    Metal Spiral Stairs - how to do it?
    48 Posts 15 Posters 7.9k Views 15 Watching
    • W
      watkins
      Inspired by TIG, and all done without plugins. A handrail would be fairly easy to include in the model.
      Spiral staircase_Bob.skp
      • daleD
        dale
        do you know this mythical thread? 😉
        Well there will be a lot of down time at workplaces around the world now Pilou....
        It ia a mythical thread, I think it gave mimi the title "stairmaster" because of the number of great posts she made.
        • charly2008C
          charly2008
          Hi Spiral stair Fans,
          Here a few further examples. The construction is best started at the point of origin. Then one has the exact center of the construction.
          I have also tried to cover the bottom of the stairs with Follow Me and Keep but this was not successful. Only the first stair was covered.
          For the hand rail i tried the Balustrade Rubies but both doesn't work in my Sketchup 7.
          Spiral stair.skp
          • W
            watkins
            Finished model with handrail
            Spiral staircase_finished.skp
            • EdsonE
              Edson
              @honoluludesktop said:
              You guys are great, hope I can find this post if I ever do a spiral stairs in SU.
              how about bookmarking it? 😉
              http://www.mahfuz.arq.br
              • EdsonE
                Edson
                @pmiller said:
                No offense to all you spiral stair makers but the wide stairs that you show with winders coming to a narrow point would be very dangerous (especially in descent). I would suggest a bigger inside hole or solid radius to assure a minimum tread depth. That's why typical library or residential stairs are quite narrow in width so as to keep a person in the middle of the tread with proper depth for the foot. Such wide stairs with point winders would be prohibited by code in the US, even for non-egress stairs in commercial stuctures.
                no offense taken, paul. if you look at the last one i posted it has an inside radius of 50cm which makes for at least 15cm (6") at ther narrowest point. in my opinion, for a spiral stair to be confortable it must be quite wide as the one in the picture shown at my first post.
                  To repeat an earlier thread...
                  When making spiral steps there are often rules/codes to adhere to..
                  In the UK on narrower flights <1m [typically domestic or small commercial flights] you must have at least 50mm of plan-tread at the innermost part and the plan-tread on the centerline should be even for every step, and follow the rule 2R+G >=550mm <=700mm - where R is the Rise and G is the Going [plan-tread].
                  If you draw this in plan it limits the relative angle of adjacent nosings and effectively sets a limit on the taper angle between them = ~15degrees depending on the configuration etc...
                  For wider stairs you measure in from both edges [strings] 270mm and the same max/min pitch applies, 2R+G >=550mm <=700mm to the two locations
                  Any landings shall be the same length as their width measured along their centerline.
                  The minimum/maximum allowable Rise and Going varies with the building type too.
                  'Private Stair'[one dwelling] R >=155mm <=220mm and G >=223mm <=300mm [vertical pitch is also limited to 42 degrees - usually trapped by 2R+G rules]
                  'Institutional and Assembly Stair' R >=135mm <=180mm and G >=280mm <=340mm
                  'Other Stair' R >=150mm <=190mm and G >=250mm <=320mm
                  BUT AD-Part-M [accessible/disabled=all commercial/public building etc] R <= 170mm G >= 250mm
                  So it's best to draw some test treads and place rotate a couple to see it they are right before committing to a complex 3D assembly...
                  • EdsonE
                    Edson
                    i wish i had access to it. according to ppb i do not have permission to access that page. i wonder how they expect me to participate more if i am not allowed to access certain threads.
                    • jeff hammondJ
                      randomly thought of this earlier today.. i drew it pretty darn fast though it could use a little fine tuning.
                      shape bender by chris fullmer..
                      • jeff hammondJ
                        gotta admit.. this is one area where bonzai3D is far superior to sketchup.. parametric stair building!
                        [flash=660,405:2pgaictc]http://www.youtube.com/v/_zgK8YYYoLo&hl=en_US&fs=1&rel=0&border=1[/flash:2pgaictc]
                        • EdsonE
                          Edson
                          gotta admit.. this is one area where bonzai3D is far superior to sketchup. parametric stair building!
                          jeff,
                          i agree with it up to a point. it is true that out of the box sketchup surely lacks some tools other apps offer as a matter of fact. (i wonder if parametric tools are not on the list for v8.)
                          on the other hand, i have not heard of any development of plugins for b3d. perhaps it does not need them but can an app be so perfect it foresees all possible users' needs?
                          but at the same time as it is great to have such a great group of people creating plugins for sketchup, it is enough for one of them to lose interest in it or be too busy to keep them updated for a whole bunch of plugins to become unusable.
                          • EdsonE
                            Edson
                            1001bits Stairs case 😉
                            thanks, pilou, but if you read this thread with some attention you will notice that i posted a stair made with 1001bit tools, and even said it was the best solution i had found.
                              1001bits Stairs case 😉 (video)
                                ah yes 😳 this last was for the video 😉
                                • EdsonE
                                  Edson
                                  never mind. cheers. 😄
                                  • charly2008C
                                    charly2008
                                    I have also tried the 1001 bit tools. For a standard spiral staircase, it's wonderful. You can quickly change the dimensions and gets in a very short time, a spiral staircase but always with the same design.
                                    Sure that a commercial working architect will have a different view because time is money.
                                    Will you have a custom design, then GROW along with a staircase component is the best choice. At the beginning you have to calculate and construct a little more but in the end you have an individual design.
                                    Karl
                                    Spiral stair.skp
                                      charly
                                      Here's my original Grow tutorial [GrowHelicalSteps2] updated for handrailsGrowHelicalSteps2.pngGrowHelicalSteps2.skp
                                      • charly2008C
                                        charly2008
                                        Hi TIG,
                                        thanks for this nice tutorial.
                                        Charly
                                        • 2 / 3
