    Model AND Render this: Lavalamp
    36 Posts 20 Posters 8.2k Views 20 Watching
      chrisjk
      I take it that SketchyPhysics is allowed? 😄
      • soloS Offline
        Sure Sketchy physics is allowed, are you planning an animation?
        • soloS Offline
          Either this is a real tough one, y'all are too busy for it or not interested.
          I guess I will need to go first.
          The outer glass
          http://img682.imageshack.us/img682/8787/lavalamp2.jpg
          The inner liquid
          http://img687.imageshack.us/img687/5872/lavalamp4.jpg
          The stand
          http://img687.imageshack.us/img687/5718/lavalamp3.jpg
          The lava
          http://img706.imageshack.us/img706/6725/lavalamp5.jpg
          wires
          http://img687.imageshack.us/img687/2597/lavalamp6.jpg
          Rendered with Thea, lava is a medium based material with subsurface scattering.
          http://img682.imageshack.us/img682/9606/lavalampfin.jpg
          • Rich O BrienR Online
            Pete,
            I've modelled a lamp but struggling with the render. Do I model glass, liquid and wax and apply material setting to each?
            Or just glass with wax inside?
            I'm using Twilight
            • soloS Offline
              Rich, I'd difinately make the glass with thickness and apply a Twilight normal glass (not thin glass) The liquid inside will be water I guess with a very slight color and the lava can be a SSS material (try Rubber from Twilight and increase absorption)
              Use a basic rectangular plane as light and try it with different strengths and positions until you get the right look I guess.
              • F Offline
                fymoro
                Hey Pete, It's absolutely incredible, very quick and so nice render...Congrats... 👍
                http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                • N Offline
                  notareal
                  With Trilight (and Kerkeythea) one must model so that surface normals do point from inside to out; from the wax to the water, from the water to the glass and from the glass to air. Use dielectric materials. Wax will need SSS.
                  Principle http://www.kerkythea.net/phpBB2/files/dielectrice_glass_modeling_normals_echo2web_129.jpg
                  Nice render solo!
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    tallbridgeguy
                    Just to show how great Solo is at rendering, I will submit the anti-lava lamp. I call it the ping pong rocket!
                    I did a really quick attempt so I could play with Thea. I need to learn how to make sss mats in thea,among other things....I think I will go back to bridges.
                    At least right now, I'm second best! (Until somebody else enters...of course)
                    TBG
                    Nielsen
                    http://www.tallbridgeguy.com/
                    • EscapeArtistE Offline
                      EscapeArtist
                      I'm working on this retro-styled model:
                        By absorption, do you mean the SSS Density setting? Do you have a suggestion on how high it should be?
                        At the moment i'm using the circular base below the liquid as a light emitter. Is this the right approach?
                        Great challenge, very informative 👍
                        • boofredlayB Offline
                          boofredlay
                          Alright Pete, you are an evil man 👿
                          All I set out to do was make a simple lava lamp and post a render. Well I have spent a good portion of my afternoon / evening on this now although most of it has been fun.
                          As for the model this, here are some shots of my model. And yes, I know I am too detailed sometimes. I went for the bottle cap and all 😆 😒
                          I have a couple renders planned, one cooking right now.
                          • honoluludesktopH Offline
                            honoluludesktop
                            Great model and render Solo. TBG, I like your render, what is your tool. Interesting note is that Solo's photos of his collection have a wider contrast, and some incompatible colors that all add to the illustrations sense of reality!-)
                              boofredlay
                              Hmm. some interesting reflections from the HDRI.
                                boofredlay
                                Overnight progressive.
                                  I'm doing something drastically wrong to get this result...
                                  There's strange vertical bars around the glass?
                                  I've a feeling I've made a fundamental mistake in the model but i can't see what!
                                    tallbridgeguy
                                    Did you use a glass texture with lines? Its a cool model.
                                    My lava now looks like marshmallows!
                                    Nielsen
                                      boofredlay
                                      Another shot.
                                      • daleD Offline
                                        dale
                                        Here my attempt, rendered in Thea. I would love to post the model, but strangely the image attached below is all that comes up in wireframe mode. I am a little suspicious of the WxSu plugin. I have had a few things give me problems in SketchUp since installing it along with the SU to Thea exporter.
                                          Ok here's failed attempt #2
                                          As you can see i'm getting the same result as before only more pronounced? Here's my model exploded...
                                          And finally here's the .skp which is render UNready for Twilight, can anyone tell me my mistake?
                                          Lava Lamp 2.skp
                                            d12dozr
                                            Rich,
                                            Is the water occupying the same 3D space as the glass?
                                            http://goo.gl/f7ooYh
