    Model AND Render this: Lavalamp
    36 Posts 20 Posters 8.9k Views 20 Watching
    • marked001M
      marked001
      no cheating! ๐Ÿ˜†
      http://formfonts.com/viewModel.php?view=1&id=55
      http://www.revision21vis.com
      instagram: revi21on
      • C
        chrisjk
        I take it that SketchyPhysics is allowed? ๐Ÿ˜„
        • soloS
          Sure Sketchy physics is allowed, are you planning an animation?
          • soloS
            Either this is a real tough one, y'all are too busy for it or not interested.
            I guess I will need to go first.
            The outer glass
            http://img682.imageshack.us/img682/8787/lavalamp2.jpg
            The inner liquid
            http://img687.imageshack.us/img687/5872/lavalamp4.jpg
            The stand
            http://img687.imageshack.us/img687/5718/lavalamp3.jpg
            The lava
            http://img706.imageshack.us/img706/6725/lavalamp5.jpg
            wires
            http://img687.imageshack.us/img687/2597/lavalamp6.jpg
            Rendered with Thea, lava is a medium based material with subsurface scattering.
            http://img682.imageshack.us/img682/9606/lavalampfin.jpg
              Pete,
              I've modelled a lamp but struggling with the render. Do I model glass, liquid and wax and apply material setting to each?
              Or just glass with wax inside?
              I'm using Twilight
              • soloS
                Rich, I'd difinately make the glass with thickness and apply a Twilight normal glass (not thin glass) The liquid inside will be water I guess with a very slight color and the lava can be a SSS material (try Rubber from Twilight and increase absorption)
                Use a basic rectangular plane as light and try it with different strengths and positions until you get the right look I guess.
                • F
                  fymoro
                  Hey Pete, It's absolutely incredible, very quick and so nice render...Congrats... ๐Ÿ‘
                  http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                  • N
                    notareal
                    With Trilight (and Kerkeythea) one must model so that surface normals do point from inside to out; from the wax to the water, from the water to the glass and from the glass to air. Use dielectric materials. Wax will need SSS.
                    Principle http://www.kerkythea.net/phpBB2/files/dielectrice_glass_modeling_normals_echo2web_129.jpg
                    Nice render solo!
                    • T
                      tallbridgeguy
                      Just to show how great Solo is at rendering, I will submit the anti-lava lamp. I call it the ping pong rocket!
                      I did a really quick attempt so I could play with Thea. I need to learn how to make sss mats in thea,among other things....I think I will go back to bridges.
                      At least right now, I'm second best! (Until somebody else enters...of course)
                      TBG
                      Nielsen
                      http://www.tallbridgeguy.com/
                      • EscapeArtistE
                        EscapeArtist
                        I'm working on this retro-styled model:
                          By absorption, do you mean the SSS Density setting? Do you have a suggestion on how high it should be?
                          At the moment i'm using the circular base below the liquid as a light emitter. Is this the right approach?
                          Great challenge, very informative ๐Ÿ‘
                          • boofredlayB
                            boofredlay
                            Alright Pete, you are an evil man ๐Ÿ‘ฟ
                            All I set out to do was make a simple lava lamp and post a render. Well I have spent a good portion of my afternoon / evening on this now although most of it has been fun.
                            As for the model this, here are some shots of my model. And yes, I know I am too detailed sometimes. I went for the bottle cap and all ๐Ÿ˜† ๐Ÿ˜’
                            I have a couple renders planned, one cooking right now.
                            • honoluludesktopH
                              honoluludesktop
                              Great model and render Solo. TBG, I like your render, what is your tool. Interesting note is that Solo's photos of his collection have a wider contrast, and some incompatible colors that all add to the illustrations sense of reality!-)
                              • boofredlayB
                                boofredlay
                                Hmm. some interesting reflections from the HDRI.
                                • boofredlayB
                                  boofredlay
                                  Overnight progressive.
                                    I'm doing something drastically wrong to get this result...
                                    There's strange vertical bars around the glass?
                                    I've a feeling I've made a fundamental mistake in the model but i can't see what!
                                    • T
                                      tallbridgeguy
                                      Did you use a glass texture with lines? Its a cool model.
                                      My lava now looks like marshmallows!
                                      Nielsen
                                      • boofredlayB
                                        boofredlay
                                        Another shot.
                                        • daleD
                                          dale
                                          Here my attempt, rendered in Thea. I would love to post the model, but strangely the image attached below is all that comes up in wireframe mode. I am a little suspicious of the WxSu plugin. I have had a few things give me problems in SketchUp since installing it along with the SU to Thea exporter.
                                            Ok here's failed attempt #2
                                            As you can see i'm getting the same result as before only more pronounced? Here's my model exploded...
                                            And finally here's the .skp which is render UNready for Twilight, can anyone tell me my mistake?
                                            Lava Lamp 2.skp
