    Bonzai3D - double take
    extensions
    119 Posts 21 Posters 15.4k Views 21 Watching
    • X Offline
      xrok1
      couple more crashes! i'm running out of patience now. we may have to continue this thread after a patch is released! 😕
        bonzai3d support
        Rocky,
        Looks like you are off to a good start, but sorry to hear that you have had some crashes. We have tried to follow your steps and reproduce the problem, but it is working properly for us. Also we checked to see if you were able to send any crashlogs to us (which we could analyze to see what might have caused it) but we have not received any reports from you. Did you get the opportunity to send a report, and if so, did you press Send?
        If you repeat the steps where you encountered the crash, do you reproduce this? If so, can you send your file and steps to us (support@bonzai3d.com) so we can test this further?
        If you select the option to Save the file, this will be saved into your Documents folder into a BNZ@date_time folder. (This will not touch your original file as it can sometimes be dangerous to save immediately after a crash -- although usually this saves just fine.) Also, if you do want to enable AutoSave, you can do this via the Preferences:
        (Just remember to also save your Preference File if you always want to use AutoSave...)
        Regarding Guides, you should not need these very frequently because of all the other input options, but if you use the Guide Tool, you can then "offset" these using the Move tool (and simply enter the distance in the Input palette). Instead of using guides in the case you show, you can hit the F4 key -- which will reset the Relative Zero and change your coordinates into Relative Input -- so you can just enter your 14.5" offset directly.
        Please feel free to contact us directly if you have any further questions or problems, and good luck on your project! 😄
        Explore * Design * Deliver
        http://www.bonzai3d.com
        Version 2.5 Now Available!
          bonzai3d support
          Rocky,
          We see that you just mentioned a few more crashes. Are these crashes always occurring in the Shaded display modes (or do you also get these with Wireframe)?
          Also, what video card and driver date do you have?
          • X Offline
            xrok1
            i almost never work in wireframe mode.
            i'll update my video drivers and try again.
              bonzai3d support
              Rocky,
              That driver is pretty recent, so we would not expect any problems specifically with this. However, we have seen some cases where using the "automatic" Update or installing a newer driver over the top of an older driver can cause a problem. Per nVidia's recommendations:
              http://nvidia.custhelp.com/cgi-bin/nvidia.cfg/php/enduser/popup_adp.php?p_faqid=10&p_created=1096404673&p_sid=Mj_mO5Xj&p_lva=&p_li=&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD03NDEsNzQxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ!!
              Uninstall the existing driver first before installing the current one. (With Windows 7, it may be necessary to uninstall more than once...)
              Does this help?
              Again, if you have any further specific questions or problems, please email us at support@bonzai3d.com. You can also call 614 488-8838 (9am-6pm EST) if you like.
              Hope this helps!
              • X Offline
                xrok1
                as soon as someone tells me why i can't draw a rectangle an cut a hole through this wall, i'll continue.3-17-2010 1-36-54 PM.jpg
                as far as i can tell its because the wall is a 3d wall object (dynamic), but there must be some way to collapse it or make it into a Plain Object??
                • X Offline
                  xrok1
                  ahh, i found the convert tool under manage:b3d1.jpg
                  but, wtf, i still can't cut a hole in it! 😞
                  furthermore even after i draw a rectangle and extrude it through a can't even select the resulting shape and it doesn't show up in the objects list??
                  • X Offline
                    xrok1
                    notice how it won't select even though its within the area pick rectangle?
                    • X Offline
                      xrok1
                      the weirdest thing is that if i use a circle (or any spline based shape) it works the way i'd expect, any other line shape won't make a cutout??????
                      in fact the circle even works as expected with the 3dwall object without converting it!!!
                        bonzai3d support
                        Rocky,
                        Sorry again that you are having trouble. You certainly should be able to insert any shape hole you want -- regardless of whether or not the object is a controlled object. (It should automatically convert to plain if necessary.) We can't tell why it is not inserting properly from your image alone. As we have requested previously, if you have any problems, can you please send your question to support@bonzai3d.com and attach your BNZ,zip file so we can get you an answer?
                        (Perhaps leading a tutorial and learning software at the same time is not the best practice. Please allow us to help you get up to speed!)
                        • X Offline
                          xrok1
                          this is actually not a tutorial but a journal of my experience with a new (your) software from a designers point of view. 😉 i will send you the file so you can check it out and advise on what's going on. i will try one more time from scratch since i'm not too far in anyways.
                          👊 biting my tongue over your last statement. 👊
                            bonzai3d support
                            Rocky,
                            Thanks for sending your file. We checked this geometry with the Object Doctor tool (check all options from all tabs, use Add to Selection, and Display Results) and we found quite a few problems:
                            We then changed the Add to Selection option to Fix (unchecked the Coplanar Surface check since I believe that you want these) and ran it again. This fixed the problems and now the insertions work properly.
                            Does this fix the problem for you?
                            • EdsonE Offline
                              Edson
                              rocky,
                              this is a very useful thread indeed. at least for us, potential users of b3d. keep it going.
                              http://www.mahfuz.arq.br
                              • X Offline
                                xrok1
                                ok, were back on track now. i had to do it twice to get it to work properly but at least i know i'm not crazy now. 😉 i appreciate your help, i can proceed with my journal now. 😉
                                PS, as you watch my process please feel free to chime in if there's an easier way of doing certain steps.
                                • X Offline
                                  xrok1
                                  so as you can see i drew construction lines along these two edges, then moved them a distance so they would intersect at the top left of the window opening. i then used their intersection as a guide to draw the window opening. (remember that i turned snap to intersection on earlier)
                                  • X Offline
                                    xrok1
                                    next was the offset tool followed by the reshape tool to create the window casing. (nothing fancy, just a guide for proper spacing)
                                    this might also be a good time to ask the b3d guys if there's a follow me type tool in case someone would like to create an actual casing profile and extrude it around the window.
                                    • X Offline
                                      xrok1
                                      couldn't really figure out how to paint the casing faces differently than the wall (any hints?) and got this while undoing. not too serious, didn't crash the program or anything. that reminds me, i better save. 😆
                                      btw, in case its not obvious the green text is aimed at the b3d team.
                                        bonzai3d support
                                        Rocky,
                                        We only check your thread occasionally (as much as time allows) but you will REALLY get faster answers if you ask them directly to us! (You can also post these questions on OUR forum, but this is a third party forum after all!)
                                        But anyway -- to answer your questions (now that I have seen them): The "follow me" tool is properly called the Sweep tool in most CAD software. You can find this on the Derive tool row.
                                        Picking objects in bonzai3d automatically picks the "most appropriate part (or all)" of the object, depending on the currently active tool. If this part is not the one you want, you can either hold down the Ctrl key (Win) or Command key (Mac) and place the cursor over the desired part to pick it, or you can also tap the TAB key to cycle through the available options.
                                        So, to color a face, drag the desired color onto this face while holding the desired modifier key, or get the Paint bucket tool and press the Tab key when the cursor is in the desired location (and click when the desired part is identified).
                                        Does this help?
                                          Could you use a less intense colour for your text? Very hard to read that green text.
                                            I'd suggest this, as it's easy to read 😲
                                            • 1 / 6
