    Metal Spiral Stairs - how to do it?
    48 Posts 15 Posters 7.8k Views 15 Watching
    • TIGT Online
      Here's another way - entirely by hand - without Plugins [from a Plugin-fiend] 😉Capture.PNGHelicalStairWithoutPlugins.skp
      • EdsonE Offline
        Edson
        beautiful, TIG. it shows once more the power of sketchup. but nonetheless i will tell as a friend: plugins can make your life much easier! there are some people in this forum who make wonderful plugins... 😉
        http://www.mahfuz.arq.br
        • TIGT Online
          Maybe I should try some .... 🤣
          • charly2008C Offline
            charly2008
            FollowMeand keep with Grow could be the ideal solution.
            • TIGT Online
              I deliberately avoided mentioning my Grow tool as I was trying to show it all 'long-hand'... 😒
                charly2008
                Hi TIG,
                shure you can help me to solve a small problem with Grow. How can i manage that the Center of the Grow object meets a individual axe.
                Thanks in advance
                Karlheinz
                • TIGT Online
                  Manipulate the component's axis and its location relative to the 'growth' point....
                    charly2008
                    The final result with FollowMeandKeep and Grow.
                    • honoluludesktopH Offline
                      honoluludesktop
                      You guys are great, hope I can find this post if I ever do a spiral stairs in SU.
                        pmiller
                        No offense to all you spiral stair makers but the wide stairs that you show with winders coming to a narrow point would be very dangerous (especially in descent). I would suggest a bigger inside hole or solid radius to assure a minimum tread depth. That's why typical library or residential stairs are quite narrow in width so as to keep a person in the middle of the tread with proper depth for the foot. Such wide stairs with point winders would be prohibited by code in the US, even for non-egress stairs in commercial stuctures.
                        • Chris FullmerC Offline
                          But if you put a traffic dividing handrail right down the middle, then make the inside lane flat and smooth, you could have a really nice safe up half with wide treads, and a nice spiral slide down lane. 😄
                            do you know this mythical thread? 😉
                            • W Offline
                              watkins
                              Inspired by TIG, and all done without plugins. A handrail would be fairly easy to include in the model.
                              Spiral staircase_Bob.skp
                              • daleD Offline
                                dale
                                Well there will be a lot of down time at workplaces around the world now Pilou....
                                It ia a mythical thread, I think it gave mimi the title "stairmaster" because of the number of great posts she made.
                                  charly2008
                                  Hi Spiral stair Fans,
                                  Here a few further examples. The construction is best started at the point of origin. Then one has the exact center of the construction.
                                  I have also tried to cover the bottom of the stairs with Follow Me and Keep but this was not successful. Only the first stair was covered.
                                  For the hand rail i tried the Balustrade Rubies but both doesn't work in my Sketchup 7.
                                  Spiral stair.skp
                                  • W Offline
                                    watkins
                                    Finished model with handrail
                                    Spiral staircase_finished.skp
                                    • EdsonE Offline
                                      Edson
                                      how about bookmarking it? 😉
                                      • EdsonE Offline
                                        Edson
                                        no offense taken, paul. if you look at the last one i posted it has an inside radius of 50cm which makes for at least 15cm (6") at ther narrowest point. in my opinion, for a spiral stair to be confortable it must be quite wide as the one in the picture shown at my first post.
                                        • TIGT Online
                                          To repeat an earlier thread...
                                          When making spiral steps there are often rules/codes to adhere to..
                                          In the UK on narrower flights <1m [typically domestic or small commercial flights] you must have at least 50mm of plan-tread at the innermost part and the plan-tread on the centerline should be even for every step, and follow the rule 2R+G >=550mm <=700mm - where R is the Rise and G is the Going [plan-tread].
                                          If you draw this in plan it limits the relative angle of adjacent nosings and effectively sets a limit on the taper angle between them = ~15degrees depending on the configuration etc...
                                          For wider stairs you measure in from both edges [strings] 270mm and the same max/min pitch applies, 2R+G >=550mm <=700mm to the two locations
                                          Any landings shall be the same length as their width measured along their centerline.
                                          The minimum/maximum allowable Rise and Going varies with the building type too.
                                          'Private Stair'[one dwelling] R >=155mm <=220mm and G >=223mm <=300mm [vertical pitch is also limited to 42 degrees - usually trapped by 2R+G rules]
                                          'Institutional and Assembly Stair' R >=135mm <=180mm and G >=280mm <=340mm
                                          'Other Stair' R >=150mm <=190mm and G >=250mm <=320mm
                                          BUT AD-Part-M [accessible/disabled=all commercial/public building etc] R <= 170mm G >= 250mm
                                          So it's best to draw some test treads and place rotate a couple to see it they are right before committing to a complex 3D assembly...
                                          • EdsonE Offline
                                            Edson
                                            i wish i had access to it. according to ppb i do not have permission to access that page. i wonder how they expect me to participate more if i am not allowed to access certain threads.
                                            • 2 / 3
