    [Plugin] Double line
    91 Posts 38 Posters 68.3k Views 38 Watching
    • FletchF Offline
      Fletch
      Didier! You are wonderful... but you already knew this. Thank you for sharing this wonderful update.
      Since you love bug-hunting... here's what I get now... it does draw the wall but in the opposite direction from expected... I drew vertically on the 'inside' of this wall... I think it's picking the 'positive' direction of the green axis... perhaps - just a guess.
      my axis lines show up now. 😄
      So, this guy goes to the doctor...
      man: "Doc, my arm hurts when I move it like this."
      doctor: "Well, don't move it like that."
      Fletch
        gamore
        some errors
        what should i do?
          RickW
          That's caused from "sketchup.rb" not being loaded. Didier should be able to fix that in no time.
          RickW
          www.smustard.com
            gamore
              lengai
              HI - perhaps a little out of date, but this post appears active (despite last input Oct '08!)
              Didier did you have an fix for RickW's error as I have got the same message?
              'Error Loading File dline.rb
              (eval):514: undefined method `file_loaded?' for main:Object'
              Any pointers appreciated - i've got a pile of single lines from an OS map, representing adjacent site walls which I would like to double up and extrude (SU speak 'pull') - I figure Dbl Line will do it?
              Thanks.
              • Didier BurD Offline
                Didier Bur
                Hi, I've released a patch today (10.04.10)
                See page 1 of the thread.
                regards,
                DB
                  lengai
                  Didier thanks for snappy comeback! Still getting error message though..
                  I'm running SU7.1 pro on Vista in case that makes a difference?
                  Thanks, L
                    Didier Bur
                    I don't understand what's happening on your side but it works here.
                    So the second patch uploaded page 1 of this thread is a version without a call to the offending method "file_loaded?". It SHOULD work.
                    Regards,
                    DB
                    • simon le bonS Offline
                      simon le bon
                      Cher Didier,
                      Happy to see you coming time to time into SCF. Hope you feel good. For me, several of your tools are definitively adopted!!
                      (Projections tools is an absolute must 👍 👍 👍 )
                      As you probably know, we have intermittent problems to reach your Ruby Library Depot
                      About DOUBLE LINE I would like indicate to you a problem with French version. As far, we can't draw the walls because hitting ENTER key calls nothing. So I'm using English version which works fine. 😉
                      *simon
                        Didier Bur
                        Hi Simon,
                        Yes I know, we had serious problems with our server and it has moved to another computer, but it seems that this is not really the solution.
                        The RLD site is in complete rework, I hope that in June you'll have a brand new site where (among others) you can submit your plugin yourself, or provide a link to your blog/site, etc.
                        P.S.: pour la version française je ne comprend pas leproblème puisque c'est le même code avec juste les messages et menus traduits. Je regarde ça dès que possible.
                        DB
                          taralee324
                          Dider, you made my day!!! This makes my life much easier.
                          A couple of suggestions...
                          1. Can you add a "Set Defaults" button so that I can be lazy and save my preferred settings between opening/closing SketchUp?
                          2. Can you add functionality so to support switching to the pan/orbit tool and back w/o loosing the current path being drawn?
                          Even without... love it!
                            JuanV.Soler
                            Thanks Didier great help 👍
                            just downloaded your plugin, did not noticed before.
                              photon2
                              This seems such an important plugin, but there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line. SU8 on Mac. Mostly trying to use in 2D, with or without grouping, on top of an existing face.
                              • GMthompsonG Offline
                                GMthompson
                                is this plugin out of date, after i click on double line, i dont get a dialog box
                                you can learn something everyday by paying attention
                                  GMthompson
                                  tab key brings up dialog box with doubleline2.rb sorry
                                    boilingsnow
                                    Hi Didier Bur, this plugin is very useful for drawing walls.
                                    But now I have one problem with it. The dialog window only displays for the first time I used the plugin. Now it doest show at all and I cant change any parameters...
                                    Can anyone tell me how I can fix it?
                                    • BoxB Offline
                                      The post above yours might be a clue.
                                      TAB key.
                                      • DSorensenD Offline
                                        DSorensen
                                        Hello,
                                        I have the same problem: the tab key does not bring up the dialog box for the tool.
                                        I am on a MAC. Any suggestions would be appreciated.
                                          This is one of Didier's tools that slipped through the net.
                                          I was charged with updating them to be compatible with the newer versions of SketchUp...
                                          This tool has never properly called its Options on TAB on MAC.
                                          It uses TAB-press... but TAB+keyDown is not recognized by MACs.
                                          Its code can be changed to TAB+keyUp, for PC & MAC compatibility.
                                          BUT I'm sure it's full of other issues too 😒
                                          I'll look at it asap...
                                            DSorensen
                                            Hello TIG
                                            Thank you for responding & looking into this. Much appreciated.
                                            • 3 / 5
