    [Plugin] Select Lines by Length (Updated March 9th, 2009)
    20 Posts 11 Posters 35.0k Views 11 Watching
      If I want all lines of a selection? (not the faces ! )
      Can you add something for that? โ˜€
      404 Not Found
      (www.sketchucation.com)
        Thx I had another one by Matt666
        Selection manager
        I will try yours also! โ˜€
        Yours seems more cozy! ๐Ÿ˜Ž
        Even it's a toy! ๐Ÿ˜‰ ๐Ÿ˜„
        Adopted! ๐Ÿ˜Ž
        But if Chris can make something like ">length wished" that will be terrific! ๐Ÿ’š
        Like >0
        or
        0 & < 12
        • Chris FullmerC
          I might not get to it right away, but adding a selection length range would be easy enoug to do. Thanks for the suggestion.
            Cool! โ˜€
            • simon le bonS
              simon le bon
              Heyhey! Chris,
              Clever idea, wonderfull tool. Many thanks, just continue this way, cause we need such tools ๐Ÿ‘ ๐Ÿ˜› ๐Ÿ˜„ ๐Ÿ˜„ simon
              • EarthMoverE
                EarthMover
                Chris,
                Would it be possible to also have a script that would select faces all of the same surface area?
                Content Creator at Skapeup
                • Chris FullmerC
                  Yeah, thats a good idea. I'll see if I can get that implemented. I have 2 others also in progress right now. Hopefully I'll get a chance to finish some of these up today. Thanks for the suggestion,
                  • P
                    publied
                    chris,
                    another very interesting plugin from you! nice job. thank you so much.
                    /paolo
                    hire me@ http://www.publied.it !
                    • bagateloB
                      bagatelo
                      Very good plugin. Is possible to make plugin work only in selection?
                      • Chris FullmerC
                        I suppose I could. The idea would be to select geometry first, then run the plugin and then when you click, lines only get added if you have cliked on something that is selected? Is that what you mean?
                        • bagateloB
                          bagatelo
                          Yes!!!
