    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 790.6k Views 175 Watching
      chloesdad
      TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
        Here's another update [3rd of the day!]
        http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        In this one the FR lingvo file has been updated by Didier Bur...
        I knew that Extrude Edges by Loft == Extruder des arรชtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
        But Extruder des arรชtes par profilage entre courbes is not half as snappy ??? ๐Ÿ˜‰
        The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
        Anyway whatever fits is best...
        ๐Ÿ˜„
        Enjoy...
          Better is "Tendre une surface entre 2 courbes" and more poetic ๐Ÿ˜‰
          (tensile structure) a loft between 2 curves
          • teufT Offline
            teuf
            I'm agree ๐Ÿ˜‰
            What a good tool, TIG. Simple and efficient. Many thanks ๐Ÿ‘
              Shall I leave you FRench purists to ponder ?
              It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
              your
              or
              Maillage entre courbes snappier
              or
              Courbes vers maillage ???
              It's your language, so say it how you like...
              Even EN-US users can even reword what their English version says, so
              could be edited to
              Loft a Mesh using Selected Curves
              which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. ๐Ÿ˜’
                Don't worry! At the end that is the best! ๐Ÿ˜‰
                  Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  A glitch in EEbyLoft's mesh-making when some curves had particular combinations of segment-count, and face-orientation reporting is fixed/improved...
                  ES lingvo updated by Diego-Rodriguez.
                    Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    EEbyRails and EEbyRailsByFace: Erasure of original curves glitch fixed.
                    EEbyFace: Variable renamed to avoid clash with EEbyRailsByFace.
                    EEbyLoft: Chinese lingvo file added by Hebeijianke.
                      driven
                      fantastic, yet again... and it works even on my Mac...
                      so a question about spacing of interconnects.
                      can they be set equal, i.e. distance between lines A and B = x equally spaced new lines?
                        Because it's a 'bezier' curve that joins the curves the segments are not evenly spaced: however, some have asked if the 'segments per section' could be set individually - I am thinking about that... ๐Ÿค“
                        • ayan13A Offline
                          ayan13
                          I have no words to say!!!Great man!!!!You make our life better!!!!:)
                          • ken28875K Offline
                            ken28875
                            I second that! ๐Ÿ˜‰
                            Follow Your Dreams.
                              Rip Tanion
                              I find "Edges by Rails" to be by far my favorite of the set. I find it has the most predictable and satisfactory results.
                                Hi TIG,
                                Do you think that you could add the date to the topic title when you update them? I find myself checking it daily to see if you've updated the toolset.
                                With the frequency that you bang out revisions it's hard to keep up with you ๐Ÿ˜ฒ
                                Just a thought
                                  The zip has the date as its name e.g. extrudeTools_20100312.zip and I do add an announcement to say it's changed and a link back to the base page, and I do add announcements to the individual tools' page too - linking back to their base pages, which in turn link back to the zipped set's base page. I stopped adding the update's date or version rference to the threads title because I kept forgetting to change it when I updated the zip ! ๐Ÿ˜’ By putting the date in the zip's name I avoid that error...
                                  So the answer to your request is... 'No' ๐Ÿ˜ฎ ๐Ÿ˜‰
                                    I suppose i was being a little unreasonable ๐Ÿ˜ฒ
                                    Must organize myself a bit better ๐Ÿ˜‰
                                      Here is an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      Several of the files had a potential [but very rare] glitch in calling sub-methods - it has now been fixed.
                                      The very few users who reported these problems should try this update and see if they now have a fully working set...
                                      Feedback please. ๐Ÿ˜•
                                        Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                        EEbyLathe has been changed - see its updated help thread for full details...
                                        It now has dynamic angle and segment [45 or 9s] entry in the VCB and a 'ghost display' of what it'll make OR if you enter 0 as the angle you can pick two points to set the rotation angle, with <Alt> to toggle <>180 degrees and <Shift> to toggle c/clockwise...
                                        The affected 'lingvo' files will be updated shortly...
                                        • ken28875K Offline
                                          ken28875
                                          Great! Thank you, Sir. ๐Ÿ‘
                                          Follow Your Dreams.
                                            Here's the update with the lingvo files updated for EEbyLathe http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 ๐Ÿค“
                                            I suspect that at least he Chinese one could do with some work ๐Ÿ˜ณ
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
