    Metal Spiral Stairs - how to do it?
    48 Posts 15 Posters 8.8k Views 15 Watching
    • EdsonE
      Edson
      thanks to all of you for your contributions. there is now more than one method to solve this problem.
      before checking here i found another way of doing it precisely with the stair tool of 1001bit tools (excellent set of plugins, by the way). i attached a tutorial explaining how i did it.
      Spiral_Ribbon_Stairs_Tut.skp
      http://www.mahfuz.arq.br
        Here's another way - entirely by hand - without Plugins [from a Plugin-fiend] 😉Capture.PNGHelicalStairWithoutPlugins.skp
        • EdsonE
          Edson
          beautiful, TIG. it shows once more the power of sketchup. but nonetheless i will tell as a friend: plugins can make your life much easier! there are some people in this forum who make wonderful plugins... 😉
            Maybe I should try some .... 🤣
            • charly2008C
              charly2008
              FollowMeand keep with Grow could be the ideal solution.
                I deliberately avoided mentioning my Grow tool as I was trying to show it all 'long-hand'... 😒
                • charly2008C
                  charly2008
                  Hi TIG,
                  shure you can help me to solve a small problem with Grow. How can i manage that the Center of the Grow object meets a individual axe.
                  Thanks in advance
                  Karlheinz
                    Manipulate the component's axis and its location relative to the 'growth' point....
                    • charly2008C
                      charly2008
                      The final result with FollowMeandKeep and Grow.
                      • honoluludesktopH
                        honoluludesktop
                        You guys are great, hope I can find this post if I ever do a spiral stairs in SU.
                        • P
                          pmiller
                          No offense to all you spiral stair makers but the wide stairs that you show with winders coming to a narrow point would be very dangerous (especially in descent). I would suggest a bigger inside hole or solid radius to assure a minimum tread depth. That's why typical library or residential stairs are quite narrow in width so as to keep a person in the middle of the tread with proper depth for the foot. Such wide stairs with point winders would be prohibited by code in the US, even for non-egress stairs in commercial stuctures.
                          • Chris FullmerC
                            But if you put a traffic dividing handrail right down the middle, then make the inside lane flat and smooth, you could have a really nice safe up half with wide treads, and a nice spiral slide down lane. 😄
                              do you know this mythical thread? 😉
                              • W
                                watkins
                                Inspired by TIG, and all done without plugins. A handrail would be fairly easy to include in the model.
                                Spiral staircase_Bob.skp
                                • daleD
                                  dale
                                  Well there will be a lot of down time at workplaces around the world now Pilou....
                                  It ia a mythical thread, I think it gave mimi the title "stairmaster" because of the number of great posts she made.
                                  • charly2008C
                                    charly2008
                                    Hi Spiral stair Fans,
                                    Here a few further examples. The construction is best started at the point of origin. Then one has the exact center of the construction.
                                    I have also tried to cover the bottom of the stairs with Follow Me and Keep but this was not successful. Only the first stair was covered.
                                    For the hand rail i tried the Balustrade Rubies but both doesn't work in my Sketchup 7.
                                    Spiral stair.skp
                                    • W
                                      watkins
                                      Finished model with handrail
                                      Spiral staircase_finished.skp
                                      • EdsonE
                                        Edson
                                        how about bookmarking it? 😉
                                        • EdsonE
                                          Edson
                                          no offense taken, paul. if you look at the last one i posted it has an inside radius of 50cm which makes for at least 15cm (6") at ther narrowest point. in my opinion, for a spiral stair to be confortable it must be quite wide as the one in the picture shown at my first post.
                                            To repeat an earlier thread...
                                            When making spiral steps there are often rules/codes to adhere to..
                                            In the UK on narrower flights <1m [typically domestic or small commercial flights] you must have at least 50mm of plan-tread at the innermost part and the plan-tread on the centerline should be even for every step, and follow the rule 2R+G >=550mm <=700mm - where R is the Rise and G is the Going [plan-tread].
                                            If you draw this in plan it limits the relative angle of adjacent nosings and effectively sets a limit on the taper angle between them = ~15degrees depending on the configuration etc...
                                            For wider stairs you measure in from both edges [strings] 270mm and the same max/min pitch applies, 2R+G >=550mm <=700mm to the two locations
                                            Any landings shall be the same length as their width measured along their centerline.
                                            The minimum/maximum allowable Rise and Going varies with the building type too.
                                            'Private Stair'[one dwelling] R >=155mm <=220mm and G >=223mm <=300mm [vertical pitch is also limited to 42 degrees - usually trapped by 2R+G rules]
                                            'Institutional and Assembly Stair' R >=135mm <=180mm and G >=280mm <=340mm
                                            'Other Stair' R >=150mm <=190mm and G >=250mm <=320mm
                                            BUT AD-Part-M [accessible/disabled=all commercial/public building etc] R <= 170mm G >= 250mm
                                            So it's best to draw some test treads and place rotate a couple to see it they are right before committing to a complex 3D assembly...
                                            • 2 / 3
