    [Plugin] Double line
    91 Posts 38 Posters 68.3k Views 38 Watching
      With pre-drowed lines extrude lines.rb is better choise imho
      You have not the drawing of the dashed axis line 😉
      And you have a thickness with extrude simple lines ❓ And a wall ❓
      it closes wall in a new point not at the first one
      Yes Didier is some original ! 💚
      It's some pertubating but after some try we are in the move! ☀
        rv1974
        Pardon, I meant extrude along path .rb (of TIG i beleive).
        I'm afraid the wink about dashed line I didn't understand. What do you mean?
          Just this 😉
            gogo2suf
            Thank You vary much D. Bur ,
            Thank you!!!!!!!!!!!!
            GOGO
              agrazdi
              Is it possible to add a png icon into the tool bars for the double line function ?
              agrazdi
              • FletchF Offline
                Fletch
                Didier! You are wonderful... but you already knew this. Thank you for sharing this wonderful update.
                Since you love bug-hunting... here's what I get now... it does draw the wall but in the opposite direction from expected... I drew vertically on the 'inside' of this wall... I think it's picking the 'positive' direction of the green axis... perhaps - just a guess.
                my axis lines show up now. 😄
                So, this guy goes to the doctor...
                man: "Doc, my arm hurts when I move it like this."
                doctor: "Well, don't move it like that."
                Fletch
                  gamore
                  some errors
                  what should i do?
                    RickW
                    That's caused from "sketchup.rb" not being loaded. Didier should be able to fix that in no time.
                    RickW
                    www.smustard.com
                      gamore
                        lengai
                        HI - perhaps a little out of date, but this post appears active (despite last input Oct '08!)
                        Didier did you have an fix for RickW's error as I have got the same message?
                        'Error Loading File dline.rb
                        (eval):514: undefined method `file_loaded?' for main:Object'
                        Any pointers appreciated - i've got a pile of single lines from an OS map, representing adjacent site walls which I would like to double up and extrude (SU speak 'pull') - I figure Dbl Line will do it?
                        Thanks.
                        • Didier BurD Offline
                          Didier Bur
                          Hi, I've released a patch today (10.04.10)
                          See page 1 of the thread.
                          regards,
                          DB
                            lengai
                            Didier thanks for snappy comeback! Still getting error message though..
                            I'm running SU7.1 pro on Vista in case that makes a difference?
                            Thanks, L
                              Didier Bur
                              I don't understand what's happening on your side but it works here.
                              So the second patch uploaded page 1 of this thread is a version without a call to the offending method "file_loaded?". It SHOULD work.
                              Regards,
                              DB
                              • simon le bonS Offline
                                simon le bon
                                Cher Didier,
                                Happy to see you coming time to time into SCF. Hope you feel good. For me, several of your tools are definitively adopted!!
                                (Projections tools is an absolute must 👍 👍 👍 )
                                As you probably know, we have intermittent problems to reach your Ruby Library Depot
                                About DOUBLE LINE I would like indicate to you a problem with French version. As far, we can't draw the walls because hitting ENTER key calls nothing. So I'm using English version which works fine. 😉
                                *simon
                                  Didier Bur
                                  Hi Simon,
                                  Yes I know, we had serious problems with our server and it has moved to another computer, but it seems that this is not really the solution.
                                  The RLD site is in complete rework, I hope that in June you'll have a brand new site where (among others) you can submit your plugin yourself, or provide a link to your blog/site, etc.
                                  P.S.: pour la version française je ne comprend pas leproblème puisque c'est le même code avec juste les messages et menus traduits. Je regarde ça dès que possible.
                                  DB
                                    taralee324
                                    Dider, you made my day!!! This makes my life much easier.
                                    A couple of suggestions...
                                    1. Can you add a "Set Defaults" button so that I can be lazy and save my preferred settings between opening/closing SketchUp?
                                    2. Can you add functionality so to support switching to the pan/orbit tool and back w/o loosing the current path being drawn?
                                    Even without... love it!
                                      JuanV.Soler
                                      Thanks Didier great help 👍
                                      just downloaded your plugin, did not noticed before.
                                        photon2
                                        This seems such an important plugin, but there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line. SU8 on Mac. Mostly trying to use in 2D, with or without grouping, on top of an existing face.
                                        • GMthompsonG Offline
                                          GMthompson
                                          is this plugin out of date, after i click on double line, i dont get a dialog box
                                          you can learn something everyday by paying attention
                                            GMthompson
                                            tab key brings up dialog box with doubleline2.rb sorry
                                            • 3 / 5
