    [Plugin] Double line
    91 Posts 38 Posters 62.9k Views 38 Watching
      taralee324
      Dider, you made my day!!! This makes my life much easier.
      A couple of suggestions...
      1. Can you add a "Set Defaults" button so that I can be lazy and save my preferred settings between opening/closing SketchUp?
      2. Can you add functionality so to support switching to the pan/orbit tool and back w/o loosing the current path being drawn?
      Even without... love it!
        JuanV.Soler
        Thanks Didier great help 👍
        just downloaded your plugin, did not noticed before.
          photon2
          This seems such an important plugin, but there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line. SU8 on Mac. Mostly trying to use in 2D, with or without grouping, on top of an existing face.
          • GMthompsonG Offline
            GMthompson
            is this plugin out of date, after i click on double line, i dont get a dialog box
            you can learn something everyday by paying attention
              GMthompson
              tab key brings up dialog box with doubleline2.rb sorry
                boilingsnow
                Hi Didier Bur, this plugin is very useful for drawing walls.
                But now I have one problem with it. The dialog window only displays for the first time I used the plugin. Now it doest show at all and I cant change any parameters...
                Can anyone tell me how I can fix it?
                • BoxB Offline
                  The post above yours might be a clue.
                  TAB key.
                  • DSorensenD Offline
                    DSorensen
                    Hello,
                    I have the same problem: the tab key does not bring up the dialog box for the tool.
                    I am on a MAC. Any suggestions would be appreciated.
                    • TIGT Online
                      This is one of Didier's tools that slipped through the net.
                      I was charged with updating them to be compatible with the newer versions of SketchUp...
                      This tool has never properly called its Options on TAB on MAC.
                      It uses TAB-press... but TAB+keyDown is not recognized by MACs.
                      Its code can be changed to TAB+keyUp, for PC & MAC compatibility.
                      BUT I'm sure it's full of other issues too 😒
                      I'll look at it asap...
                        DSorensen
                        Hello TIG
                        Thank you for responding & looking into this. Much appreciated.
                        • TIGT Online
                          Here's v6x http://sketchucation.com/pluginstore?pln=dline2
                          Usage:
                          Draw > Double Line
                          [Tab] for options dialog
                          [Double-click] to close loop and draw
                          [Enter] to draw
                          [Esc] to quit
                          Draws Double-Lines / Walls - like Autocad's Autolisp "dline.lsp".
                          It is now compatible with PC & MAC, and suitable for v8 to >=v2015 .
                          Its lines are now forced 'flat' - constrained to initial point's Z.
                          If grouped it is uniquely named ["DLINE#n"].
                          General coding overhaul and update...
                          Now uses TAB+keyUP for Options to be compatible with MAC & PC.
                            DSorensen
                            Thank you TIG. Really helpful.
                            All best,
                            David
                              DSorensen
                              Hello Tig,
                              ".......there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line".
                              Would it be possible to break up the lines as suggested by this comment quoted above....?
                              If possible---and with our thanks.
                              David
                              • EdsonE Offline
                                Edson
                                I have installed the latest version from the Extension Warehouse but it does not work.
                                I am on Mac OS X 10.10 and the latest version of SU 2015.
                                http://www.mahfuz.arq.br
                                  driven
                                  Edson, it's working with Yosemite on my mac...
                                  is it appearing in the Draw menu?
                                  is it drawing anything?
                                  • EdsonE Offline
                                    Edson
                                    hi john,
                                    yes, it appears on the Draw menu and the toolbar is ok. at first it seemed not to be working because I was drawing at too small a scale.
                                    after making sure it is working I ran a few tests and the only thing I could not do is to close a set of walls upon itself. in general it does not close and when it does the corner is not healed (see image attached). perhaps I am doing something wrong.
                                    on the other hand, drawing from a selection works fine.
                                    thanks.
                                      driven
                                      it's it's click >> click >> double click for self closure...
                                      self closure
                                      • EdsonE Offline
                                        Edson
                                        this is what I cannot achieve. when I double-click there appears a third line on the ground and I have to press return for the wall to appear. the corner remains unhealed as in the attached image.
                                        • mariochaM Offline
                                          mariocha
                                          Negative height: This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
                                          Well, sorry to say it happens even if the face is in a group. Quite annoying.
                                          %(#008000)[Mario C.
                                          • mariochaM Offline
                                            mariocha
                                            Just for info. Here, on 10.10.5, double-clicking closes and heals alright.
                                            Hum... if a third line appears, it means a third single point has been clicked, I'd say.
                                            To make a closed triangular wall, the process is : click = start, click = 1st line, double-click = walls.
                                            As you probably figured out by now.
                                            %(#008000)[Mario C.
                                            • 4 / 5
