    Bonzai3D - double take
    extensions
    119 Posts 21 Posters 28.0k Views 21 Watching
    • X Offline
      xrok1
      the weirdest thing is that if i use a circle (or any spline based shape) it works the way i'd expect, any other line shape won't make a cutout??????
      in fact the circle even works as expected with the 3dwall object without converting it!!!
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        bonzai3d support
        Rocky,
        Sorry again that you are having trouble. You certainly should be able to insert any shape hole you want -- regardless of whether or not the object is a controlled object. (It should automatically convert to plain if necessary.) We can't tell why it is not inserting properly from your image alone. As we have requested previously, if you have any problems, can you please send your question to support@bonzai3d.com and attach your BNZ,zip file so we can get you an answer?
        (Perhaps leading a tutorial and learning software at the same time is not the best practice. Please allow us to help you get up to speed!)
        Explore * Design * Deliver
        http://www.bonzai3d.com
        Version 2.5 Now Available!
        • X Offline
          xrok1
          this is actually not a tutorial but a journal of my experience with a new (your) software from a designers point of view. ๐Ÿ˜‰ i will send you the file so you can check it out and advise on what's going on. i will try one more time from scratch since i'm not too far in anyways.
          ๐Ÿ‘Š biting my tongue over your last statement. ๐Ÿ‘Š
            bonzai3d support
            Rocky,
            Thanks for sending your file. We checked this geometry with the Object Doctor tool (check all options from all tabs, use Add to Selection, and Display Results) and we found quite a few problems:
            We then changed the Add to Selection option to Fix (unchecked the Coplanar Surface check since I believe that you want these) and ran it again. This fixed the problems and now the insertions work properly.
            Does this fix the problem for you?
            • EdsonE Offline
              Edson
              rocky,
              this is a very useful thread indeed. at least for us, potential users of b3d. keep it going.
              edson mahfuz, architect| porto alegre โ€ข brasil
              http://www.mahfuz.arq.br
              • X Offline
                xrok1
                ok, were back on track now. i had to do it twice to get it to work properly but at least i know i'm not crazy now. ๐Ÿ˜‰ i appreciate your help, i can proceed with my journal now. ๐Ÿ˜‰
                PS, as you watch my process please feel free to chime in if there's an easier way of doing certain steps.
                • X Offline
                  xrok1
                  so as you can see i drew construction lines along these two edges, then moved them a distance so they would intersect at the top left of the window opening. i then used their intersection as a guide to draw the window opening. (remember that i turned snap to intersection on earlier)
                  • X Offline
                    xrok1
                    next was the offset tool followed by the reshape tool to create the window casing. (nothing fancy, just a guide for proper spacing)
                    this might also be a good time to ask the b3d guys if there's a follow me type tool in case someone would like to create an actual casing profile and extrude it around the window.
                    • X Offline
                      xrok1
                      couldn't really figure out how to paint the casing faces differently than the wall (any hints?) and got this while undoing. not too serious, didn't crash the program or anything. that reminds me, i better save. ๐Ÿ˜†
                      btw, in case its not obvious the green text is aimed at the b3d team.
                        bonzai3d support
                        Rocky,
                        We only check your thread occasionally (as much as time allows) but you will REALLY get faster answers if you ask them directly to us! (You can also post these questions on OUR forum, but this is a third party forum after all!)
                        But anyway -- to answer your questions (now that I have seen them): The "follow me" tool is properly called the Sweep tool in most CAD software. You can find this on the Derive tool row.
                        Picking objects in bonzai3d automatically picks the "most appropriate part (or all)" of the object, depending on the currently active tool. If this part is not the one you want, you can either hold down the Ctrl key (Win) or Command key (Mac) and place the cursor over the desired part to pick it, or you can also tap the TAB key to cycle through the available options.
                        So, to color a face, drag the desired color onto this face while holding the desired modifier key, or get the Paint bucket tool and press the Tab key when the cursor is in the desired location (and click when the desired part is identified).
                        Does this help?
                          Could you use a less intense colour for your text? Very hard to read that green text.
                            I'd suggest this, as it's easy to read ๐Ÿ˜ฒ
                            • X Offline
                              xrok1
                              @bonzai3d support said:
                              Rocky,
                              i am not after fast answers and understand if i don't get them, but you must realize i'm doing this for the users of this forum as well as for personal curiosity about b3d. i can stop at any time if you feel i'm doing you a disservice but i'm really starting to enjoy the experience now that i'm getting a little more familiar.
                              i believe most of us know this, i'm trying to stay in context. i tried it and it works quite well actually. ๐Ÿ˜„
                              very useful information about the pick tool! i guess i should have watched the videos on your site a little closer.
                              Does this help?
                              yes, my faces are properly colored now.:D
                              btw, the green was too hard on my eyes. ๐Ÿ˜†
                              • X Offline
                                xrok1
                                side note: here's the sweep tool in action. its quite good!
                                  bonzai3d support
                                  Rocky,
                                  We certainly do not want to tell you to stop posting! We just hoped you could better show how bonzai3d was Designed to work -- and perhaps a little less how it does not work when you try to use it like SketchUp.
                                  We are sure that your thread can be quite useful to other readers of this forum, so if you have any questions or problems, feel free to email us. Then you can post what you tried and what we suggested all in the same post.
                                  Anyway, glad you are getting more familiar and enjoying bonzai3d!
                                    tfdesign
                                    Erm, I am finding this blue hard to read too (against the off-white background). Can you not just keep your text black? ๐Ÿ˜„
                                    • X Offline
                                      xrok1
                                      fine! ๐Ÿ˜†
                                      • X Offline
                                        xrok1
                                        Rocky,
                                        out of all fairness here's a link to the b3d video's if anyone wants to see how its designed to work: http://www.formz.com/products/bonzai3d/bonzai3dVideo_640.php?startMovie=Interface_640.flv
                                        if you care to see what an SU users experience will be like stay tuned. ๐Ÿ˜‰
                                          kwistenbiebel
                                          Hey, this is a great thread.
                                          You are using the exact same approach I would take when I would learn new 3D software like B3D.
                                          Diving into it with the SU knowledge we have and see how it goes...
                                          First thing that strikes me is: it's not Sketchup ๐Ÿ˜„
                                          I'll be following this with great intrest... ๐Ÿ‘
                                          • utilerU Offline
                                            utiler
                                            Me too, kwist. I'm sitting in the front row complete with popcorn.....
                                            Just Curious...
                                            • 2 / 6
