGT Online
        New updated set available here... http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        Brand new tool ExtrudeEdgesByRailsToLattice added.
        [It has basic EN-US/FR/ES lingvo files...] http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
        Replacement ES lingvo files for all tools included [from Defisto]; and some new FA lingvo files for some tools added [through Majid] - Thanks to them! πŸ˜„
        Minor adjustments:
        EEbyEdges tool now exits gracefully.
        A few scripts have had the missing "require 'deBableizer.rb'" added.
        RickW's ' offset.rb' method-only script is now included in the set - because it's needed by EEbyRailsToLattice...
        πŸ€“
        • mitcorbM Offline
          mitcorb
          Again, TIG:
          Thank you for your talents and contributions.
          • W Offline
            watkins
            Dear TIG,
            You appear to be using version 1.0 of offset.rb. There is a later version, V2.1 (see the attached). Is it okay to use the later version with your scripts?
            Regards,
            Bob
            offset.rb
            • TIGT Online
              @watkins said:
              Dear TIG,
              Regards,
              Bob
              Don't know how I'm still using that old one !
              Finger on the pulse, and all that.... πŸ˜’
              Anyway... it doesn't matter, v1 or v2.1 both work fine when I've tested...
              I'll package the new version with any future updates...
              Meanwhile, if users already have the newer version then I recommend that they don't overwrite it with the older zipped one until the zipped update catches up...
              Sorry for any confusion...
              • TIGT Online
                Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
                πŸ€“
                • TIGT Online
                  I have reissued a new version again today http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
                  After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb πŸ˜’ .
                  None of this affects my tools - they only need the Face::offset() method !
                  In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
                  πŸ˜•
                  • TIGT Online
                    Here's another version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
                    [note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
                    Thanks...
                      doy
                      thumbs up....this is hot...thanks a lot for sharing
                      • TIGT Online
                        Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
                        πŸ€“
                        • TIGT Online
                          Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
                            Works fine now πŸ‘
                              gavvy
                              😲 TO Tig ,I can't say anymore πŸ‘
                              • TIGT Online
                                Here is an updated set.
                                EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
                                Reverse the order of picking the rails to swap the diagonals' direction.
                                Make two diagonal groups overlaid to get a 'diamond mesh' etc...
                                The lingvo files have be updated to match.
                                • TIGT Online
                                  Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                                  • W Offline
                                    watkins
                                    Dear TIG,
                                    Does one still need offset.rb? I notice that it is missing from the zipped folder.
                                    Regards,
                                    Bob
                                    • TIGT Online
                                      Bob
                                      No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
                                      You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                                        leixing
                                        Thanks TIG.
                                        great work
                                        • W Offline
                                          watkins
                                          Dear TIG,
                                          I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
                                          Thanks,
                                          Bob
                                          • W Offline
                                            watkins
                                            Dear TIG,
                                            Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                                            Regards,
                                            Bob
                                            • 31
                                            • 32
                                            • 7 / 32
