    Metal Spiral Stairs - how to do it?
    48 Posts 15 Posters 7.9k Views 15 Watching
      Despit the fact that Spiral staircases are ready made inside see this video
      1001bits "extrude along path"
      Just use an helix as path 😉
        d12dozr
        Jeff's method is great, and could save a step and some cleanup by using TIG's EE by Vector to pull the helix up vertically. So you would:
        -Draw helix with Curve Maker
        -Extrude helix vertically with EE by Vector
        -use JPP to give it thickness
        http://goo.gl/f7ooYh
        • EdsonE
          Edson
          thanks, guys, for your kind help. i will try all the suggestions and will report back when i have done my own spiral stair.
          best regards,
          edson
          http://www.mahfuz.arq.br
          • W
            watkins
            Dear Edson,
            A quick model using screw1_5.rb
            Regards,
            Bob
            Quick model.skp
            • EdsonE
              Edson
              one problem i am facing right now is how to draw a helix that will fit precisely the stair i am building. i have tried helix, drawhelix and curvemaker but they all seem not to make things easier for one.
              helix asks you to select a face. it does not seem to accept integers like 1.5.
              in drawhelix, what is pitch and sections per?
              the parameters in curvemaker are obscure: what are from turns, to turns, sides/turn?
              • GaieusG
                In Drawhelix, "Pitch" is the total height of the helix while "Sections per" will refer to the segment count it will use per turn (in that screenshot 5 turns).
                So say if you want to combine it with a "regular" circle base, which has 24 segments all around, leave it at 24 in the plugin, too.
                • simon le bonS
                  simon le bon
                  Hi Edson, Hi everybody,
                  And why not use COMPONENT STRINGER ?
                  It is very powerful and flexible. >> Once the component is distributed along the path, you can open it and work on it in order to change the all stair in one pass: for example build and join the ribbons to make a complete one 😉 (I understand myself 😆 )
                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/Wire020_th.jpg
                  😛 simon
                  • charly2008C
                    charly2008
                    maybe a simple method with draw helixand follow me and keep. However, I do not know yet how to make the transition to the next floor!
                    • jeff hammondJ
                      from turns to turns has to do with the origin parameter.. if you have the origin set at 0,0,0 then set from turn at 2 and to turn at 3.. the helix will end up being one full revolution starting above the actual origin (ie, it will be as if two revolutions were made but only the top revolution will be drawn)
                      for simplicity sake (or the way i use it).. if you want one rotation, set it from turn 0 to turn 1.. if you want 1 1/2 turns then go from 0 to 1.5.. 3 revolutions = from 0 to 3 etc... then move the helix into the location you want..
                      sides/turn simply means how many line segments you want the helix to be drawn with per 1 revolution.. same thing as drawing a circle in SU - default is 24 sides/turn but you can change it to whatever you like.
                      • jeff hammondJ
                        oh yeah, that's way better..
                          dtrarch
                          Hi Edson
                          Easy to build a circular stair using 2 Olde scripts.
                          draw helix and spiral stair.
                          Both available on Didier's site.
                          (seems to be off line now)
                          Just to make sure here is the all script zip file and quick tut on how to build.
                          Use the handrail path (followMe and Keep) to extrude handrail shape or to create walls along the stair.
                          For floor to floor just copy and move up/down as needed.
                          Thanks for jogging my memory on this too.
                          us_all_scripts.zip
                          SPIRAL STAIR TUTORIAL.skp
                          • charly2008C
                            charly2008
                            At the end it should look like that. Still without stairs. Any Idea how to complete it with steps?
                            Spiral stair.skp
                            • EdsonE
                              Edson
                              thanks to all of you for your contributions. there is now more than one method to solve this problem.
                              before checking here i found another way of doing it precisely with the stair tool of 1001bit tools (excellent set of plugins, by the way). i attached a tutorial explaining how i did it.
                              Spiral_Ribbon_Stairs_Tut.skp
                                Here's another way - entirely by hand - without Plugins [from a Plugin-fiend] 😉Capture.PNGHelicalStairWithoutPlugins.skp
                                • EdsonE
                                  Edson
                                  beautiful, TIG. it shows once more the power of sketchup. but nonetheless i will tell as a friend: plugins can make your life much easier! there are some people in this forum who make wonderful plugins... 😉
                                    Maybe I should try some .... 🤣
                                    • charly2008C
                                      charly2008
                                      FollowMeand keep with Grow could be the ideal solution.
                                        I deliberately avoided mentioning my Grow tool as I was trying to show it all 'long-hand'... 😒
                                        • charly2008C
                                          charly2008
                                          Hi TIG,
                                          shure you can help me to solve a small problem with Grow. How can i manage that the Center of the Grow object meets a individual axe.
                                          Thanks in advance
                                          Karlheinz
                                            Manipulate the component's axis and its location relative to the 'growth' point....
                                            • 1 / 3
