    [Plugin] Drape Cpoints
    46 Posts 23 Posters 49.7k Views 23 Watching
      To 'paint selected faces' you select the faces as apply the Material with the Paint-bucket - all selected are painted ? What else do you need ??? 😕
      • EarthMoverE Offline
        EarthMover
        TIG - sorry, poor wording on my part. By "paint select" I mean hover select, not applying a material. Looking for a tool that you can click the mouse down once and drag over the faces you want to select. Similar to Fredo's script for edges, but just a simple one for faces. It would be easier than window selecting or individually clicking on faces to select triangles in a subdivided mesh.
        Content Creator at Skapeup
          Fredo ? 5 minutes work ? 🤓
            monk77
            Thanks for sharing. Great plugin.
            Cheers
            monk77
            my sketchup-animations
            • Chris FullmerC Offline
              How about Use Fredo's tool to select the edges, then right click on one of the selected edges and use the "Selection - Select connected Faces" option. That should do the trick!
              • fredo6F Offline
                Yes, sure. I would have to apologize if it takes longer 😍 .
                I had this in mind, and it is why HoverSelect is not called HoverEdges.
                • mitcorbM Offline
                  mitcorb
                  Whoa!
                  I like it already. Can't wait to try it.
                  • mitcorbM Offline
                    mitcorb
                    Hmmm
                    Next thing you know, one of these giants is gonna present a floating xyz gizmo for local mesh editing.
                      EarthMover
                      Another use for the script.....5 minute bedspread. (Bed model from warehouse)
                        dedmin
                        @earthmover said:
                        :berserk: Perfect perfect perfect! Exactly what I was looking for. Thank you so much TIG!
                        Now I just need a "paint select faces" tool to quickly isolate faces in the triangulated topology. This will be a very useful tool for doing things like adding snow to an irregular shaped object, or adding water to a waterfall.
                        Sorry, but how did you made triangulated mesh from the points?
                          pibuz
                          Sorry guys: I can't find the rb to triangulate the CPoints..
                          Could you please head me to?
                          ...btw GREAT RB! I can't wait to test it!
                          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                            The script 'points_cloud_triangulation.rb' [which shows in the Plugins menu as 'Triangulate Points'] is here...
                            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/points_cloud_triangulation.rb
                            that also requires 'delauney2.rb' - which you can get here...
                            http://forums.sketchucation.com/viewtopic.php?p=117071#p117071
                              dedmin
                              @tig said:
                              The script 'points_cloud_triangulation.rb' [Shows in the Plugins menu as 'Triangulate Points'] is here...
                              I tested it - SUPER USEFUL!!!!! BIG THANKS!! 😍
                                Ben Ritter
                                Earthmover,
                                For some reason, by looking at your images, I can't figure out what this script actually does or what happens in each step (e.g. bedspread example).
                                Can you explain? Thanks.
                                  Ben Ritter
                                  TIG,
                                  Thanks for the explanation. I suppose it sounds more complicated than it really is.
                                  Ben
                                    @ben ritter said:
                                    Earthmover,
                                    You select some faces/groups/components etc [the bed]. You give an XY grid spacing in a dialog and it makes a horizontal grid of Cpoints that's initially put just above the selection: the regular grid extends to the XY bounds of the selection. These Cpoints are then dropped down till they hit something in the selection OR, if not, then down to the minimum bounds of the selection. These Cpoints are grouped. This is all done so quickly you won't see it till the grid appears - there is a counter that shows its progress making the Cpoints and draping [dropping] them - there's also some 'behind the scenes' temporary grouping, erasing and exploding etc but you don't really need to worry about that ! Existing ruby tools can then work on these Cpoints to make a triangulated mesh face.
                                    I surmise what was done with the 'bed' was to make the draped Cpoints, a faced mesh was made with 'Triangulate Points' and then some vertices forming the bottom edge were manually moved randomly to form the 'folds' of the bedspread. Perhaps a few top face vertices were moved a little to give some 'dints'. The sheet part was probably selected and moved up a little to form a change of plane for the different material. It was then all smoothed and the materials applied...
                                    Its general use is if you have a triangulated site mesh made from survey data-points it'll likely be irregular - it's often preferable to make it into a regular XY grid (like those made by the Sandbox Tools). This tool lets you quickly drape a regular XY grid of Cpoints over the form and then reform them into a regular faced mesh using another tool, the original form is left unchanged...
                                      jamma-pcb
                                      ANy chance you could add gravity physics to this plugin.
                                      The idea is to hover a face over multiple components and any space inbetween curve based on the gravity amount. Like draping a quilt over many pillows. The edges it would follow on Z and any space inbetween to curve out on multiple edges.
                                      ANy chance of such a any tool
                                        Sounds pretty complicated ! 😮
                                        Don't you want something inside SketchyPhysics like a 'chain of hinged links' that you anchor at its two ends and it then 'sags' appropriately ?
                                        Each 'chain' would be made representing a 'rib' of a 'mesh' or 'net'...
                                        You'd then swap the links for simple edges and explode stuff and you have the basis of the surface ???
                                        My brain hurts already... 👊
                                        Thomthom is making a Vertex Editor and that might help ?
                                        Remus has also done some work on Catenary Curves...
                                        These things combined might do what you want BUT it'd be at the end of along list for me... others might pick up the gauntlet ? 😄
                                          EarthMover
                                          Sounds like he's looking for a real physics based cloth simulation plugin for sketchup. That seems as though it would be better integrated into sketchy physics as it has the framework for gravity simulation. I would love to see it, but I imagine it's still a far way off unless SU 8 implements a better engine under the hood.
                                          • X Offline
                                            xrok1
                                            great plugin. thankyou. here is the .zip file that contains this and the other two plugins needed to create a mesh. maybe you could add it to your original post. would be less confusing for some. 😳
                                            DRAPE_TRIANGULATE_DELU_Plugins.zip
                                            • 1 / 3
