    Model AND Render this: Lavalamp
    36 Posts 20 Posters 8.2k Views 20 Watching
    • boofredlayB Offline
      boofredlay
      Hmm. some interesting reflections from the HDRI.
        boofredlay
        Overnight progressive.
          I'm doing something drastically wrong to get this result...
          There's strange vertical bars around the glass?
          I've a feeling I've made a fundamental mistake in the model but i can't see what!
            tallbridgeguy
            Did you use a glass texture with lines? Its a cool model.
            My lava now looks like marshmallows!
            Nielsen
            http://www.tallbridgeguy.com/
              boofredlay
              Another shot.
              • daleD Offline
                dale
                Here my attempt, rendered in Thea. I would love to post the model, but strangely the image attached below is all that comes up in wireframe mode. I am a little suspicious of the WxSu plugin. I have had a few things give me problems in SketchUp since installing it along with the SU to Thea exporter.
                  Ok here's failed attempt #2
                  As you can see i'm getting the same result as before only more pronounced? Here's my model exploded...
                  And finally here's the .skp which is render UNready for Twilight, can anyone tell me my mistake?
                  Lava Lamp 2.skp
                    d12dozr
                    Rich,
                    Is the water occupying the same 3D space as the glass?
                    http://goo.gl/f7ooYh
                      d12dozr
                      Your water was smoothed too much...see the top and bottom edges on the attached pic:Capture.JPG
                      This is a small test I ran after fixing the water smoothness and scaling the water and lava down by 5%. The issue appears to be fixed 😉 ...now on to fixing the lava material, but that's up to you 😛
                        KarinaGM
                        that's what I call a clean mesh dale! 0_0
                        rclub. Maybe it looks more like a frost lamp more than a lava one, but I love it, lol. How did you do that?
                        I made a quickie model, but I've been struggling with the render settings and haven't acomplished nothing nice...
                        I always have a lot of troubles when trying to create transluscent materials in Kerkythea.
                        Anyway, here's my lamp after aprox. 2 or 3 hours 😳
                        **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                        -Benjamín Franklin.**
                        • N Offline
                          notareal
                          It not just smoothing, but there quite a lot issues how interfacing from material to material should be done. You should avoid intersecting meshes and airgaps. I believe there are examples of Kerkythea/Twilight water liquid interfacing, if my earlier link to basic principle did not help. This is same, only far more complex.
                          Thea has a slightly different way to do material interfacing... Just drop by in Thea forum and we continue there in details, if you have issues.
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                            puck
                            Hi Guys,
                            Had a free night tonight so thought I'd have a little crack at this one. I'm on my laptop and have no rendering software (or power to run it!) so I'm just posting the sketchup model for now. Twilight render will follow in a few days when I'm home.
                            Puck
                            • honoluludesktopH Offline
                              honoluludesktop
                              Fletch, Thanks for the tutorial.
                                d12dozr
                                Very nice detailed explanation, Fletch...thank you!
                                  KarinaGM
                                  Thanks Fletch. I liked the resultant render.
                                  I'll try with spots and biased in Kerky.
                                  • FletchF Offline
                                    Fletch
                                    I responded to Rich on Twilight's forum, but thought I might share some insights here in case they may help others.
                                    Indeed, the model is more complicated than necessary... here's a render in under 2mins 😄
                                    Here's the model/scene ready for Twilight!
                                    1. deleted the water model completely. 😉
                                    2. Then painted the front faces of the "inside of the glass" as "water"
                                    3. grouped them.
                                    4. opened the group and got them all oriented to point "out" (away from the centerline /centroid of the lamp)
                                    5. deleted some of the geometry in the upper base group to get out of the way of the light... deleted odd-shaped emitting light plane which was equal to about 50 lights. ❗
                                      (Each face is triangulated, so an odd-shaped face with many faceted sides = many triangles, each triangle = 1 light emitting plane)
                                    6. set a spot light in the bottom of the lamp (renders much more quickly than emitters and about 100x faster than the odd-shaped emitter plane.)
                                    7. used White as the color of the glass and Flint template 1% opacity
                                    8. used White as the color of the water and 0% opacity
                                    9. used the SSS>Wax template at default settings for the Lava.
                                    10. used Brushed Metal template no bump. 600 shininess.
                                    11. scaled the scene accurately ❗ (14" high... approx 35cm)
                                    12. scaled the lava by 1.08 to fill the lamp more and hide top and bottom of the lava model
                                    13. changed color of base to just be flat grey at 75% grey
                                    14. inserted the Bauhaus lamp scene and deleted the lamp and purged the file.
                                    15. used the studio for the lamp to light the scene
                                    16. created a camera view I liked.
                                    17. applied a fake emitter material to the reflection screens in the background to get something interesting in the metal reflections. I hid a fake-emit screen or two.
                                    18. adjusted the power of my spot light and hot spot and falloff until I was happy (about 2mins of work)
                                    19. rendered prelim at 300x600 on low.
                                    20. rendered final at 300x600 on Medium+.
                                    Fletch
                                      pixelmonkey380
                                      i am going to have to download and start playing with render plugins.
                                      so you want a lava lamp from the 70's eh? well, lets make it realistic! color and current state.
                                      sitting somewhere in a closet, unplugged for years and color correct!
                                      chris<pixelmonkey>:D
                                        Kman
                                        Hey, I'm starting on a lavalamp. Modeling's going smooth, but idk about rendering. Gonna be difficult with demos...
                                        Turns out that Subdivide and Smooth ($22 from Smustard.com) is almost ESSENTIAL to modeling this.
                                        Edit: This is what I have done so far:
                                        Not very far...
                                        When life gives you lemons, take them. Because hey... free lemons.
                                        • 2 / 2
