    Model AND Render this: Lavalamp
    36 Posts 20 Posters 7.8k Views 20 Watching
    • soloS Offline
      Why not combine the two.
      I'm looking for retro lava-lamps, not todays cheap knockoffs.
      http://991.com/newGallery/The-Beatles-Love---Mathmos-La-393700.jpg
      http://www.zerotoys.com/newsite/products/images/LavaLamp_Image3.jpg
      The modeling is one thing, and the rendering another challenge.
      Take your time, and have fun.
      • michaliszissiouM Offline
        michaliszissiou
        You're sick, you know pete... πŸ˜†
        • soloS Offline
          πŸ’š
          No I'm evil. πŸ‘Ώ
          • EarthMoverE Offline
            EarthMover
            Great idea. How about you just coin it "Dupe This"?
            Content Creator at Skapeup
              joppermann
              Or..."Try to model as well as solo." πŸ˜‰
              • marked001M Offline
                marked001
                no cheating! πŸ˜†
                http://formfonts.com/viewModel.php?view=1&id=55
                http://www.revision21vis.com
                instagram: revi21on
                  chrisjk
                  I take it that SketchyPhysics is allowed? πŸ˜„
                  • soloS Offline
                    Sure Sketchy physics is allowed, are you planning an animation?
                    • soloS Offline
                      Either this is a real tough one, y'all are too busy for it or not interested.
                      I guess I will need to go first.
                      The outer glass
                      http://img682.imageshack.us/img682/8787/lavalamp2.jpg
                      The inner liquid
                      http://img687.imageshack.us/img687/5872/lavalamp4.jpg
                      The stand
                      http://img687.imageshack.us/img687/5718/lavalamp3.jpg
                      The lava
                      http://img706.imageshack.us/img706/6725/lavalamp5.jpg
                      wires
                      http://img687.imageshack.us/img687/2597/lavalamp6.jpg
                      Rendered with Thea, lava is a medium based material with subsurface scattering.
                      http://img682.imageshack.us/img682/9606/lavalampfin.jpg
                      • Rich O BrienR Online
                        Pete,
                        I've modelled a lamp but struggling with the render. Do I model glass, liquid and wax and apply material setting to each?
                        Or just glass with wax inside?
                        I'm using Twilight
                        • soloS Offline
                          Rich, I'd difinately make the glass with thickness and apply a Twilight normal glass (not thin glass) The liquid inside will be water I guess with a very slight color and the lava can be a SSS material (try Rubber from Twilight and increase absorption)
                          Use a basic rectangular plane as light and try it with different strengths and positions until you get the right look I guess.
                          • F Offline
                            fymoro
                            Hey Pete, It's absolutely incredible, very quick and so nice render...Congrats... πŸ‘
                            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                            • N Offline
                              notareal
                              With Trilight (and Kerkeythea) one must model so that surface normals do point from inside to out; from the wax to the water, from the water to the glass and from the glass to air. Use dielectric materials. Wax will need SSS.
                              Principle http://www.kerkythea.net/phpBB2/files/dielectrice_glass_modeling_normals_echo2web_129.jpg
                              Nice render solo!
                                tallbridgeguy
                                Just to show how great Solo is at rendering, I will submit the anti-lava lamp. I call it the ping pong rocket!
                                I did a really quick attempt so I could play with Thea. I need to learn how to make sss mats in thea,among other things....I think I will go back to bridges.
                                At least right now, I'm second best! (Until somebody else enters...of course)
                                TBG
                                Nielsen
                                http://www.tallbridgeguy.com/
                                • EscapeArtistE Offline
                                  EscapeArtist
                                  I'm working on this retro-styled model:
                                    By absorption, do you mean the SSS Density setting? Do you have a suggestion on how high it should be?
                                    At the moment i'm using the circular base below the liquid as a light emitter. Is this the right approach?
                                    Great challenge, very informative πŸ‘
                                    • boofredlayB Offline
                                      boofredlay
                                      Alright Pete, you are an evil man πŸ‘Ώ
                                      All I set out to do was make a simple lava lamp and post a render. Well I have spent a good portion of my afternoon / evening on this now although most of it has been fun.
                                      As for the model this, here are some shots of my model. And yes, I know I am too detailed sometimes. I went for the bottle cap and all πŸ˜† πŸ˜’
                                      I have a couple renders planned, one cooking right now.
                                      • honoluludesktopH Offline
                                        honoluludesktop
                                        Great model and render Solo. TBG, I like your render, what is your tool. Interesting note is that Solo's photos of his collection have a wider contrast, and some incompatible colors that all add to the illustrations sense of reality!-)
                                          boofredlay
                                          Hmm. some interesting reflections from the HDRI.
                                            boofredlay
                                            Overnight progressive.
