    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • F Offline
      fine2444
      http://cfile234.uf.daum.net/original/155C3D1D4B6EA9867F0B3A
      I made two round corner model Yesterday, today.
      I want two same shape of rondcorner model but It is not working out.
      Working conditions were the same as the shape ..
      What's wrong?
      I dont want small triangle particles at all in very right model.
      You mean It happens becasue the edge is not aligned, I think I aligned it
      would like to tell me why and how?
        Hi Fine,
        Can you delete those edges without losing the faces?
        It's not necessarily there because you did not align your model but maybe because the newly created facets would not be co-planar otherwise.
        In any case, after smoothing those surfaces, it won't be seen (but I understand that you wish to have the least geometry and cleanest possible model)
        • fredo6F Offline
          What's wrong?
          Can you check if you use the same setting for the option "Strict Offset" (this is the button with the vertical green and red bars).
            archi-sketch
            i don't know what to say..or should i just say~THANK YOU VERY MUCH!!! ..you make my day!
              rd84
              Many thanks for this utility - my life using Sketchup is suddenly much easier !
              Cheers
              Paul
                aea
                2D round corner is ? plugin , something ?
                • mitcorbM Offline
                  mitcorb
                  See TIG's 2D Tools.
                  Or fillet one corner with arc, mirror copy the others.
                    aea
                    my instal TIG 2D TOOLS bad no i managed ...?
                    • massimoM Offline
                      massimo Moderator
                      Try this Adrian, it's called "2D fillet".
                        Jim
                        A Fillet Tool should be a first-class plugin for Sketchup. What I mean is it should have a spot in the Tools menu, have a clear purpose, meet user's expectations for a native Tool, and be a stand-alone plug-in separate from dependencies.
                        I know several plug-in suites have a fillet feature, but I think would be better to borrow the best functionality from them all and create a dedicated feature out of them.
                        Sorry to go off-topic.
                        • fredo6F Offline
                          You can also try BezierSpline 1.3and convert your rectangle and other polylines to have round corners.
                          See post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
                          1. select the rectangle (contour with surface is fine)
                          2. call the contextual menu Convert to... > Polyline Arc Corner
                          3. You are prompted for the Radius of the corners
                          4. Your contour will be rounded at the corners and become a curve
                          5. you can change the number of segments of the corner by typing a Precision number followed by 's' (this is the number of segment for a full circle, by default 24)
                          6. You can later chang'Ee the Radius and Precision with the BezierSpline Edit tool (also in contextual menu when selecting the contour 'Edit Polyline Arc Corners')
                            aea
                            THANKS from answer , 2d tool , fillettool , fillet.rb no works , bezier spline is ok ...
                            • ely862meE Offline
                              ely862me
                              Hi Adrian! I see u have some problems with the plugins!
                              Send me a private message so we can discuss better.
                              Till soon!
                              Salut Adrian! Vad ca ai ceva probleme cu plugin urile!
                              Trimite mi un mesaj privat sa putem discuta mai bine.
                              Pe curand!
                              Elisei (sketchupper)
                              Come and See EliseiDesign
                              • romboutR Offline
                                rombout
                                why is there a PS plugin in the folder??????
                                • HieruH Offline
                                  Hieru
                                  I'm having a little difficulty with the plugin.
                                  The plugin works initially, but when I save my file I lose a small section from each corner.
                                  Any idea what might be causing this?
                                  http://artsablaze.com/Images/missingCorner.jpg
                                  www.davidhier.co.uk
                                    Sketchup can't create faces that are too small. Scale up the geometry first, then scale down.
                                    • X Offline
                                      xrok1
                                      that sentence should be added to the end of every forum topic title, specially the newbie one. 😆
                                      it should actually be a SU popup to warn the user when this happens.
                                      • HieruH Offline
                                        Hieru
                                        Thanks for the response.
                                        Unfortunately I already tried that and the same thing happens.
                                        The plugin creates the rounded corners (20mm radius in this case), but as soon as I save the file a section from each corner literally vanishes. If I 'undo', the missing section reappears - disappearing again if I try and save the file.
                                        What is odd, is that it only appears to happen with certain files and certain objects within a model (just basic shapes - nothing complex).
                                        www.davidhier.co.uk
                                        • X Offline
                                          xrok1
                                          did you try scaling it up before saving it?
                                          • HieruH Offline
                                            Hieru
                                            Yes I did.
                                            I've just tried remodelling certain elements of the model I'm working on and I'm finding that all sorts of odd geometry is appearing on its own and random bits of geometry keep disappearing in areas where I haven't applied the plugin.
                                            I'll have to try reinstalling SU.
                                            www.davidhier.co.uk
                                            • 73
                                            • 74
                                            • 4 / 74
