    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Select Lines by Length (Updated March 9th, 2009)
    20 Posts 11 Posters 33.4k Views 11 Watching
    • Chris FullmerC Offline
      Descrtiption: This script selects all lines of a specified length.
      Usage: You can start with a single line selected and this tool will select all other edges in the model of the same length. OR you can have nothing selected and it will prompt you to supply a length. The length is automatically in the default model units or you can specify ( 12", 2', 10cm, 110mm, etc).
      [flash=651,613:3jcg1p2h]http://www.chrisfullmer.com/forums/Select_Edges_by_Length.swf[/flash:3jcg1p2h]
      v1.1 - Changed where it loads itself.
      v1.1
        Panga
        Nice script Chris, That'll hepl me a lot.
        Thanks.
          azuby
          I also coded something similar this night reusing the code form "Select all with same orientation" (SAWSO) It's should be simple to integrate the functionality to select more than one line, Chris.
          azuby
          *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
          Bad English? PM me, correct me. :smile:**
            True, it wouldn't be that much more code to make it so it allowed for multiple starting lines being selected. Just a single line was the request, but if multiple lines is desired, I could expand it.
              Tricky ☀
              Maybe that be possible to choose something like this
              13 <= length < 20 ?
                Dee256
                Thanks, Chris! It's stuff save my worktime! Thanks Thanks Thanks!!! 😍
                  sigue2000
                  That's a great script Chris!
                  Thank you.
                  It should save me a lot of clicks in the future.
                  What?
                    It's a pity that works not for a line "grouped" or a line "component"! 😉
                      If I want all lines of a selection? (not the faces ! )
                      Can you add something for that? ☀
                        301 Moved Permanently
                        (www.sketchucation.com)
                          Thx I had another one by Matt666
                          Selection manager
                          I will try yours also! ☀
                          Yours seems more cozy! 😎
                          Even it's a toy! 😉 😄
                          Adopted! 😎
                          But if Chris can make something like ">length wished" that will be terrific! 💚
                          Like >0
                          or
                          0 & < 12
                            I might not get to it right away, but adding a selection length range would be easy enoug to do. Thanks for the suggestion.
                              Cool! ☀
                              • simon le bonS Offline
                                simon le bon
                                Heyhey! Chris,
                                Clever idea, wonderfull tool. Many thanks, just continue this way, cause we need such tools 👍 😛 😄 😄 simon
                                • EarthMoverE Offline
                                  EarthMover
                                  Chris,
                                  Would it be possible to also have a script that would select faces all of the same surface area?
                                  Content Creator at Skapeup
                                    Yeah, thats a good idea. I'll see if I can get that implemented. I have 2 others also in progress right now. Hopefully I'll get a chance to finish some of these up today. Thanks for the suggestion,
                                      publied
                                      chris,
                                      another very interesting plugin from you! nice job. thank you so much.
                                      /paolo
                                      hire me@ http://www.publied.it !
                                      • bagateloB Offline
                                        bagatelo
                                        Very good plugin. Is possible to make plugin work only in selection?
                                          I suppose I could. The idea would be to select geometry first, then run the plugin and then when you click, lines only get added if you have cliked on something that is selected? Is that what you mean?
                                          • bagateloB Offline
                                            bagatelo
                                            Yes!!!
